Question about Dell Optiplex GX60 PC Desktop
Sound drivers no run devices my computer
  • Dell Master
  • 32,281 Answers
You can download the device drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows of the drivers for your Windows operating system. Click on this link to download the drivers: -
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Posted on May 07, 2013
How to install
Reeva,
If you have not tried to install it then follow the steps given below.
Disconnect the device from the computer. Insert the CD that came with the device into the drive. Let Auto run run the CD. Install the drivers for your device according to the operating system. Reboot the computer. Connect the device and allow Windows to auto detect it and load its drivers. Happy printing.
If you have attempted to install the device then go to Control Panel->Add Remove Programs. And uninstall the device and reboot the computer. Then you can follow the steps given above.
Aug 15, 2011 | Epson Stylus Multifunction Inkjet Printer/...
It asking for modem device on high definition audio bus driver and sound is not coming...
  • 1
    Click the link "hp: Modem Driver Installer for Microsoft Windows XP (32-bit)" listed in Resources if you run the Windows XP operating system on an HP computer; for Windows installed on a Toshiba computer, go to Step 3. For all other types of computers running Windows, go to Step 4.
  • 2
    Click "Download" from the HP website and click "Run" to install the high-definition audio (HDA) modem driver package. If the modem device does not work properly after the driver has been installed on your Windows XP computer, go to Step 9.
  • 3
    Click the link "Toshiba Audio Drivers" if you run Windows and use a Toshiba computer. Find your operating system, click the appropriate driver listed and then read the installation instructions on the screen to download the driver. If the modem device does not work properly after the driver has been installed, go to Step 9.
  • 4
    Click the "Start" button and click "Control Panel."
  • 5
    Click "System and Security" and click "Device Manager" under "System."
  • 6
    Click "System Devices" and right-click the "Microsoft UAA Bus Driver for High Definition Audio" device.
  • 7
    Click "Update Driver."
  • 8
    Update the "PCI" description drivers (PCI bus and PCI device) and any modem device that displays an exclamation point to the left of it. If the modem device does not work properly after the driver has been updated, go to the next step.
  • 9
    Visit the computer hardware or operating system manufacturer's website for further support
  • Jun 13, 2011 | Computers & Internet
    I cant find out tat driver of thisd model
    You can scan the computer with a program called Unknown Device Identifier -->
    http://www.zhangduo.com/udi.html (scroll to the bottom.. theres a link that says 'Download Now')
    It will be an application, it does not require installation and runs right from the download folder.
    After running the program, it will display a list of all of the devices in your computer. You want to find the device that says 'Unknown Device' or a device that appears to not have a driver installed. Search @ www.google.com with the name of the device and that's it!
    Mar 29, 2011 | Computers & Internet
    Gateway 310 s won't recognize a cd
    Method 1: Initiate recognition of the USB device by using Device Manager loadTOCNode(2, 'workaround'); To initiate recognition of the USB device by using Device Manager, follow these steps:
    1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens.
    2. Click to select your computer as the location for the scan.
    3. On the Action menu, click Scan for hardware changes.
    Windows XP recognizes the new device.
    4. Close the Device Manager window.
    If this method resolves the issue, you are finished.
    If this method does not resolve the issue, go to method 2.
    Method 2: Disable power management of the USB hub loadTOCNode(2, 'workaround'); Note If you perform the following procedure, you may also reduce the battery life on a portable computer.
    Use this method if method 1 does not work. To disable power management of the USB hub, follow these steps:
    2. Expand Universal Serial Bus controllers.
    3. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed.
    4. Click the Power Management tab.
    5. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
    6. Repeat steps 3 through 6 for each USB Root Hub in the list.
    7. On the Action menu, click Scan for hardware changes.
    8. Close the Device Manager window.
    If this method does not resolve the issue, go to method 3.
    Uninstall all the usb controller from USB controller
    and now restart the computer.
    If this method does not resolve the issue, go to method 4 .
