Question about Canon BJC S450 InkJet Printer
Prints just the top 3 inches (in color) of web and email pages
New ink cartridges installed, all maintenance checks performed, but printer will only print the top 3 inches or so of any page - web page or email page. Help!
    Sergeant:
  • 390 Answers
This range of canons are notorious for the paper sensors to go ie malfunction. It may be on the way out, but other issues can cause this type of print error. You need to eliminate all possibilities. First is to trully see if the printer is not having driver errors etc caused by spyware. Do a full spyware and virus check with safe software. Housecall is a good free service online and eliminates what it finds. Next, check printer drivers, go to start menu, control panel, perf and maintenance, system, hardware, scroll down to printer, check for errors, etc. It will tell you under devices if drivers are ok. If this is the problem, it can be fixed with new driver updates from canon. A good place to start if not the problem, is next eliminate a built up residue on print head. This range of canons also clog really easily. I use cotton buds and proper cleaning solution, and clean the area thoroughly where cartridge goes in (printhead)the printers own cleaning system cannot overcome this type of clog itself. Now try printing again. Good luck
Posted on Aug 11, 2007
SOURCE:
Factory reset
This type of problem is typically caused by one of the ink cartridges which is suffering from marginal electrical performance - either the HP92 (black) or HP93 (color) ink cartridge.
Can you perform the 'Self Test Page' test (see below). If this test is successful then this demonstrates the printer is 'generally operational', but if normal printing is still not permitted then either the HP92 (black) or HP93 (color) ink cartridge is likely electrically damaged and may need to be replaced*.
Perform Self Test Page:
1. Press and hold the CANCEL button.
2. Press the COLOR COPY button. Release both buttons.
3. The self test prints. The printed pattern will verify printer is generally functional. Inspect color bars to verify proper nozzle/jetting health.
-- Inspect printed nozzle stair step patterns - verify all ink nozzles are properly firing. Generally, if the Self Test Page prints ok then the printer is functioning correctly and the problem is with the ink cartridges - replace the suspect ink cartridge and retest. Refer to 2nd video procedure at the following link on how to read the Self Test page test (NOTE: HP74/75 cartridges are electrically identical to the HP92 thru 98 cartridges).
http://inkjet411.com/?page_id=579
*Many cartridges eventually do encounter problems or failures. Severe cartridge errors are primarily caused by an electrical breakdown at the cartridge's nozzle plate. Ink *********** or corrosion into the nozzle plate will cause a failure of the tiny micro-electronics resulting in a variety of different error messages being displayed - see picture at bottom of this page: http://inkjet411.com/?page_id=1216
It is suggested to install a new HP92 and/or HP93 ink cartridge in it to resolve the current issue.
May 02, 2013 | HP PhotoSmart C4180 All-in-One Color...
How do you install ink of epson l110
Follow the given steps:
Step 1
Turn on your printer and open the hatch or cover where the ink is stored. Different printer models are configured differently and may take different types of ink cartridges. Check your specific model for exact instructions (see Resources for Epson support site).
Step 2
Remove any old cartridges by gently pulling up and away from the printer.
Step 3
Remove the tape from the new ink cartridge covering the contacts. Avoid touching the contacts with your hands or clothing as this may damage the cartridge.
Step 4
Install the cartridge in the appropriate slot by pushing gently down and towards the printer until it snaps in. Some printer models have a black cartridge and several color cartridges. Some models only have one black cartridge and one color cartridge. Be careful not to mix them.
Step 5
Align your new cartridge by following the printer's instructions. Test for proper installation by printing a test page. Navigate to "Control Panel-->Printers-->Epson-->Properties-->Maintenance-->Print Test Page." If the page does not print correctly, consult Epson support for help.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Feb 06, 2013 | Epson Office Equipment & Supplies
The printer won't print out any of the reds in my images, even when the colour cartridge has just been replaced, and prints any red areas in yellow instead.
Hi is this a new printer? If you've just installed a new color ink, it would prompt you to align the cartridge or print some test page.. If the RED doesnt show on the test page, then try to perform maintenance on it.. Like Clean cartridge or clean print head.. it may be clogged.. if it still does this, try changing the color ink.. If you color ink is from a stock, it may have dried up.. if you bought it just days ago, ask for a replacement.. If all has been done, it maybe the printer itself..
