Question about HP Compaq dc7600 Small Form Factor PC Desktop
Hp compaq diagnosis
My hp compaq dc7600 desktop when switched on it blinks with a red warning light producing a sound 2 what could be its problem?
  • 79 Answers
Hi, if your hearing a beep when the bios or pc is booting, there might be a hardware thats failing. Check this link as your reference: http://www.computerhope.com/beep.htm
Posted on May 07, 2013
abhi_patil
  • 568 Answers
SOURCE: HP COMPAQ D530 RED BLINKING LIGHT WITH BEEPING SOUNDS
if it is a long beep then check ur ram, try cleaning ram. if not solved then there may be problem with ur ram try changing ur ram.
if it is short beep and if you have a display card installed check the display card
Posted on Dec 27, 2008
SOURCE: HP COMPAQ D530 RED BLINKING LIGHT WITH BEEPING SOUNDS.
4 beeps & 4 flashes mean problem with the power supply. For my experience, most of the time the PSU is good, it is just overloaded.
For more LED and Beep messages, check this link:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00067072/c00067072.pdf
Posted on Dec 31, 2008
  • 5 Answers
SOURCE: blinking red lights on startup
If you look up the HP diagnostic LED code on the xw8200, if the red diagnostic LED is blinking 4 times signifies a bad power supply.
Posted on Mar 28, 2009
efs_perpends
  • 1996 Answers
SOURCE: Blinking red light at
Please take a look at this link, and consider the possibility that your power supply has failed. Also helpful may be this article. If you take it in to them, a local computer tech can load test the power supply to determine if it is in fact at fault, and they are readily replaced for minimal cost.
Most likely your hard drive will have been spared, and your data secure, but this is the reason quality surge protectors are recommended for IT systems. No way to tell for sure until you power it up again and see if the hard drive spins up...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 27, 2009
martmet
  • 52 Answers
SOURCE: 5 Beeps with red light.
Well those beeps tells you that something is going wrong with the hardware. Could be the memory/processor or something going bad on the motherboard. Well you could try a few things (new memory/harddrive/removing all PCI cards except the video card) to try to isolate the problem. But you probably end up at the computer store where technicians can take a look at it. So I would go there first since it's probaly gonna take some time to figure it out anyway. Also try to remove anything you installed recently. Good luck!
Posted on Jun 08, 2009
Problem with the HP Compaq dc7600 Small Form Factor PC Desktop Audio driver is installed but microphone is not working.
Depending on operating system installed, check for microphone enabled in "sound" setting found in control panel. Also may have a "mute" setting in sound mixer control aplet.
-AAT
Feb 21, 2011 | HP Compaq dc7600 Small Form Factor PC...
I am not found hp compaq dc7600 ethernet controller download pleas help me
Try here :-
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=472278&prodTypeId=12454&prodSeriesId=472276&swLang=25&taskId=135&swEnvOID=2094
or just google "hp compaq dc7600 drivers"
Nov 13, 2010 | HP Compaq dc7600 Convertible Minitower PC...
If i start up my dc7600 sff there is a red led blinking and 4 beeps then a pause and again 4 beeps this happens several times and then it stops. Can you help me to solve this problem ? Thank you in...
RAM has been faulty of your PC.If your system has two RAM's then you can check it one by one RAM.If it is only one RAM then you can check it with another RAM.
Sep 15, 2010 | HP Compaq dc7600 Small Form Factor PC...
Computer will not start
It all depends how many beeps there were.
From http://h18000.www1.hp.com/products/quickspecs/12253_div/12253_div.HTML
Diagnostic LED Explanation Table Number of 1-second red LED blinks followed by 2-second pause, then repeats:
2-processor thermal protection activated
3-processor not installed
4-power supply failure
5-memory error
6-video error
7-PCA failure (ROM detected failure prior to video)
8-invalid ROM, bootblock recover mode
I have only really come across 4 beeps = order new Power Supply or 5 Beeps = reseat the memory and hope it works
Regards,
Oli
Apr 15, 2010 | HP Compaq dc7600 Small Form Factor PC...
I have an HP Compaq dc7600 sff that will not power on. It has a solid green light on motherboard, no other response.
1) perform a powerdrain i.e. unplug the power cable from the back of the computer and then press power button and hold it down for 10 secs
2) open up the chasis and reseat the power cable i.e ATX connector coming out of the SMPS to the motherboard
Feb 15, 2010 | HP Compaq dc7600 Small Form Factor PC...
Jun 08, 2009 | HP Compaq dc7600 PC Desktop
Soundcard
Hey there, the HP bios is pretty smart - it should automatically detect a new sound card and switch off the internal one when installed - alternatively you can go to the 'system devices' panel and disable it in the software as well.
hope this helps
cheers
Nov 19, 2008 | HP Compaq dc7600 Convertible Minitower PC...
HP Compaq dc7600 Small Form Factor PC Desktop Logo
66 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
