Question about Clarion (NAVSIR) SIRIUS Radio Receiver
Clarion SIRIUS Radio Receiver - Not Receiving All Subscribed Channels
Had some car work done recently where they disconnected the battery. Now my Clarion Sirius receiver only gets a small subset of my subscribed channels. When manually trying to tune a Sirius channel I get an "Invalid Message" error on the Clarion display. Some channels come in fine, however. I called Sirius and they sent the updated subscription message... They told me to tune to channel 184 but that is one of the "Invalid Channels". The receiver reverts back to one of the channels that it does receive. Any help in troubleshooting is much appreciated. Thanks.
  • 4 more comments
  • wmayhem Aug 14, 2007
    Please keep me posted and let me know what Clarion says!
    This weekend, I'm thinking of trying to recreate the battery disconnect scenario that caused this issue...
    I'm fairly certain that, when the battery was reconnected at the auto repair facility, the vehicle was in a building that obstructs the Sirius signal.
    I'm going to try disconnecting and reconnecting the battery while the car is outside and has unobstructed access to the Sirius signal - to see if a complete reboot will reset the receiver to be able to get all the channels.
    Have any thoughts on this???
    Thanks.
  • wmayhem Aug 26, 2007
    Disconnecting the battery and reconnecting solved the problem!!! Did it work for you?
  • Huge Fish Nov 19, 2007
    My CMD-4 gives an "invalid channel" message since changing out the boats batteries. Called Clarion, the Tech. basically told me I was on my own because I purchased the unit online...... Thanks alot, this was my last Clarion purchase......... He did say that I need to reset the module.....? Anyone know how to do dat??? Thanks.
  • Anonymous May 27, 2008
    i have heard that if you know the code SID# you can program it to any of your sirus systems to activate them is that true? If so, how do you do it?
    Jim
  • rufus0331 Jul 03, 2008
    I had the same problem with my DX945MP. I had to disconnenct the battery to work on my car, as a shadetree mechanic, of course! Reconnecting the battery under the same tree resulted in an incomplete update for Sirius. This was resolved by moving the car to an area with an unobstructed view of the sky and disconnecting the battery for a few minutes.
  • Anonymous Mar 22, 2014
    in manual it says a SC-C1 required
My DX445 does the same thing. Here's my method for fixing it, it should work for any similar Clarion receiver:
1. If possible, make sure the radio is turned off when disconnecting the battery. If the radio turns itself on when the vehicle is restarted (for example after jump starting or battery disconnect for a few seconds only), turn the radio off.
2. Disconnect the battery by removing the negative battery cable from the battery. Leave it disconnected.
NOTE: Car batteries can be dangerous things. If you're unsure how to do this safely, get an experiences mechanic to help you.
3. Reset the radio. On my radio this is done by removing the faceplated, and pressing a tiny button for 30 seconds. Your radio may be different.
4. After waiting at least 20 minutes, reconnect the battery.
5. My radio displayes 'System Check -- Press Power'. After pressing the power button, the display reverts to the clock.
6. Turn on the radio. It should work fine on the broadcast bands.
7. Select 'Sirius'. The radio should display 'Updating'. Don't touch anything until the radio finishes its update phase. When it's done, it should tune to Sirius channel 1 and play as normal.
8. This should restore normal tuning. reset your presets and preferences.
What seems to happen is that the radio gets stuck in a 'Category Select' condition, but not all the categories will load, and manual tuning will not allow, say, Radio Classics to play when the radio is stuck in Pop mode.
On occasion (maybe 1 time out of 10), the radio hangs while doing the 'updating' in Sirius mode. If this happens, just shut off the radio and start over. I've never had to do the brute force reset more than twice since I stumbled on this method.
Posted on Dec 09, 2008
    New Friend:
Thanks!