Hope this helps.. :D
Oct 07, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
PRINTER COLOR PROBLEMS
o.k. I can give you a few tips that may be of assistance.
you need to run a printer alignment page like you do when you put in new cartridges.
unplug your printer plug it back in.
open door and take out print ink cartridges.
put them back in and then close the door.
It should now prompt you to do a test alignment page.
Also, Another thing to try is to hit file, top left of page, hit print, click properties. color tab.
make sure you are printing high quality on chose different color management options.
FINALLY TRY THIS:
When Printing Becomes Faint or Colors are Incorrect
When printing becomes faint or colors are incorrect, even if ink remains in
the ink tanks, the print head nozzles are probably clogged. Follow the
procedures below to maintain the print head.
Important Before maintaining the print head, check the following;
􀁺 Open the front cover and make sure that the ink tank
contains ink. If it is out of ink, replace it.
􀁺 Ensure that all the orange tape of the ink tank has been
peeled off.
􀁺 Press "PUSH" on the ink tank and ensure that the ink tank
is installed securely.
􀁺 Increase the Print Quality setting in the printer driver
Printing the Nozzle Check Pattern
Print the nozzle check pattern to determine whether the ink ejects properly from the print
head nozzles, and to verify print head alignment. Use this function when printed results are
blurred or the color is incorrect.
1 With the printer on, load a sheet of Letter-sized paper in the printer.
2 Open the Printer Properties dialog box.
See "Opening the Printer Properties Dialog Box Directly from the Start Menu" on
page 25.
3 Print the Nozzle Check Pattern.
(3) When the confirmation message is displayed, click OK.
When the confirmation message is displayed after the nozzle check pattern has
been printed, click OK.
See "Examining the Nozzle Check Pattern" on page 52.
Note Nozzle check pattern printing can be executed also from the printer
itself. With the printer on, load a sheet of Letter-sized paper in the
printer. Hold the RESUME/CANCEL button until the POWER lamp flashes
Print Head Cleaning
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print
head consumes ink, so perform print head cleaning only when necessary.
The print head can be cleaned also from the printer itself. With the printer on, load a sheet
of Letter-sized paper in the printer. Hold the RESUME/CANCEL button until the POWER lamp
flashes once.
1 Ensure that the printer is on.
page 25.
3 Start Print Head Cleaning.
(1) Click the Maintenance tab.
(2) Click Cleaning.
(3) Select the print head to be
cleaned.
(4) Click Execute.
Print Head Deep Cleaning
If print quality does not improve by standard print head cleaning, try performing print head
deep cleaning, which is a more powerful process. Print head deep cleaning consumes ink,
so perform this procedure only when necessary.
page 25.
3 Start Print Head Deep Cleaning.
(2) Click Deep Cleaning.
deeply cleaned.
(4) Click Execute
Aligning the Print Head
This operation must be carried out when using the printer for the first time. Aligning the
print head positions allows you to print without shifts in the color registration.
Print head alignment is performed either automatically or manually. This section deals with
automatic print head alignment only.
page 25.
3 Print the pattern.
(2) Click Print Head Alignment.
(3) Check that paper is loaded in the
printer and click OK. If a message
warning you not to perform other
operations appears, click OK.
It takes about one minute to start
___________________________________________________
this covers everything you should solve the problem with my advice.
please give me a good rating for my time and effort! Thank You
Mar 28, 2010 | Canon i860 InkJet Photo Printer
THE INSTALL COLOR INK NOTICE KEEPS STAYING ON. EVEN AFTER I KEEP INSTALLING DIFFERENT CARTRIDGES
Go into printer maintenance and chose the Canon printer (assuming you have multiple printers). Once you chose the printer you can then perform maintenance and do cleaning and priming. Essentially when you click install new cartridge the system will essentially prime the printer so that when you print a document it will not have to prime itself. It should prime automatically once you close the lid and install the new cartridge.