    Method 3: Restart the computer loadTOCNode(2, 'workaround'); To initiate recognition of the USB device, first unplug the USB device and restart the computer. Then, wait five to ten seconds before you plug the USB device into the computer or hub. Windows XP recognizes the new device.
    Hope this helps.
    Jan 14, 2011 | Gateway 310 S PC Desktop
    Usb ports not wokring . every thing installed when in connect the mouse.its not working . but mouse lights are on. and any other usb device connect its also not wokring.
    To scan for hardware changes, follow these steps:
    1. Click Start, and then click Run.
      Note If you are running Windows Vista, click Start, and then use the Start Search box.
    2. Type devmgmt.msc, and then click OK. Device Manager opens.
    3. In Device Manager, click your computer so that it is highlighted.
    4. Click Action, and then click Scan for hardware changes.
    5. Check the USB device to see whether it is working.
    If scanning for new hardware did not fix the problem, try restarting the computer. After the computer has restarted, check the USB device to see whether it is working.
    If restarting the computer fixed the problem
    3. Expand Universal Serial Bus controllers.
      Note You might have to scroll down the list to find this item.
    4. Right-click the first USB controller under Universal Serial Bus controllers, and then click Uninstall to remove it.
    5. Repeat step 4 for each USB controller that is listed under Universal Serial Bus controllers.
    6. Restart the computer. After the computer starts, Windows will automatically scan for hardware changes and reinstall all the USB controllers that you uninstalled.
    7. Check the USB device to see whether it is working.
    Oct 24, 2010 | HP NX5000 Notebook
    How do i put music,pictures ect in the device
    Connect your MP3 player via USB cable to the Computer.
    when you connet mp3 player, it will automatically running.
    If not running go to My computer - Select Removable Device and Open -
    Copy Music File or Picture from your computer and paste to your mp3 player.
    Feb 08, 2010 | Audio Players & Recorders
    USB ports not working
    Method 1: Use Device Manager to scan for hardware changes loadTOCNode(2, 'resolution'); Use Device Manager to scan for hardware changes. After your computer scans for hardware changes, it might recognize the USB device that is connected to the USB port so that you can use the device.
    If scanning for hardware changes fixed the problem, you are finished. If this method did not fix the problem, go to Method 2.
    Method 2: Restart the computer loadTOCNode(2, 'resolution'); If scanning for new hardware did not fix the problem, try restarting the computer. After the computer has restarted, check the USB device to see whether it is working.
    If restarting the computer fixed the problem, you are finished. If this method did not fix the problem, go to Method 3.
    Method 3: Disable and re-enable the USB controller loadTOCNode(2, 'resolution'); Use Device Manager to disable and re-enable all the USB controllers. This lets the controllers recover the USB port from its unresponsive condition. The USB controllers represent the USB ports in Device Manager.
    To disable and re-enable the USB controllers, follow these steps:
    Jan 02, 2010 | Evesham Axis PC Desktop
    Nextar will not connect to computer
    What operating system are you running?
    Did you run the cd included with the device?
    Did you click the bubble that popped up when you plugged in the device? If this appears, it can walk you through the device install process.
    Sep 07, 2009 | Nextar MA933A MP3 Player
    Hanging
    could be a virus/spyware/malware, also empty you temp and history files, then restart ur pc.
    Nov 12, 2007 | Intel REALTEK nc-r150201 Network Adapter
    Sansa e250 issue
    Sounds like your music may have become corrupt.
    You can follow these steps to erase and start anew.
    Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
    http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
    You need to put the device into "recovery mode" before you run the tool.
    - Turn the device off (hold power for 20 seconds)
    - Slide the hold switch into "hold" position.
    - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
    Then run the recovery tool. Select format when prompted.
    Best of Luck.
    Nov 08, 2007 | SanDisk Sansa e250 MP3 Player
    Dell Optiplex GX60 PC Desktop Logo
    14 people viewed this question
    Alun Cox