Posted on Nov 15, 2011
  • Trevor Nov 15, 2011
    This totally worked, My battery died, put in a new one, satellite radio said Invalid channel and was stuck on channel 1. I stupidly called Sirius first, an hour and a half of tech support and they said my new battery had shorted out my convertor box for my Clarion deck. Thanks.... I did one google search ONE. Pulled the negative off my battery and my faceplate, and my fuse. Waited 20 minutes. Plugged it all back in and what you know... WORKS! System Check, Updating Thanks guys, shorted out, ha I didn't think that happened.
    New Friend:
I had the same problem with my Mazda CX-9. It was in the garage for an extended period. When my wife first drove it, the channels tried to reload, but not all of them were available. I could not get 184, and some of the news and weather channels. I called Serius, and they could not fix the problem. They said it was probably my antenna. I read this thread and disconnected my battery. I had to leave it disconnected for about 10 minutes for it to reset. It came back up on channel 184 and reset all of the channels. Thanks.
Posted on Apr 06, 2010
Thank you so much for posting these comments. I had the same problem and was able to rectify it based off this page. I took my truck to a dealer and had some work done. They obviously disconnected my battery while in their big metal shop...once, re-enabled, it looks like Sirius went to update and was not able to get a good signal. I kept getting "Invalid Channel" for every channel.I called Sirius, resent the signal, etc. Nothing was working. They didn't know the solution. Tuning to 184 for an update was not working either. Low and behold I found this page...I pulled the radio fuse for my Clarion, while parked outside, and reinitialized....It worked!!
I was so mad dealing with this issue, that had I not found this page, I was ready to go buy another deck to put in the truck...this saved me some cashola!
Posted on Apr 14, 2009
I had the same problem with my Clarion Sirius receiver. I found that simply pulling the radio fuse instead of disconnecting the battery worked great. Thought this might be easier for some to do. I was receiving no (0) channels. I pulled the fuse. Put the car in accessory power to make sure the deck wouldn't power up. Waited a few minute and replaced the fuse. The radio performed the full update and all is well!
Posted on Dec 26, 2008
Disconnected my battery last weekend while doing some mechanical repairs in the driveway. I have a clarion DX545MP head unit and CL1 tuner. I'm so glad you guys put this up here because I just got off the phone with Sirius and after resending the init signal 2x, they said it was a problem with my Clarion headunit and referred me to their support dept. I'll try to repeat the disconnect again and hope for the best. Like I said, I was in the driveway with a clear shot to the sky but I turned the car on and off again (testing) and not paid attention to the radio updating and turned it off before it fully completed it's programming. I'll post back tomorrow.
Posted on May 09, 2008
I have had the same issue with both a CMD4 Clarion Marine Radio and a VRX745 Clarion Head Unit in my vehicle. For the head unit in my vehicle, there is a reset button that does NOT work to update the receiver with missing Sirius channels (but it will look like its doing it). Using info from this site, I disconnected the positive battery terminal, waited a few minutes, then reconnected the battery. Went into vehicle, turned on VRX745 head unit and it walked me through set up. This time it actually performed an update and I got all my channels back.
For the CMD4, I did not try the battery disconnect because I wasn't aware it might work. What I did was manually scan by category. It's a pain, but if you go to a "pop" channel and tell it to scan (don't remember exactly how, but you'll find it) it will scan for all channels that fall under the "pop" category. It will skip over all other categories, so hopefully you have a "valid" channel in each of the categories. I then tuned to a "country" category channel and scanned, then a "entertainment" category, and so on. Got most of the channels back that way.
Posted on Jan 23, 2008
I am having the same problem, i was able to manually get about 37 channels by holding down the BND button which changed the mode to manual tuning which allowed me to manually move to individual stations. By going bak and forth I was able to add more stations, but once I got to channel 38 (which is not a used channel) I could not add more channels. I don't know if this will help you get a few more channels. I am going to try to call clarion to see if they can help, if you get it fixed, please post what you did. Thanks and hopefully we can get this fixed
Posted on Aug 13, 2007
  • Rockum Aug 17, 2007
    I was thinking of trying the disconnect myself. Let me know if that works and if not I will give clarion a call this weekend. Unfortunately I have not had a chance to do it yet and i cant find there e-mail. I will post something once I get a hold of them if the disconnect does not work. I know that when I took my car in, the face plate was off, so that might make a difference as well. I don't know if yours was off and if it should be on when you retry. Also, my model # i DX545MP, is yours the same? Cheers and good luck.
