Question about Valor ITS-701W Car DVD Player
Volume knob dont work
Volume knob does not work
Volume control keys on my jbl creature 3 speakers are not working what to do
If you remove the knob and Put a very small amount of WD40 down at the base this can help clean and lubricate the Knob inside. This sometimes cures the problem. If not the volume knob will need to be replaced i included a link to a page that shows The knob and it is just 2 wires. The volume knob can be picked up at a radio shack.
Sep 29, 2014 | JBL Creature III 2 Speakers
Tone knob and switch info
the switch, has three positions. Typically forward or up will be your neck (or rythm) pick ups, only and will work with one volume knob(usually top right as your looking at guitar), and one tone knob ( top left as your looking at the guitar). when the switch is in the far right or all the way down position, that will be the saddle (or lead) pick-ups. And that works with only one volume knob(bottom right as your looking at the guitar) and the corresponding tone knob. when the switch is in the middle position, botjh volume knobs work and both tone knobs work. You've gotta kinda play around with them to find whatever sound yopur looking for. and tone knobs are very subtle in their changes. good luck
Aug 26, 2014 | Epiphone Sheraton II Guitar Electric...
Tuner doesn't work
Turn the main (volume) knob all the way until volume reads 00, leave the button (volume) pressed until the radio beeps - be patient it takes a while - after this turn the knob all the way or until you reach an acceptable volume limit, push the knob again until beep then turn radio off.
Mar 29, 2014 | Boston Acoustics Horizon Solo Clock Radio
How to set digital clock on ix35 Hyundai highlander
Turn the radio on.
Hold down the volume knob for 3 seconds.
The display will come up Volume Setting
Rotate the volume know clockwise until the display switches to time setting.
Push the volume knob.
Rotate the volume knob to select the hour
Push the knob
Rotate the volume knob to select the minute.
Push the knob.
Done.
Nov 30, 2010 | Car Audio & Video
Deneon PMA-250 amplifier -Volume knob not working correctly
Well, it seems you have your finger on the source of the problem. If accessible, try some tuner cleaner inside the potentiometer.
Mar 05, 2010 | Audio Players & Recorders
I am having problems with the volume knob. The
That is a dirty pot switch.. The volume adjusting pot gets dirty.. Two things to try..
1.) With the unit off - spinn the volume min to max many many times at a rapid pace.. This sometimes will displace the debris in the pot..
If that does not work --
2.) Get some "tuner cleaner" in a spray can.. At Radio Shack or a similar store.. Lay the radio on its back so the volume knob is facing up.. Pull the knob off carefully.. Use short controlled bursts of the spray.. A few sprays and spin the knob min to max several times and repeat..
Good luck..
PLease dont forget to rate for your free question..
Aug 20, 2009 | Lasonic TRC-931 Cassette Boombox
The volume not does not work on the infinity radio. I can control volume from the steering wheel but not the knob. Is this normal? Can it be fixed?
dear friend-the volume on the steering works from the back of the radio and the knob from the front,they work seperate but both can be used,so the knob on your radio is not working.
Jul 07, 2009 | 2009 Hyundai Sonata
Logitech S500 Volume Knob Broken
The simplest thing to try is some compressed air directed to the knob. This would clear out any dust or dirt that may be obstructing the knob. I am not sure what you mean by power cut so I am shooting in the dark here. If you mean a power surge that caused the volume to quit working then I would suggest an external volume control such as http://www.amazon.com/Koss-155954-VC20-Volume-Control/dp/B00001P4XH/ref=pd_bbs_2/002-2257004-6895258?ie=UTF8&s=electronics&qid=1194009359&sr=8-2
Or
http://www.radioshack.com/product/index.jsp?productId=2102975&cp=&sr=1&origkw=volume+control&kw=volume+control&parentPage=search
Dec 18, 2008 | Logitech X-540 Computer Speakers
It has lost partially the mechanical connection between the volume control knob and the volume control pot.
The knob could be "stripped". A drop of a slightly resilient glue should do the trick. Do not use rigid adhesives, as this will prevent future service to this area of your receiver....accordianman
Oct 31, 2007 | Yamaha RX-V630 Receiver
Valor ITS-701W Car DVD Player Logo
18 people viewed this question
Top Valor Car Audio & Video Experts
David Payne
David Payne
steve morris
steve morris
Tom Chichester
Are you a Valor Car Audio and Video Expert? Answer questions, earn points and help others
