Question about Home
Youth light 2910. LED lights
Youth light laser 2010. Bought online. It doesn't work. Opened it up to find pieces floating. Don't know what they are or if machine is fixable. Everything else looks great
    New Friend:
Bits what have fell of it
Posted on May 07, 2013
  • heather erickson May 07, 2013
    These bits were randomly floating around inside where the circuit board is. Do you know what they are? Or what they were supposed to be attached to?
I just bought an led light set for my new diamondback bike. Which is fine except I don't know how to attach it to the bike the pieces that came with it only attach together. Am I missing something?
If you feel pieces are missing, return the unit and get a new one. Aside from that, you would have to improvise a fastener to attach to the frame or handlebars. 7_16_2013_10_17_55_pm.jpg
Jul 15, 2013 | Cycling
Tip
How to see if your remote control is actually working
For remotes which use an IR connection you can see if they are transmitting using this trick. An IR type of remote will have one or two LED's on the front end. If it doesn't, than it may be an RF type of remote - this tip will not work for those.
Get some electronic device which can view a live image on a screen. A cell phone camera, digital camera, digital video camera, and (I think) even a web-cam will work. If you're using a digital (still) camera, you don't need to take a picture as long as you see a live image on the screen of whatever the camera is pointing at. Take your remote and find the LED on the front end. There may be one or two. (If there's two, one actually isn't an LED, but that's not too important.) Point the front of the remote at the camera (LED's facing the camera), and press buttons. You should see the LED's light up in the live image. While these LED's normally produce light which the human eye can't see, digital image sensors can, and they change this invisible light to light we can see on the screen. (Cool right?) So, if your remote is working then you'll see the LED light up on the display. (To make sure your camera is actually working as I am suggesting here, find a remote which you know does work and try it.)
The LED should light up for every button pressed. If one button doesn't make the LED glow, you may have a bad button - try pressing it firmly. Buttons can wear out. The image of the LED may appear steady or it may pulse or blink on the viewscreen - this is normal.
If the LED doesn't light up, and you know your camera works like this (you've checked a good remote), try new batteries - that solves most problems. Check the battery contacts in the remote - if they're corroded, (white flaky stuff caked on, looks like dried up salt) - you can clean the contacts with a solution of water and baking soda and a Q-Tip. Use a knife to remove any large chunks. Also, some fine sand paper works too. Both the flat contacts and the springs need to be cleaned. Wash any tools (and hands) with soap and water afterwards. Handle corroded batteries as little as possible - or better yet, use gloves.
If you have good batteries and the contacts are clean, and the LED is not lighting up - it's pooched. Try getting a replacement from the manufacturer (call or email/write them), or use a universal remote.
If you've found this tip helpful, please check the box below. =8o)
#Remote #RemoteControl #IRRemote
on Jul 08, 2014 | Televison & Video
Power Supply bad working. Blue led doesn't light.
Hi, I'm having the same problem with one of mine M1 Active 620. Please have you found out characteristics of D5 Zener diode, voltage?
Nov 13, 2012 | Alesis M1-Active-MK2 Powered Studio...
I bought a led light cable lock and I need a code to lock doesn't came with code
go please to www.fitness.manualsonline.com or www.remotecodelist.com
GOd bless you
Jul 17, 2012 | Televison & Video
MY SONY WALKMAN CANNOT BE OPENED, IT LIGHTS UP THEN TURNS OFF IMMEDIATELY
What do you mean "MY SONY WALKMAN CANNOT BE OPENED"? If you mean that you can't get to the battery, then you should look at the charging piece in the MP3. If it wiggles or moves in any way, then there is no way to fix it. I myself had that problem once, and it needs charged, but won't take a charge for some reason. I glued the piece in place with super glue which didn't help, and even put a drop of water on it to see if the electricity needed a material to carry it. That didn't work either. I gave up, as there are no screws, so you can't put it back together. I would suggest getting a new one, getting a new charger, or taking it to the store you bought it at. If that doesn't work, then bring it to RadioShack and ask for help. It's worth a try. Or, as I always add at the end, continue looking on the computer.
Jun 16, 2012 | Sony NWZ-E443 Digital Media Player
I bought my son a 1995 Nissan PU about 3 years ago....from my sister. Ever since I have had it, the brake and tail lights come and go at their leisure. I was told I need to replace the...
Check the ground for your rear lights. It's probably one single ground for all the rear lights, though I don't know that for sure. If it's not a grounding issue, it must be a loose power connection.
Nov 07, 2011 | Cars & Trucks
My car doesn't have a fuse diagram and my hazards and turning signals don't work. I bought fuses but don't know which one to change.
just pull them all out one at a time till you find the blown one .but if all fuses all ok then change the hazard warning light switch as this is the most likely unit to fail and cause these problems
Sep 26, 2011 | 2001 Ford Mustang
Water light is on ,Water tank is full but the light stays on
If the water tank stays full it indicates that the pump cannot function properly.
Before first use, the Sirena pump needs to be 'primed'. This is indicated by the blinking blue 'water' LED. On a new machine (or a refurbished one as in my case), empty the water container first, then
  • remove the plastic water container
  • activate the small spring valve mechanism built into the bottom of the water tank.
    This plastic valve mechanism could initially be hard to depress, because the small metal spring is too strong, or the entire mechanism may be stuck altogether. Exercise this spring and the small valve a few times (ok: 10 times).
  • once the spring-loaded valve moves freely (it becomes easy to depress with your finger), the pump will have no problem activating the spring mechanism and starts sucking water out of the tank:
  • refill with filtered water almost to the top and observe the floating magnet (fill indicator) now in its UP position. You will have to refill the water after a few shots and using steam.
  • Press the ON/OFF button and open the steam knob clockwise all the way until you can hear the pump working and a steady stream of water escapes... onto the floor, or if you're smart, into a small container.
  • Once primed, the pump can operate and in turn, the machine starts heating up.
  • Now you can make your espresso, and even try the steam wand after it shoots out a short stream of water. Once you have steam coming out of the wand, you can start getting serious about making your brew...
I believe that a lot of problems, like failure to heat up, machine doesn't work, etc. are caused by this small spring mechanism being a little hard to operate initially. The Sirena is programmed to operate ONLY if it can extract water out of the tank.
Try it and enjoy the superb cappucino, espresso, etc. -the beautiful Sirena was born in Italy and is a little temperamental, but will be your best friend with a little help in the mechnical department (Think FIAT). By the way: I am a German engineer -no kidding.
Sep 08, 2011 | Saeco Starbucks Sirena Espresso Machine
Home Logo
80 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
