Question about LG Televison & Video
Red button not working tv - LG Televison & Video
    Top Expert:
  • LG Master
  • 74,666 Answers
If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Nine Lakh viewers cannot be wrong.
http://electrohelponline.blogspot.com/
Posted on May 07, 2013
Can't get Mitsubishi tv remote to work with my
These are universal remote setup codes for Sony TV. 0128 0013 0002 0071 0380
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jul 04, 2012 | Televison & Video
After retune bbc redbutton not working
Found this when my Philips LCD TV lost the BBC RED button http://sparedparts.com/parts/details/philips-lcd-tv-bbc-red-button-no-longer-works
No BBC RED button
Apr 07, 2012 | Philips Televison & Video
Hi I have a vizio tv control with the key board and it all just stopped working so I thought it was the batteries changed them still not working ????? Help Please
Test ur tv remote control first see,if it is working,malfuctions or completely dead?U have a Digital Camer wright?Yes.Digital Camera can read Infer Red signal Output by the tv remote.Yes?Turn the Digital Camera on and take the tv remote point it at the Digital camer and pushes all the remote buttons the Infer Red signal will read all buttons Infer Red signal flashes u can see on Digital Camer viewing screen.Pushes all remote buttons see flashes of white lights.Mean the tv remote control it it good or not.Take some cottons ball soak it with some rubbing alchachol clean the tv Infered Red sensor on the tv frame near the power LED incation light.Might be dirty,Still not reading the Infer Red signal.If 100% it is the tv remote control is the cause,it CPU is dead.Try website like Remotes.com to buy another the tv original remote.
Jul 29, 2011 | Vizio VO47L 47 in. LCD TV
What was the code did all work cause i can not get it to work at all
Hello
Just try one amoung the following codes. I've only these three codes are available with me for Jensen Tv.
{ 0004 _0009 _0133 }
Proceedings
Note:- If one amoung the above four codes did't work, try the other after the TV is switched off and switch in again after some time, say at about 10 seconds, and try the other. Not enter the code continously without turning it off, after one code won't work. Ok.
__________________________________________________________________________________
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Oct 25, 2010 | Jensen TS2050J 20" TV
Remote codes for the 22LV506 for a dish network remote please. none of the provided codes for this tv work. Thanks, Frank
You can power scan any dish network remote for the correct code by pressing and holding down the tv button(clear or gray button at the top of the remote) until the lights all light up, release the tv button. Press the larger red power button (not the red tv button) release button then press the channel up button repeatly givng time for tv to shut off. Once tv shuts off press pound key and red tv button to turn tv back on, Press sat key to go back to satellite mode.
Jun 19, 2010 | Toshiba 22LV506 21.9 in. LCD HDTV/DVD...
Please help me match my Philips Universal Remote controller with Toshiba TV
Okay this goes for the 3000 series remotes it might work for more. Press and hold the setup button until the red indicator light stays on'. Then release the setup button. Press and release the desired mode button (TV,VCR,etc) In your case it would be TV.The red indicator light then stays on.Then enter the four digit code. For a valid entry the red light goes off for a invalid code the red light flashes.With your device powered on push the channel up button if it works you are done. If some buttons don't work try some other codes.The codes are 0517, 0419, 0512, 0613, 0719, 0112, 0506, 0111, 0618, 0618, 0627, 0437, 0041, 0313, 0715, 0094, 0802, and 0111. And this helps you give me a vote please.
Mar 04, 2010 | Televison & Video
I can't get my directv Remote to work my sanyo tv must use tv remte now to turn on tv and addjust volume
try these steps.
1. turn on device 2. press setup (underneath on/off) till red light stays on the take finger off the button 3. press and quickly release device button (tv,vcr,etc.) the red indicator blinds off once 4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press 5. press and release enter to install code.
if your tv is not working the remote dont have your tv model stored, you need to find a compatible remote.
Feb 20, 2010 | GE JASRM24912 Remote Control
Code for Sky+ remote to work with Toshiba TV AV635DB
Hi there. I have just bought the same television today and I have just found that the remote code 0156 does actually work. The mistake i initially made was not pressing the TV BUTTON after I had held in the SELECT and RED Buttons together, making the light blink twice. So here's what I did:
1. Press the TV button
2. Hold in the Select and Red Button until the red light flashes twice
3. Press the TV button again
4. Enter the code 0156 (The Red light will blink Twice again)
5. Test the controller - Try to change the volume
6. If it works, press SELECT one last time to save the settings.
Hope this helps.
apnit
Jan 04, 2010 | Televison & Video
RC24912 - D
1 manually turn on the device (tv, vcr. etc) to be controlled
2.Press and hold the setup button until red indicator stays on, then release the Setup button.
3. press and quickly release the desired device button (tv vcr etc). the red indicator blinks off once
4. Enter the following codes then press the channel up button and if anything happens the light will go off.
Jenson TV codes 0004, 0009, 0133
If you can't get any of these to work then you will have to do the exhausting manual version.
CODE SEARCH FOR THE RM24912
4. press the channel-up button repeatedly (up to 300 times) until the device to be controlled changes. The red indicator blinks off with each button press.
5. press and release the mute button to install the code. Then the light will go off.
Jan 19, 2008 | GE RM24912 Universal Remote Control
Televison & Video Logo
20 people viewed this question
Computer Repairing
Computer Repairing
