Question about Dynex DX-WOM20 Mouse
Device dy00354 wireless - Dynex DX-WOM20 Mouse
Hi there! I would like to know how to unlock internet button from my HP probook. Its button light is orange and I have no access to the internet. I'll glad you anything you can do for me! ...
Not knowing the model of your unit, I respond with a general answer:
Using the wireless controls
You can control the wireless devices in your computer using these features:
?? Wireless button
?? Wireless Assistant software (select models only)
?? HP Connection Manager software (select models only)
?? Operating system controls
Using the wireless button
The computer has a wireless button, one or more wireless devices, and two wireless lights. All of the
wireless devices on your computer are enabled at the factory, so the wireless light is on (blue) when
you turn on the computer.
The wireless light indicates the overall power state of your wireless devices, not the status of individual
devices. If the wireless light is blue, at least one wireless device is on. If the wireless light is amber, all
wireless devices are off.
Because the wireless devices are enabled at the factory, you can use the wireless button to turn on or
turn off the wireless devices simultaneously. Individual wireless devices can be controlled through
Wireless Assistant software (select models only) or through Computer Setup.
check chap.2, page 22 in this manual:
http://tinyurl.com/3czcyss
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks,
Joe Diaz, Nashville TN.
De Cayey, P.R.!!
May 20, 2011 | Computers & Internet
Hello, im trying to install my wirless printer to my wireless computer and im having some difficulties. for example its asking me to check my wireless LAN access point.. I dont know waht that is? im...
The Canon is trying to connect to a wireless router or wireless access point which is connected to your computer network. Your Sprint 3g device is a wireless broadband device for Internet connection and cannot connect to the Canon using this device.
You need a wireless card that connects to the wireless router or wireless access point.
Otherwise you can connect to your printer using a printer cable.
May 16, 2011 | Canon MP560 All-In-One InkJet Printer
I have a HP pavilion entertainment PC laptop.The wireless button of my laptop has turnedd off and not getting on.Please help me.
hpweb_1-2_minus.gif Wireless device is turned off or disabled The power to the wireless network and Bluetooth devices is controlled by a switch or button on most computers. It is possible to accidentally bump the button and turn off the wireless service. c02230159.jpg On most computers, there is an LED light that glows blue when the wireless device is turned on and enabled, and glows orange when off or disabled. Some newer models use different a different color scheme, see the user guide for more information. To turn on and enable the wireless device, do the following:
  1. To turn on the wireless device, simply move the switch to the on position. On some computers, the switch is actually a touch point on the panel above the keyboard.
  2. To enable the wireless device, right-click the HP Wireless Assistant (disabled) icon c02448899.jpg and select Open Wireless Assistant . Click Turn On . The HP Wireless Assistant (enabled) icon c02448900.jpg will display.
  3. You can also try pressing the fn+ F2 keys simultaneously to enable the wireless device.
Apr 24, 2011 | Computers & Internet
I have sony vaio S. but the wirelees is not working no wireless host shown. how can i fix it?
Selecting the wireless function Follow the steps below to select the wireless function to be activated when you set the WIRELESS switch on your computer to on. Double-click (wireless switch icon) on the Notification area at the bottom right of the desktop.The Wireless Device Switch dialog box appears. Hints The appearance of the wireless switch icon changes depending on the selected wireless function. Point to the wireless switch icon to display the selected wireless function. Alternatively, you can right-click the wireless switch icon and select "show Wireless Device Switch settings" to display the Wireless Device Switch dialog box. Select the desired wireless function from "Wireless LAN" or "Bluetooth Device". Notes 5 GHz Wireless LAN is available on certain models only. You must select at least one wireless function to perform wireless communications. The 2.4 GHz and 5 GHz Wireless LAN functions employ different frequency bandwidths, thus are not compatible with each other. Checking the check box for both "Enable 2.4 GHz Wireless LAN" and "Enable Bluetooth Device" may cause poor communication performance or a connection loss due to electromagnetic interference. Click OK. The message "Setting up the wireless devices. Process may take several minutes. Please wait." appears first, then the Wireless Device Switch dialog box is closed, and finally the dialog box that describes what to do with the icon on the Notification area appears. Note While the message "Setting up the Wireless Devices. Process may take several minutes. Please wait." is displayed, do not: place your computer into power saving mode. turn off Windows or log off from the current user. turn on and off the WIRELESS switch. Confirm the settings and click OK. The dialog box about the icon on the Notification area closes. Hint If you check the "Don't show this dialog in the future" check box, the dialog box will not appear next time you close the Wireless Device Switch dialog. To analyze the network condition You can analyze the network condition if you select either or both of the wireless functions under "Wireless LAN" in step 2 above. Click the "Diagnose" button to start Windows Network Diagnostics. When the network analysis is complete, the result is displayed. If any problems are found, follow the on-screen instructions. Hint Windows Network Diagnostics is the function to identify problems the network has and present solutions to them.
Mar 01, 2011 | Sony Computers & Internet
I cannot connect to the internet wirelessly.
is your driver installed well? try to activated your wireless open your device manager find some wireless device there if you cant find wireless device (wireless lan) than you have to cee is the device installed well on your netbook
Jan 16, 2011 | Acer Aspire One AOA150-1504 Netbook
Where is the wireless button so that I can turn it on?
It is located in the front left of your computer.
Refer to the manual from the link below. Go to page 11 in the manual.
http://h10032.www1.hp.com/ctg/Manual/c00765305.pdf
Jul 25, 2009 | HP Pavilion dv6000z Notebook
How do I switch on wireless on amilo 1505 please?
Check if the wireless device is installed and working properly on your machine.
Go to >> My PC >> properties >> Hardware >> Device Manager >> network devices
Run a wireless network connection (Start >> Control Panel >> Wireless )
Do you have any wireless network running in your home?
If not you will not see any signal from the wireless devices.
(but it is probably instead that you can see all the wireless networks availables on range with your device (eg.:your neighbor)
Oct 05, 2008 | Fujitsu Siemens AMILO Pro V7010 Notebook
Unable to connect to my wireless system with hp pavilion dv6353us
install software for ur plug in wireless then plug in ur wireless ...not until this point will system find and install....then get online and find driver for ur internal wireless ...download and install.....when u remove ur external and restart system will recognise internal as only wireless and configure ...if still have problem ....and ur problem wont be wireless Itll be getting online....then u need to config wireless differently.
let me know
Mar 07, 2008 | HP Pavilion dv6000z Notebook
Wireless connection no longer works after vista upgrade
HP uses "branded" wireless modules,which means it's got to be HP or it doesn't get to play.
Does device manager see the wireless device? I've had similar situations with the 8000s. Always the driver or the wireless utility was the problem. Try letting windows manage the device, or if you already are, disable that and use the devices utiliy to manage it.
BTW, most systems consider BT as wireless.
Good luck, hope that helps
Nov 25, 2007 | HP Pavilion zd8000 Notebook
Dynex DX-WOM20 Mouse Logo
104 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
