Question about Health & Beauty
Desperately Need wiring diagram for an ATE501 scooter
I have power to only the motor. None of the lights,blinkers, horn, etc work. I've changed the converter and the brain controller, I've checked the breaker, it's fine. If anyone has a diagram for this scooter, or can offer suggestions it would be greatly appreciated......Thx,Keith
SOURCE: Need a wiring diagram for Pride Rally Electric Scooter
I can tell you how i fixed it for $19.95
Posted on Jun 22, 2009
gewiz
  • 1263 Answers
SOURCE: fischer and paykel scooter model sc231ala not charging
hi, if you got a meter , check the voltage o nthe charger socket , it should be about 24v,
that is the left and right pin, not the middle pin that is slighly lower,
if the voltages are going up and down goto the batteries first and chec k the connections on the terminal, tight ?, check them back the the charging socket, normally the charging socket is wires indirectly to the batteries.
Regards
GeWiz.
Posted on Jan 15, 2010
  • 23 Answers
SOURCE: electric mobility scooter says charge is full but won't run
This sounds she has tripped her circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead.
Looks like you have the same scooter as mine, it should be a little white button on the back of the base. If you follow this link, it will give you a pdf version of the older model pride victory manual, (Mine is a three, they are up to about 10!) See fig. 8 on page 20 and 'Circuit Breaker' on page 21. Also, Page 33 has the troubleshooting info. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Victory%20Owner's%20Manual.pdf
Posted on May 06, 2010
  • 177 Answers
SOURCE: Invacare Zoom 220 mobility scooter will not run
Hi. When the machine is on, does it display a flashing light or LED on the display for a fault code? Is the free-wheel lever switch operating correctly?
You might have a sticky brush in the motor. Take the brushes out and check their condition. If the brush caps are not tight enough then the current arc's on to the side of the brush, and it jams in the brush holder.
Check the resistance through the motor before touching the brushes. Check motor and battery connectors for continuity and any sign of heat or melted plastic. Check operation and resistance of the brake unit. Most controllers in mobility scooters are quite reliable, so always eliminate all other possibilities before looking at the controller. Good luck. Neil.
Posted on May 29, 2010
HoverTech
  • 232 Answers
SOURCE: scooter has sat for long time inside. replaced
Unfortunatly, your batteries need to be replaced.
The batteries contain a gel that needs to have current run through it on a regular basis (at least 8 hours once a week) or it will solidify. If you attach the charger, what will most likely happen is the green light will either stay green or go to green after a very short time. The charger will indicate the batteries are full, but instead of being full of pwer, they are full of crud. Your warranty will most likely not cover replacment as this is due to customer neglect, but your insurance may still cover the replacement if you can wait for the process to go through. Otherwise, you will need to replace the batteries on your own. There is enough power to turn on the lights and honk the horn, but not enough to get the motors to work. Make sure all of your connections are good and the fuses are intact and that your manual brake release or freewheel lever is in the drive position.
Posted on Oct 25, 2010
Wirng diagram for a sc50 sonic pride scooter power switch, horn,horn button,power meter,etc.
Bad boy (or girl of course)! Should have noted everything BEFORE taking it apart. But then you now know that and probably did before .... Oh well, we've all done it... Once. I have a Pride scooter, but not this one. MAYBE someone with a sc50 Sonic will be kind and post a photograph of the underside of their control panel while still wired?? This would help our friend a lot.
Sadly Pride Mobility aren't known for useful things like wiring diagrams or meaningful owner's manuals.
Jun 22, 2014 | Pride Sonic 3 Wheel Portable Scooter
Taotao ATE 501 electric scooter no power to the motor
Sounds like the Hall wire are mixed up. Try reconecting the hall wires to the correct wire and it will run excellent. I have the same scooter and that is what was wrong.
May 28, 2012 | Health & Beauty
Gogo elite pride scooter horn won't stop
Peggy I've just solved mine as well there was a touching wire on the horn! So try that. You have to take some screws off the front panel
Jan 21, 2012 | Pride Go Go Elite Traveller Plus HD 4...
Pontiac sunfire interior lights, horn and blinkers do not work
They are talking about the body control module, but I'm not sure they are right. The horn does not need the bcm to work. See diagram below. The horn relay is energized by the horn switch on the steering wheel. The switch also signals the bcm, but that is not used to power the horn.
The turn signal does not use the bcm at all. The problem there may be the switch or the wire. See diagram below.
The instrument lights DO REQUIRE the bcm, but can be rewired to bypass the bcm. The gray wire from the bcm in the diagram below powers the instrument lights. You can cut the gray wire and splice it to the brown wire from the multi function switch. Find the brown wire coming out the bottom of the steering column, skin some insulation off the wire and verify it has 12 volts when the parking lights are on. Do not cut the brown wire--just attach the gray wire to it. You will not be able to dim the lights, but they will come on.
Aug 07, 2017 | 2005 Pontiac Sunfire
My horn quit working on my 2004 hyundai sonata. everything else seems to be working . think I checked every fuse i could find, but none are marked horn.
Go to www.hmaservice.com and register your vehicle by VIN #.. you'll then have access to wiring diagrams, shop manuals, service bulletins, campaigns, illustrations and procedures, etc.
The horn fuse in in the fuse/relay box under the engine hood along with the horn relay.
Sep 05, 2011 | Hyundai Motor 2004 Sonata
It starts and runs perfect but no headlight horn
first... check to make sure you don't have blown fuse.. using an electrical tester also, pierce the wire going into the units(if testing blinkers.. horn.. etc.. make sure you actually turn the blinker or horn on etc) this will tell you if you're getting power to them.. if no power trace wire back to connectors with the tester, checking connections etc... (you can get the electrical tester for about $5, clips onto battery and has small light that turns on when it's getting current to where you pierce the wires)
Sep 02, 2009 | kawasaki Full Suspension Mountain Bike Men
Need a wiring schematic for a rascal scooter
hooperimports.com/showpages.asp?pid=1013
they have wiring diagrams and information on how to wire chinese import engines and for more info contact http://tinyurl.com/m7ghqz
Jun 15, 2009 | Razor E100 Electric Scooters Red
I need a schematic for the x-treme scooter
Check the batteries, they need at least 12+volts to run scooter. Blinker may be burned out or the wire came loose. If batteries are charged Two things That could be wrong are: Twist throttle is NO Good, Or the controller is BAD. You need a voltage tester, (Disconnect the Wiring Harnesses) and check voltages coming out of the controller(the silver BOX with lots of wires) and see if it is sending voltage to the twist throttle. Controller wires to the Twist throttle should read 4-5 volts.
(Make Sure You Unplugged That Wiring Harness) There is 4-6 wires in that Wiring Harness then find + and - test them for voltage from that Controller box wiring harness. If You get a positive reading out of that Controller wiring harness then the Twist Throttle thing is bad. If you get NO READING out of that Controller Wiring Harness Then if is BAD. Normally it will be the dead batteries or the Twist Throttle that go bad. Batteries are expensive, Twist Throttle Cheap. Good LUCK
Apr 03, 2009 | Electric X Treme X 360 Scooter
Health & Beauty Logo
37 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