Feb 08, 2010 | Canon PIXMA iP90 Mobile Printer
I put a new ink cartrige and printer prints low coulour tone.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 26, 2009 | Lexmark Color JetPrinter 5700 InkJet
Color Cartridge Missing
Please follow the steps given below:
1 Turn the printer/All-In-One off and unplug the power cable from the outlet.
2 Open the printer/All-In-One lid so that the cartridge carrier can be accessed.
3 Remove the print cartridges.
4 Using a dry, clean cloth wipe the carrier contacts gently from top to bottom.
5 Repeat Step 4 for the other cartridge slot (if applicable).
6 Reinsert the cartridges, slide the cartridge carrier to its original position, and close the printer/All-In-One lid.
7 Plug the printer/All-In-One back into the power outlet and turn it back on.
Next, try to perform a Self test:
1 Press the Copy button on the operator panel once (this button is located under Mode).
2 Press the Options button ten times until Maintenance appears on the display.
3 Press the left arrow button (-) once. The display should now read Self Test Page.
4 Press Select. The printer will print a hardware test page.
Apr 04, 2009 | Lexmark X6170 All-In-One InkJet Printer
Brought 2 new black color inks for lexmark x8350, perform alignment several times and failed, when i set to print only the color will print where as the black color will not print clearly if it prints it...
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please try to print the self test page.
Begin by disconnecting the power supply from the wall (not the back of the printer) for at
least "30 seconds." This is essential. Then plug the printer back in and follow these
steps:
1. Press the "Copy" button.
2. Press the "Menu" button.
3. Press the down arrow button once or until the screen displays "Maintenance."
4. Press the check mark button to select the "Maintenance" menu.
5. Press the down arrow button three times until the screen displays "Print Test Page."
6. Press the check mark button to select this. The Self-Test will start printing.
The self-test should at least print out a set of either black or color bars, if not both
(if you have a printer with both color and black installed simultaneously.) Should this
test fail, try it again without cartridges installed. If the self-test still fails to take
paper in and make sounds like the carrier is moving across the paper, this is a hardware
issue, and the printer will require service. If the self-test completes without any
cartridges installed, run the self-test again with the color cartridge installed. (If you
have both black and color cartridges, after this test, run the test again with just the
black cartridge installed.) If you find that either cartridge causes the self-test to fail
A technique to improve print quality is to try and clean the cartridge nozzles. You can clean the cartridge using the following steps given below:
Click on "Start," go to "All Programs," and down to the Lexmark. Click on the "Solution Center." Next, click on the "Maintenance" tab. Select "Clean to fix horizontal strips." This will produce a printed page.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean to fix horizontal strips" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution Center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge (or cartridges) from the printer.
9. Repeat the "Clean to fix horizontal strips" one more time. If this fails to address the problem, the entire procedure may need repeating.
If you have replaced your ink cartridge with a new one and are continuing to experience difficulties with print quality, please try cleaning and wicking the ink cartridge. If this fails to resolve the issue, the maintenance station may have an excess build-up of ink.
The maintenance station is located inside the printer on the right hand side. This is the same area where the cartridges sit when in the "idle" position. To access the maintenance station: Unplug everything from the back of your printer, open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fanbelt. On some models, the cartridge access will be very small, but the belt should still be visible. Take the top part of the belt and move it gently to the right.
***Note*** please do not pull outwards on the belt. The cartridges should come over towards the left side of the printer. The maintenance station will be on the right side on the bottom of the printer behind the fixed cover. Clean the area with several damp cotton swabs or damp papertowels until the build up of ink is removed.
Once the maintenance station has been cleaned you should "wick" the cartridges. Remove the cartridge from the printer. Get a clean damp paper towel and lay it on a flat surface. Set the ink cartridge right side up, with the ink nozzles touching the towel and hold in this position for about 15 seconds. Then wipe the nozzles across in one direction only (left to right). Repeat this process, each time using a clean spot on the paper towel, until it looks clean. Dab the cartridge on a dry towel to make sure that the ink is flowing.
After you have wicked the cartridges place them back into the printer, securing them into place. Plug the power back into the printer. Close the cover and click on "Old Cartridge Installed" on the "Control Program" screen. Once the printer has reset, run the "Clean Print Nozzles" page twice. This should resolve the issue.
your's tech expert
Jeeth
Feb 19, 2009 | Lexmark X8350 All-In-One InkJet Printer
Help
Me is Vikram Kumar Thumu, I have seen your message on the  issue related to the HP Deskjet 5150 Printer. I would like to provide my suggestions on this issue.
