Question about Asrock Computers & Internet
Agp8x manual bored Ic Damage
  • 5,660 Answers
Go to AsRock Support
Using the secret model number of the motherboard, find the support page on AsRock Support for it.
I figure it's a secret because you did not post it.
Regards,
joecoolvette
Posted on May 07, 2013
What is the cause of power loss and requirement to fix it
dirt in the carb , strip and clean ! clean tank also !
low compression , 100psi or more on tester and if less then remove cylinder head and check bore for wear or damage , gasket also ! if damage in bore then a rebore and oversize piston kit and new gaskets etc !
Aug 15, 2014 | Yamaha DT 125 R Motorcycles
Bore sighter manual
You have not provided the model number of the laser bore.
Best to visit this site and look for the one you want.
http://www.ncstar.com/support/product-manual.html
Aug 11, 2014 | NcStar Optics
Low compression in 2 cylinders
Your head gasket is blown or motor has seized due too overheating or lack of oil
Sep 23, 2013 | Clymer EvinrudeJohnson Outboard Shop...
Where do i find the VT8237 Mother Board manual
It's an IC (chip), not PCB, check here:
http://www.via.com.tw/en/products/chipsets/southbridge/vt8237/
Aug 07, 2013 | Gigabyte GA-7N400 Pro 2 : ATX Socket A...
Hi, I'm having problems starting my new morrison bc230b weedeater... I think whats happened is the wrong fuel was put in it..(no oil mixed) .is there a quick fix? thanks
hi there
walkersworld
if you have run the unit with no oil in the mix ie straight petrol
you will have damaged the piston / rings / bore - do a compression check - if its quite low
check - remove the muffler and check for score marks on piston and rings and bore
if so , the unit may not be worth repair , because compression will be lost past damaged rings
and with damage on piston more scoring / damage will occur
so answer to is there a quick fix - no especaily if what find when you look up the ex port at piston / rings/bore
have a look
sorry for bad news
pauly46
May 31, 2011 | Garden
HOW DO YOU CHANGE A LEAKING FROST PLUG IN A 1999 OLDS ALERO. V6
CORE PLUGS HARD TO REACH THEY ARE ON SIDE OF CYLINDER BLOCK.ENGINE HAS TO BE REMOVED BEFORE YOU CAN REACH REPLACE CORE PLUG.TO CHANGE CORE PLUG YOU CAN USE A HAMMER AND A LARGE PUNCH.KNOCK CORE PLUG SIDEWAYS IN BORE.PULL CORE PLUG OUT WITH PLIERS.WHEN INSTALLING NEW CORE PLUG IN BORE.MAKE SURE INSIDE BORE CLEAN FREE FROM RUST.USE SCOTCH BRITE INSIDE BORE.ROTATE SCOTCH CLOCK WISE POSITION TO REMOVE RUST INSIDE BORE BE CAREFUL DONT DAMAGE SCRATCH INSIDE THE BORE.THEN CLEAN INSIDE BORE WITH ACETONE.REMOVE RUST AND GRIME.WHEN YOU SEE CLEAN DRY METAL SURFACE.COAT THE SEALING SURFACE OF CORE PLUG WITH A NON HARDENING SEALANT LIKE PERMATEX NUMBER 2 .DRIVE NEW CORE PLUG IN PLACE WITH A LARGE 1/2 INCH SOCKET AND 1/2 INCH EXTENSION IF YOU DONT HAVE A DRIVER SET.YOU ARE DONE.
Feb 18, 2011 | 1999 Oldsmobile Alero
Where are the freeze plugs located on 1994 Ford Taurus?
For the vehicles covered by this information, one of two types of freeze plugs may be used: a cup-type plug or an expansion-type plug. They are removed in the same way, however two different kinds of tools are used to install them. REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable. Drain the cooling system.
  2. Remove the necessary components to gain access to the freeze plug.
  3. As required, raise and support the vehicle safely.
  4. Drill a 1 / 2 in. (12.7mm) hole in the center of the plug, then remove the plug using a Universal Impact Slide Hammer T59L-100-B or equivalent. Inspect the plug bore for damage that might interfere with the proper sealing of the plug. If the bore is damaged, you will have to bore the surface to accommodate the next specified oversize plug.
Oversize plugs are identified by the "OS'' stamped in the flat on the cup side of the plug.
To install:
  1. Lightly coat the plug and/or bore with an oil resistant Stud and Bearing Mount E0AZ-19554-BA or Threadlock 262 E2FZ-19554-B or equivalent.
  2. Cup type core plugs are installed with the flanged edge outward. The maximum diameter of this plug is located at the outer edge of the flange. The flange on cup type plugs flares outward with the largest diameter at the outer sealing edge.
  3. Expansion type core plugs are installed with the flanged edge inward. The maximum diameter of this plug is located at the base of the flange with the flange flaring inward.
  4. For the cup-type plug, it is important to push or drive the plug into the machined bore by using the proper tool. Never drive the plug using a tool that contacts the crowned part of the plug. Damage to the plug and/or plug bore may result. When installed, the trailing (maximum) diameter must be below the the chamfered edge of the bore to effectively seal the plugged bore.
Fig. 1: Use the proper tool when installing a cup-type plug
  1. For the expansion-type plug, it is important to pull the plug into the machined bore by using a properly designed tool. Never drive the plug into the bore using a tool that contacts the flange. Leakage and/or plug blowout will result. the flanged (trailing) edge must be below the chamfered edge of the bore to effectively seal the plugged bore.
Fig. 2: Use the proper installation tool when installing an expansion-type plug
  1. Install all the removed components. Lower the vehicle, as required.
  2. Fill the cooling system and check for leaks.
Hope helps.
Jan 09, 2011 | 1994 Ford Taurus
Power suplay bored problem AC1601 IC BLOW
Try these telephone number for Insignia serve and parts. Service Number 1-877-467-4289. Parts Number: 1-888237-8289. Insignia is a brand name use by Best Buy Inc. and there may be a another number for them in your area. Look under Best Buy. Hope this helps you with your problem.
Apr 24, 2009 | Insignia LCDTV26 26 in. Television
Error code-6
open all case. power supply bored is seen.removable an 8 pin ic is seen. exchange ic from the one same ic besides the secondary memory ****. and transfer jumper lug downward.power on unit for 2 sec. return jumper lug up. power on unit. unit is now ok
Feb 23, 2008 | Kyocera KM-1505 Copier
Computers & Internet Logo
178 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