  • Rockum Aug 27, 2007
    I have still not had a chance to get to it, but hopefully this coming week I will give it a try. Im glad that fixed it and I will be trying the same thing when I can get my hands on some tools to disconnect the battery. Thanks much for the info.
    Cheers
SOURCE:
Clarion Marine Problem w Sirius CeNet Unit
When a CD changer or Sirius satellite receiver is added to a system, the source unit’s main wiring harness must be disconnected before the changer and/or satellite receiver’s CeNET cable is connected to the source unit. Otherwise, the source unit will not “recognize” that a CD changer or Sirius satellite receiver has been added.
Apr 09, 2008 | Clarion (NAVSIR) SIRIUS Radio Receiver
One of my customers has a CMD6 with SIR-CL3 Sirius receiver. When powered up the unit displays "SIRIUS NO TUNER" and then shuts off, powers itself up again, repeats display message then shuts...
I am having the exact same problem with my CMD6. The sirius worked fine with my CMD4, but has the same problem with constantly rebooting when I hook it up to the CMD6. Did you find a solution?
Feb 08, 2011 | Clarion CMD6
My sirius reciever in my boat worked fine until this year now it wont work antenna is only two years old and it is a high quality marine antenna could it be the reciever it is hooked to a clarion radio...
Oxidation from humidity could have tarnished a connector somewhere. Make sure all connectors are clean and shiny first. It could be that the receiver is bad. A stereo shop should be able to check that for you easily.
Mar 13, 2010 | Clarion (NAVSIR) SIRIUS Radio Receiver
Trying to set up satellite radio function on my clarion dxz755mc
there is more than 1 channel you can set to on sirius try setting your fm to 108 and set siriuus to same if you go into yor sirius tuner you can use the up and down arrows to tune in the stations
Dec 30, 2009 | Clarion DXZ755MC CD Player
Constantly goes to "linking" whenever I select Sirius. Sirius tells me that means an antenna problem. However, I have tried a new antenna with the same results.
The unit needs to be replaced. solder pins on the PC board of the unit are broken. Clarion has about 100,000 of these units with the same problem. You can find a replacement online for $50 that's been fixed & the problem should not re-occur. Sorry for the bad news. Hope this helps
Jun 02, 2009 | Clarion SIR-CL1 SIRIUS Radio Receiver
Sirius Radio Invalid Channel message
1) Do you have a Sirius account?
2) Have you called Sirius and given the serial number of that receiver?
Those are the first two things you have to do to get a Sirius receiver working. (The original owner could have changed his account to use his new receiver, if he has one.) Go to http://www.sirius.com/install - the "activate" part - for details.
Aug 20, 2008 | Clarion (NAVSIR) SIRIUS Radio Receiver
Clarion Marine XMD3 / SIR-CL1 Sirius Troubleshooting
I had the same problem with invalid channel on all channels ! Had to reset the siriuss receiver by removing power for 15 sec and restoring! that means not just shuting it off but removing all power to the sirius unit not the clarion unit itself and reastablishing power to it turning on the clarion head unit and walah! satelite would recieve ESN and 184 and programing! Hope it works for you after 3 long waiting periods on the phone!
Oct 21, 2007 | Clarion SIR-CL1 SIRIUS Radio Receiver
Clarion (NAVSIR) SIRIUS Radio Receiver Logo
4,392 people viewed this question
Top Clarion Audio Players & Recorders Experts
Larry Tezekjian
Larry Tezekjian
xxxxxx xxx
Robert Rankin
Are you a Clarion Audio Player and Recorder Expert? Answer questions, earn points and help others