The issue could be happen due to following below reasons:
1. If you are using wrong ink cartridge for the Printer.
2. If you are using a refilled ink cartridge
3. If there is an issue with fault with ink cartridge or an issue with ink cartridge slot in the Printer.
4. If there is an issue with Hardware malfunction of Printer.
Well, to resolve the issue I recommend you to try below solutions.
Note **: Your Printer supports below ink cartridges:
Cartridge Part number Black HP 56 (C6656A) Tri-color HP 57 (C6657A) Photo cartridge (optional) HP 58 (C6658A)
Check whether you can installed correct ink cartridges for the Printer or not.
Solution 1: To Hard Reset Printer once.
Make sure that Printer is disconnected from the computer.
1. Turn ON the Printer.
2. Raise the top access door of Printer. The carriage assembly should move    towards center of the printer.
   Note: for some printers carriage will not move to center.
3. Remove both ink cartridges from Printer.
4. Power OFF printer by pressing the power button of the Printer.
5. Disconnect the power cord from wall outlet and Printer cable (USB or Parallel) from the back of the Printer.
6. Let the Printer remain disconnected for at least 60 seconds.
7. Reconnect power cord and Printer cable (USB or parallel) at back of end Printer.
8. Turn ON the printer.
9. Reinstall both ink cartridges into Printer, make sure that they lock into position and installed in correct ink cartridge slots.
10. Close the top access door firmly.
once if you are done with steps, check the issue. If the issue still persists then please go ahead with next solution.
Solution 2: To Clean the ink cartridges and Cartridge slot in the Printer
Please open below web link.
Link is:
Once if you have opened the web link, please perform the steps that are mentioned in the web page for cleaning ink cartridges and also steps for cleaning ink cartridge slot assembly in the Printer.
I hope that this should resolve the issue. However, if the issue still persists then please go ahead with next solution 3
Solution 3: Testing the ink cartridges of the Printer
To isolate the issue by testing the Printer Hardware functionality with " Reserve mode printing " ( this is also called as 'Back up mode'). This is referred as using the Printer with only single ink cartridge. Your Printer model supports for this feature.
Steps are :
1. Open top access cover of Printer and remove the Black ink cartridge from Printer ,make sure that Printer is installed with Color ink cartridge only . Then close the top access cover firmly. Please turn off Printer and Wait for 30 seconds and then turn ON Printer. Check the status of blinking lights on the Printer. If you do not see any blinking lights on the Printer front panel, then cartridge is fine. We can now go ahead with testing Cartridge functionality along with Hardware test of Printer.
Please do these below steps to test Cartridge and hardware of Printer:
1. Turn the printer on.
2. Press and hold the POWER button until step 4.
3. Press the RESUME button four times.
4. Release the POWER button.
This should print a self test page. If you see any information printed on the page, then it confirm that Printer and cartridge is fine else if there is no information printed on the page then it confirms that Cartidge is Out of ink.
Note: you may receive a error code on the test page, please do not worry about that.
Please do below steps similarly to check the issue with Color ink cartridge..
Open top access cover of Printer and remove the Color ink cartridge from Printer ,make sure that Printer is installed with Black ink cartridge only . Then close the top access cover firmly. Please turn off Printer and Wait for 30 seconds and then turn ON Printer. Check the status of blinking lights on the Printer. If you do not see any blinking lights on the Printer front panel, then cartridge is fine. We can now go ahead with testing Cartridge functionality along with Hardware test of Printer.
I hope this should resolve the issue. If the issue still persists then you may need to service the Printer once.
If you any issues related to the Printer further you can mail me at [email protected]. I will be glad to help you.
Oct 03, 2007 | HP DeskJet 5150 InkJet Printer
Prints only the top 3 inches or so of a web or email page
This is a beginning to be a really common problem with this type of Canon. I had one that did this too,It sounds like your printheads or rollers are dirty and clogged. You need to thoroughly clean the area where the cartidges sit in (printheads) new cartridges and all the allignments in the world will not resolve clogs, and it will not be sufficient to just rely on the canons own cleaning, you have to manually do it with cleaning solution and cotton buds (q-tips)
Aug 11, 2007 | Canon BJC S450 InkJet Printer
Canon BJC S450 InkJet Printer Logo
Clive
Clive
old marine
old marine
Ekse
