Question about Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer
Washing machine problem...
I own a Large capacity,, 5 years old, amana,, washing machine.. (commericial size)reads..on machine..Problem::: The Tub has a (hair line crack) in it,, near the base... and leaks water from it...when water is but into the Tub.. (Stanless Steel)...Options: 1. can I seal it with a sealer compound..or glue... if so please advise which kind.. 2. Replace outer Tub..
Stop drill the crack then apply some jb weld.Make sure and clean area real good before applying jb weld.
Posted on Oct 29, 2007
  • 5,911 Answers
A good marine type silicone sealant (like what you might use on boats) might buy you some time. However, with the vibration of the machine and the torque applied to the tub when the transmission and drive motor engage to spin will only make the crack worse over time. Sorry, but you might want to think about replacing the tub.
Posted on Aug 11, 2007
What is the capacity of whirlpool model #LA5558XTW2
This is a direct drive model washer tub size is large capacity but any washer to stop from overloading is loose laid cloths 3/4 of tub any washer to work properly
Dec 19, 2016 | Whirlpool Washing Machines
Why would the hot water cycle of my washing machine not work?
The solenoid that opens to admit hot water is either defective or not being energized by control panel.
Jun 20, 2017 | Washing Machines
What size is an Amana washer LW8303W2
I had the very same question, so I can buy a replacement that is just as big. Not finding the answer online, but only your question, I measured mine and calculated the volume at about 2.5 cubic feet. I am surprised it seems so small, because it is labeled as an extra large capacity. Of course, it is now about 15 years old, so maybe the new ones are mega washers or something. I wonder if I will get that much time out of a new one.
Jan 17, 2011 | Amana NAV2335A Top Load Washer
Magic Chef washing machine getting out of balance
it is a sign that the dampeners on the ends of the tub suspension or support rods have failed
A pack of 4 cost around $80.00 and with a technician doing the job can be done in 15 minutes
with you doing the job , around 1 hour unless you can get the spares people to explain how it is done
get the spares from the service agent spares
any unbalance gets out of control unless it is got under control very early and that is what these dampeners are designed to do and 4-5 years is the design life expectancy
Sep 17, 2017 | Magic Chef CAV2000AWW Top Load Washer
Amana Distinction super capacity plus 3.3 stainless tub...works great, no vibration, but in the spin cycle it has started to roar, being very loud. Why did this start..could it be the idler roller for the...
You have a tub seal that has leaked and the tub bearing has gotten wet and started to rust. This problem will continue to get worse and louder until the tub bearing falls apart. This is a major repair , the parts are not that expensive to replace, ( about $60.00 )but the labor involved is major. In some cases the washer is replaced for this problem. I also would not recommend you attempt this repair yourself. This job takes a professional about 3-5 hours, and sometimes the seal will leak again anyway. If you do decide to attempt this repair I will try to find you a detailed step by step guide. But, be prepaired to replace the machine if the repair fails. It is a major job. I know this is not what you wanted to hear, but its not a horse so shoot it and get another one. that would be my suggestion.
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 10, 2010 | Amana Washing Machines
I have an Amana Large capacity Stainless washerthat spins FAST!
Great that exactly the desired result, probly needed a belt for a while.
Mar 15, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Jammed agitator
Some further checking indicated a bad transmission. As the unit is 15 years old, I decided the best solution was a new machine! ..
Dec 03, 2008 | Washing Machines
Hi, I have a 5yr old Amana Distinctions Super Capacity Plus top load washer, 2spd motor, 3.3 cu ft. I have taken off the front cover to expose the wash tub, because recently when the washer is in a spin...
sounds like a drain pump issue, not able to remove water quick enough before the centrifical force of tub spinning throws it over the top, remove the pump hoses and look for blockages
Nov 07, 2008 | Amana Washing Machines
Leaking at drum where drive shaft enters
hi thanks for the question .your problem is major save yourself a lot of aggravations purchase new a nice washer is called roper built by whirlpool but cheaper same quality thanks the appliance doc
Sep 28, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
AMANA DISTINCTIONS FABRIC CONDITIONER RELEASE
Hello Daddy 2,
Welcome to fixya
I'm Huuum and happy to assist you,
What is the model number and the year of the washer?
Front load or top?
A waiting your response!
Huuum
Dec 10, 2007 | Amana 3.2 cu. ft. Top-Load Washer
Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer Logo
228 people viewed this question
Top Amana Washing Machines Experts
Sal De
Mike
Virgil Watts
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
