Question about Rinnai Heating & Cooling
Rinnai RCE 670TRE gas heater
How to turn it on
SOURCE: Need to disengage the child lock on a rinnai rce-318H gas heater
You need to press the child lock button - keep pressing hard on the button until it turns off - takes a few seconds.
Posted on Jun 23, 2010
  • 120 Answers
SOURCE: Rinnai RCE-606A vent free space heater, the Lock
Hold the lock button down for approximately one second to switch between locked and unlock. If it is locked when you turn it on you will need to do this first
Posted on Jul 30, 2010
  • 120 Answers
SOURCE: Heater goes out after 20min error code 12 appears
Definately a gas supply problem. If it was an overheat you would get a different code. Error code 12 meant a flame was there but then went out. The code 11 meant tried to light but no flame sensed. Error code 12 on heaters and Infinites is nearly always a fault on the gas regulator at the bottles. Sure I recognise your company name from up in Queensland. As you might know we hae had problems with an oily residue in some regulators for ages. I am recommending going away from two stage regs and spliting them up with a seperate first stage and then a second stage. Bit more expensive by zero call backs.
  • 120 Answers
SOURCE: rinnai gas heater model RCE-318H
Real odd one as if ignition fails this unit is designed to flash various lights to give you an idea of what the fault is. Also this usually happens after about 10-15 seconds. I'm going to have to ask you to clarify that no other lights flash. If I had this fault exactly as you descibe, after running some basic tests to check gas supply and any obvious damage or burnt out components I would change the the main PCB as a start and the control PCB as a plan B.
Posted on Aug 09, 2010
  • 103 Answers
SOURCE: can I convert a rinnai rce-229a from propane source to natural gas source
It should be. You should be able to replace the oriface and the regulator. Propane is at a higher pressure than natural gas.
Posted on Aug 08, 2012
How to fix gas heater Rinnai RCE-229H?
get a gas fitter in to fix the problem as gas is less forgiving than electricity
Jul 19, 2015 | Rinnai Heating & Cooling
I require a user Manual
RINNAI GALAXIE SPACE GAS HEATER REH241EC
try www.rinnai.us and download the user manual.
Sep 01, 2014 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Rinnai natural Gas Heater 25 TR (Avenger RCE 670)
this is all I could find it looks like an earlier model, but it may be helpful. sorry it is such a long link. it's the download link for the manual, hope it helps.
http://www.google.com/url?sa=t&rct=j&q=rinnai+natural+gas+heater+manual+avenger+RCE+670&source=web&cd=3&ved=0CC4QFjAC&url=http%3A%2F%2Fwww.finesgas.com%2Fproduct_extra_files%2FRinnai-RCE-592.pdf&ei=rzZgUMbfKpLI9QTwx4DwCQ&usg=AFQjCNGPoBENsIVWy_-1GG94mowsXBSosg&cad=rja
Sep 24, 2012 | Rinnai Heating & Cooling
Can I convert a rinnai rce-229a from propane source to natural gas source
Aug 01, 2012 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
I have a Rinnai RCE-329H gas heater that keeps turning off.
Check..for gas pressure creep.....2 lb sys....big problem...change to green hat....pig tail line.....rinnai gas valve problem being fixed....
May 31, 2012 | Heating & Cooling
Extremely annoying humming sound coming from our rinnai RCE-318H gas heater. sounds like a bearing or wheel spinning noise. please help?
The humming you hear is from the gas pressure or lack there of. Check the inline gas shut off valve, to make sure it's fully open. If that checks out OK, turn the unit OFF completely and wait five minutes, before turning everything back ON and relighting the heater. If the noise is still there, contact your Rinnai dealer for a service call.
I hope this helped you, Arthur. Thanks for choosing FixYa. Cheers!
Aug 27, 2011 | Rinnai Heating & Cooling
Why does red light on "on" button stay on?
The reason the red light on your rinnai vent free gas heater stays on simply is because it is having power on it, if it is unplugged, it will go off, or if you turn off the switch from the power outlet, then it will go off too.
As long as there is power supplied to the rinnai vent free gas heater, the power light will remain on.
Take care and good luck
Dec 01, 2010 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Mar 13, 2010 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
WONT START AND LIGHTS FLASH
try interrupting power to reset.if it still doesnt work consult manual for code to flashing light sequence.also make gas supply is on
Jun 23, 2009 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Heating & Cooling Logo
48 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
