Question about Kitchen Appliances - Others
Ciabatta bread cracks on top and sides after baking in Rotating Oven at 220 Deg C
My Ciabatta rye bread cracks on the sides and top afte rbaking. What could be the possible reasons? Is it due to oven temperature/ proofing or mixing? what should the standard process time, temperature and ingredients be? Please reply, bit of an urgency. Your help or input is highly appreciated.
PitVipermd
  • 54 Answers
SOURCE: I need to know the
This is the order I use with excellent results..good luck!
water
molasses
butter
white flour
wheat flour
rye flour
coffee granules
salt
fennel seed
yeast
Posted on May 01, 2009
  • 56 Answers
SOURCE: The bread did not bake. The ingredients mixed,
You may have a bad heating element. If this is the case it will be hard to find that part.
Posted on Dec 08, 2009
  • 433 Answers
SOURCE: Oster 5834 not mixing ingredients well before rising & baking
Take the bread pan and paddle out of the machine and see if you can spin the paddle by hand. If it moves freely, then it could be the belt is loose on the pulley inside the base of the machine, or the pulley or motor itself is not right. Either check the belt or exchange it at the store or check warranty. It is obviously a defect. Good Luck, Hank
Posted on Jan 21, 2010
EwingElect
  • 276 Answers
SOURCE: bread top "sinks" when in the final baking process...
Suggest that you check the amount of yeast. If there is too much the top may sink.
Posted on May 24, 2010
daryl441918
  • 1280 Answers
SOURCE: After adding ingredients, plugged in bread maker
Some machines have a delay before they start kneading if they detect that the ingredients are not at the right temperature. Try waiting about 10 minutes after you pust start and see if it starts kneading. I have a Breadman machine that warms up for about 5 or 10 minutes and then starts kneading.
Posted on Oct 10, 2010
Whirlpool built in electric oven bake (bottom)heating element does not heat up only tot heats when in bake mode
CHECK FOR CRACKS IN THE BAKE ELEMENT. IF THE UNIT IS NOT HEATING THE BOTTOM, BUT THE TOP IS STILL HEATING, YOU MORE THAN LIKELY HAVE TO REPLACE THE ELEMENT. THIS IS A 220 VOLT OVEN WITH 110 VOLTS ALWAYS GOING TO THIS ELEMENT, SO TURNING OF THE BREAKER IS VITAL FOR SAFETY PURPOSES. WITH AN OHM METER, UNINSTALL THE ELEMENT AND CHECK BOTH WIRE CONNECTIONS FOR OHMS. YOU SHOULD GET SOME KIND OF READING BETWEEN 10 OHMS AND 500 OHMS. IF YOU'RE NOT AT LEAST GETTING A SOLID READING, REPLACE THIS ELEMENT.
Jan 24, 2013 | Whirlpool 24" Double Electric Built-In...
My oven is not baking properly. The tops of banana bread and cinnamon rolls are browned and bottoms still soggy.
It's possible the lower bake element is not working. If the oven takes a long time to come up to temperature, that's a good indication that a baking element (bottom, broil element is on top) is bad.
Apr 27, 2011 | Whirlpool GBS307PR Electric Single Oven
I know how I make an exact bread dough , but when I cook it in oven it has not maximum spring in oven and so it is not soft enough , I cannot find how I can solve the problem .
Since you have a bread machine you should just go ahead and choose a program and let the bread machine do the baking for you. It will be at the right temperature and allow your bread to rise better than in the oven.
Be sure you are not using flour that is marked "all purpose flour" you should be using a bag of flour marked "bread flour" unless you are baking a whole wheat bread.
Jan 02, 2011 | Magic Chef CBM310 Bread Maker
Labels on black and decker toaster oven worn off CT0650C
Top dial is Bake/Broil knob, it goes left to right. Starts with OFF @ 9 0-clock next is 100 dgre then @12 o-clock 180 Deg. is at top center next is 250 Deg. next 350 located opposite of off. Next @ 4 o-clock is 400 Deg. Next @ 5 o-clock is 450 Deg. and finally at the bottom at the 6 o-clock position is BROIL. The Center Knob is BAKE TIMER . Starts @ off position as 0, next @ 10 o-clock is 10-mins. Next @ 12 o-clock position is 20 mins. Next @ 2 o-clock pos. is 30 mins. Next @ 3 o-clock pos. is 40 mins. Next @ 5 o-clock pos. is 50 mins. Next and finial pos. is 60 mins. The Bottom knob is TOAST @ the 9 o-clock is is 0 next @ 11 o-clock pos. is Light , Next between the 12 & 1 o-clock pos. is MEDIUM and the final pos. @ 3 o-clock is DARK. TOAST.
Jun 13, 2009 | Black & Decker CTO650 1500 Watts Toaster...
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
