Question about Pioneer VSX-305 Receiver
Pioneer vsx 502 stereo no sound when on fm/am tuner cd player plays sound
  • 63 Answers
SOURCE: pioneer vsx d512
All you have to do is connect the coaxial out from pc to any audio i/p at the back of vsx d512.but ensure you select the right channel to play the audio ( eg. tape i/p select tape at front control, aux i/p select the aux at front control )
Posted on Aug 03, 2007
Gurudristi
  • 98 Answers
SOURCE: Pioneer VSX-D209 receiver shuts off when too loud
Dear Tabasco,
Your receiver is basically going into protect mode.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem.
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck! Thanks for using FixYa!
Posted on Apr 21, 2009
  • 30 Answers
SOURCE: Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
Posted on Aug 02, 2009
smarthome2
  • 1114 Answers
SOURCE: Pioneer VSX 818V No Sound
First thing to check is the Speaker Select Switch. It will say, "A" "AB" or "Both" it will be displayed on the LCD screen as well. Second if that's ok, Check the "Direct" switch. If it's on, turn it off. Generally if it's on, you will see a blue light if it's on (most receiver's)
If you still have No audio, hook up your DVD to the "Direct" input and turn "Direct" on. If you have audio then. The DSP chip is probably bad and you should take it to a shop and have them bench it first to confirm. Hope this helps
Posted on Dec 05, 2009
Testimonial: "Got me on right path, but I'm still stuck."
  • 15 Answers
SOURCE: Pioneer vsx-819H: MCACC setup won't display on tv
Its because the pioneer does not display menu options through hdmi. You have to hook up basic yellow composite to monitor out.
Posted on May 03, 2010
Center speaker problem on pioneer vsx 40 .I hooked up the center speaker and I can’t get sound from it
Most problems are menu settings, because surround modes can be complex and confusing. Verify what surround input type you are using. FM tuner will not play center spkr unless put into a simulate or expand stereo mode. Do other surround speakers work other than normal L/R stereo mode? You can try redoing your auto surround setup (MCACC) or going to the manual speaker setup and verifying speaker is turned on in menu system. Rechech you listening mode setups at Pages 33,38,39 in your manual. Try another speaker and wiring on center output. Try Different surround inputs, some manufactuers have had problems with their DTS and HDMI boards. Otherwise take to repair.
Nov 22, 2017 | Pioneer Audio Players & Recorders
Why cant I record FM from this Pioneer vsx921
To record from the built-in FM-tuner, you can use either the DVR/BDR or the CD-R/TAPE outputs of the receiver.
Mar 13, 2015 | Pioneer VSX-921K 7.1 Channel A/V Receiver...
Amp plays sound through previews of the movie - but NOT when the movie starts??
This sounds like a problem with the DSP chip. Turn off any DSP and surround modes in the unit and see if it at least plays in stereo. You may need to unhook the DVD player from the 5.1 inputs and put the front left/right into a CD or TAPE input to fully test this theory.
If that doesn't work, I have a VSX-D309 that just came up for sale (sorry, no remote)
Feb 22, 2011 | Pioneer VSX-D557
No stereo signal from FM? I have had this receiver for several years. I have tried several times to get a stereo FM signal. I have tried a "T" shaped antenna, an "S" shaped antenna...
Appears that your multiplex circuit in receiver is fubar. Also make sure that your receiver is set to the Stereo mode since the mono mode will also turn off the tuner stereo section.
Jun 17, 2017 | Pioneer VSX-D811S Receiver
I just bought a new pioneer cd player and i put a cd inside and it plays it normally but suddenly it changes to radio stations it's very strange
That is the symptom of a faulty selector switch. That's causing automatically switch up from CD to tuner station. Replaced the selector switch with a new one, so ks normal again.
Good luck;
Don't forget to rate:
Jul 10, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown ...tech service only.
Feb 05, 2009 | Pioneer VSX-D608 Receiver
No sound
I have the same problem. It worked before and now the sound is gone. If I put it on tuner and turn it up all the way I can hear a little bit
Dec 14, 2007 | Pioneer VSX-D511 Receiver
Overload
Ok, how much is "a bit"? If you are operating your unit at the 50% or more level, your unit is working as it should, as DVD and CD players output more signal than other sources...accordianman
Nov 26, 2007 | Pioneer VSX-D307 Receiver
163 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
