Question about LG LSC121PMA Split System Air Conditioner
Snowflake over water drop
Hi. I have a LG Art Cool. There is a symbol that appears on the unit that is a snowflake above a drop of water. It only appears when I put the unit on the sun symbol to heat the room and then the unit will only blow cold air. Even if it's set to 30 degrees centigrade. The Unit is 5 years old and was recently serviced and cleaned. Please help as I cannot find any solution to this problem.
  • 400 Answers
SOURCE: LG Room Air Conditioner Model
I would say that your return air sensor is faulty or not positioned correctly. Check sensor
Posted on Mar 05, 2009
  • 415 Answers
SOURCE: The AC doesn´t work when outside temp goes 100 degrees and above
Try using a garden hose to wash down the condensor coil (the coil that is exposed to the outside air).
During the cooler times when it seems to be working, check the temperature difference of the air coming out against the temperature of the air coming in (room temperature air). The temperature should be approximately 16 to 22degF difference. If you are not getting at least 16degF air, you most likely need to have your unit serviced to see if professionial cleaning or a recharge is needed. If you are getting the temperature difference but not getting the amount of cooling you need during hot weather, it could be a capacity problem. You can perform a quick test by using the calculator on this site:
http://www.goodhousekeeping.com/home/air-conditioner-calculator.
I hope you find this information helpful. Good Luck! :-)
Posted on Mar 08, 2010
TheMobilian
  • 8220 Answers
SOURCE: it blows cold air for 5 min. and the it blows cool air for 15 min
See if you can reposition the thermister on the facing of the evaporator coils. That could be it or the thermister might be bad. They don't use copper/mercury sensing bulbs these days. They use these cheap thermisters.
Posted on May 22, 2010
SOURCE: I have a 18000btu LG
Hello.I think they are on to something with shortcycling on temp sensor.I think it should be sampling the return air instead of (inside coils ?).A 2*f dead band use to be built in (factory installed) to thermostats to prevent on/off, but not sure in this case.Try a new sensor location(return air) and see if anything changes.
Posted on Oct 26, 2010
hvac1960
  • 2133 Answers
SOURCE: I have an LG AC/Heat
TO GET HEAT, SET MODE OR SELECTOR SWITCH ON "HEAT" AND ALSO TEMP+29
Posted on Dec 13, 2010
On Fujita remote is it the sun that appears on the remote for heat as it doesn't say heat cool it's just little symbols
Yes, the sun symbol is 'heat', the snowflake is 'cool', and the water drop is 'dehumidify'
Jul 19, 2016 | Heating & Cooling
Does not produce Heat
Sounds to me like it is defrosting the outdoor unit. Is this possible? The process takes a little bit to complete but it will then start up again.
Nov 14, 2014 | LG LA120HYV Art Cool 120HYV Ultra...
If I want to cool the house what symbol is it? the sun or a snowflake?? thanks
Cool symbol is * and sun symbol refers heat and snowflake refers dry mode. Happy?
Dec 27, 2010 | Fujitsu 24C1 Air Conditioner
The insiside unit is cover with ice and leaking water
The unit has a leak and is low on charge...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Nov 26, 2010 | LG Art Cool LA181CNW Split System Air...
LG Art Cool, 2 splits. Error code CH7
Multi Splits and Multi V = indoor unit is set to run in a different mode from the master indoor unit. Set ALL indoor units to cooling or ALL to heating to clear.
Splits = Compressor Over Current (CT2)
Jul 09, 2010 | LG Art Cool LA121CNP wall/window Air...
Art Cool LA181CNW Split System Air Conditioner: hi, i am using an lg split airconditioner. the sp...
Sound like a defective receiver board. Have this checked. Also check to see that your remote transmits. Hold the top part of the remote to your phone or digital camera lens. press a button and a light should appear on the screen of your phone or digital camera screen.
Hope this helps I take the time to answer your question so please rate me
May 18, 2010 | LG Art Cool LA181CNW Split System Air...
Heating does not start appears a light circle with am asterisk and small drop inside the circle ()art cool lg
possibly a freon charge issur, or thermistor problem, in the heat mode the indoor coil has to be a certain temp. for the fan to run, if it does not reach the temp because of a low charge or a sensor that is defective, could be more complicated but usally not. Note: if it is low on charge you have a freon leak that needs to be repaired.
Jan 31, 2010 | LG Art Cool LA091HNP Split System Air...
What do symbols mean i lost my remote and instruction book.triangle,snowflake,pan with drop above,3 blade fan
Triangle = automatic
Snowflake= cooing only
Pan with drops = dehumidifying mode
3 blade fan = fan only (no heat/cool)
Aug 18, 2009 | Heating & Cooling
Which symbol is cool. Such as I feel cool, heat,
COOL is the snowflake, I feel is a four arrows which looks likea square, HEAT is a sun and Dry is a water droplet
Hope this helps
May
Jul 16, 2009 | Mitsubishi Heating & Cooling
LG error CH 64
What is the model of the unit?
Apr 07, 2009 | LG Art Cool LA121CNP wall/window Air...
Heating & Cooling Logo
29 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
