Question about HP Photosmart Premium C309A All-In-One Printer
Hp c309a message error remove usb device from printer
Remove usb device from printer
SOURCE: hp laserjet 1020 ( usb device not recognized )!?
I recently have the same problem with a HP Photosmart Printer with windows XP ( when I connected the printer the message USB device unknown message appeared) Before wasting your time unistalling and reinstalling driver, I strongly recommend this:
Change the USB cable for a new one THAT WORKS PROPERLY FOR USB 2.0 FULL SPEED . What does it mean ?. Well if you have an older cable is very probably that it doesn't work well at USB2.0 full speed (480Mbps) because it's not properly shielded, if you buy a new one check specifications on the box to see if it is prepared for 480Mbps. Testings in other PCs is not relevant unless you're ABSOLUTLY SURE that USB ports are working at full speed in those PCs
I changed old cable for a new one ( Belkin), and no more problems.
Posted on Jun 19, 2008
SOURCE: hp 2355 all in one error message
mine HP was acting the same way after a jam. I contacted hp and they told me it was a hardware issue and that I would need to purchase a new printer. I found a KB on thier site for this issue. It involved removing both ink carts and then reseting the printer with the ink carts out. it seemed to work.
Posted on Jul 03, 2008
I have solved this problem, it seems that the cable I used isn't sufficient enough, it was cheap A-B USB cable for printer. I used then the quality cable from my external 3,5" hardrive. I uninstalled all USB related things in device manager, then restarted my computer (just for the case, remove the laptop battery for a while when you are using laptop), then turn on computer, install the laserjet software and then if the message on screen says "connect the printer", do so. Then you should get a messages about correct installing your laserjet and problem is solved :). Good luck, I spent nearly one dat solving this :)
Posted on Mar 30, 2009
sgoswami
  • 114 Answers
SOURCE: HP Photosmart Premium c309a series will not print
Try This :
Try printing from micrsoft word; Click on tools;
Click on Envelopes and Labels
Click on "OPTION"
Under the TAB Envelope Option you will get Evelope Size;
Scroll Down to the bottom you will get an option "Custom Size " Select it;
Set the accurate size of the envelope;
Click on Printing Options
Select the Feed method and make sure you do it the same way;
And then try to print this should resolve your Issue
otherwise let me know
Regards Soumajit
Posted on Sep 21, 2009
Testimonial: "Still not working. Great idea, tho."
  • 59 Answers
SOURCE: error message 0x610000f6 won't re-set.
>try to do hardware reset
>while printer is on unplug power cord at the back of it, press and hold # and 6 buttons on your printer, while holding the buttons plug back power cord, printer should initialise you can release the buttons after 10 secs or until you see semi full reset on the display, if the printer will not automatically turn back on press the power button, if it ask for you to set the region and laguage again then you have done the reset successfully
>this hardware reset should clear the error otherwise better contact hp
Posted on Sep 29, 2009
Error 0x61000f6 hp 6500
For your interessting:
Strange:
I disconnect the HDMI cable from the Vu+ Solo2 DVBS2-Satellite-Receiver, and the HP Photosmart C309a "rings", and show this error message.
Two completely different Systems without any connection.
Note: Actually I use a rolled ~10m-HDMI-Cable between Receiver and TV, and the Printer is only connect to the Computer with a slightly longer USB cable, loose lying on the desk.
And, in this Printer, actually there is not a print head (But that does not explain this strange error).
Aug 29, 2012 | HP Officejet 6500 Wireless All-in-One...
HELP ! My HP C309a photosmart 3in 1 printer
Hello and Welcome!
The error
Oxc19a0040 is mostly occurred in HP printers
To solve the error code
Oxc19a0040,Follow the given steps
  • Reset the printer without turning off the printer, disconnect the USB cable from the rear of the printer
  • Remove the cartridges from the printer
  • Wait for the 'Insert Cartridges' message to display on the control panel
  • Disconnect the power from the back of the printer
  • Now wait 60 seconds
  • Now reconnect the power If the product does not automatically turn on, press the Power button
  • Reinsert the cartridges, and then close any open doors on the printer.
  • If you receive a prompt to print a calibration page.Print it
  • Reconnect the USB cable to the port of the printer & then try printing again
Error will automatically remove.
Thank you for using FixYa!
Jun 08, 2012 | HP Photosmart Premium C309A All-In-One...
Error message "USB not compatible" Any ideas?
Try re-installing the printer drivers again.Install the drivers that corresponds with your operating system.
Hope this helps.Thanks!
Please rate this answer.
Oct 20, 2011 | HP Photosmart Premium C309A All-In-One...
HP c309a printer - error message 0xc19a0036, have cleaned the heads and the turned it off and on again and still won't work. Flits between error message ending in "36" and "24". Any...
hello, well, if you followed hp self help on the cleaning printhead, if you have then i would replace printhead, amazon seems to have the best price for the printhead. around $40.
Oct 10, 2011 | HP Photosmart Premium C309A All-In-One...
I "m getting error 252*
Welcome to FixYa!
Try to reset the printer by doing the following;
1. Turn ON the printer.
2. Disconnect the USB printer cable at the back of your printer while the printer is ON.
The USB printer cable looks like the image below.
3. Open the Cartridge Door and remove the cartridge. Refer to the image below.
4. Wait for the "Insert Cartridges" message to display on the message screen of the printer.
5. Disconnect the power cord from the back of the printer.
6. Wait for 1 minute.
7. Reconnect the power cord.
8. If the printer does not turn on, use the power button to turn it on.
9. Reinsert the cartridges.
10. If the printer prompts you to print a calibration page or requests for a cartridge alignment, please do so.
11. Reconnect back the USB printer cable and try to print.
I hope that this would be helpful to you, thank you for usng FixYa!
Jas247
Mar 06, 2011 | HP Photosmart Premium C309A All-In-One...
Error message 0x610000f6 won't re-set.
Sep 28, 2009 | HP Photosmart Premium C309A All-In-One...
HP Photosmart Premium C309A  All-In-One Printer Logo
41 people viewed this question
Seeker5211
Seeker5211
