Question about Samsung SCX 4521F All-In-One Laser Printer
How to install scan - Samsung SCX 4521F All-In-One Laser Printer
Try to install it from the original CD which came along with the printer or you can search it on Samsung home page click detect my device.
which OS you are using so we can come up with genuine solution.
Posted on May 07, 2013
I want to scan documents and save them in a pdf file format, but my scanner does not seem to offer that option.
Do you have the full software installed? Is Adobe Reader installed? (Install it if it isn't on the computer.) If you have the HP Solution Center (Windows) installed, launch the program. Then choose Scan Document. Cancel the scan and choose Settings. Click on Scan Settings and then Document Settings. You should be able to find the Save as PDF option there. Then make sure check the box for checking settings before scanning and save your new settings. Click on the Home button and scan your document.
If you choose Scan Picture, you will not get the Save as PDF option. If you are launching the scans from the all-in-one, you may need to adjust the scan button defaults elsewhere in the solution center. (The software you choose as a scan to destination may limit the available file types in the HP scan software.)
If you do not have the HP full software installed, unplug your data cable (if USB) and uninstall the driver that is currently installed. Go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=1119598& and select your OS version. Click Next. Expand the section marked Driver and choose the full software. Download and install the software and replace the data cable when prompted to do so.
I hope this helps.
Oct 11, 2011 | HP Officejet 6310 All-In-One InkJet...
Sorry my scaner not working but printer will be working please tell me whats wrong
  1. The firewall must allow the following traffic.
    • TCP on ports 9400 and 9401
    • UDP on port 6000
  2. Make sure Scan Manager is configured for the correct IP address of the printer. If Scan Manager will not launch from SmartPanel and it does not show up in Control Panel, check <WindowsDirectory>\twain_32\Samsung. Without Scan Manager installed the printer will not be able to scan to PC.
To use Scan Manager you will need to have installed and configured the following items:
  • Installed the Print Driver, including the Smart Panel application
  • Installed the Scan Driver, including the Scan Manager application
  • Have an active connection between the Printer and PC
Important: If you don't have these items in place, stop now and perform the installation.
To scan to the PC using Scan Manager, follow these steps:
  1. Right click Smart Panel in the task bar, and then select Scan Manager. (Scan Manager Admin dialog appears)
  2. namo_fileview.jsp?type=nfs&pid=decisiontree&did=151998&cid=bdbe6a5u2kt1@namo.co.kr&sep=%7c
  1. Select the Printer you want to use, and then click Quick Scan. (Quick Scan dialog appears)
  2. namo_fileview.jsp?type=nfs&pid=decisiontree&did=151998&cid=pdq8czuzqk7f@namo.co.kr&sep=%7c
  1. Once the Quick Scan dialog appears set the following parameters:
    • Save Location - To change the default location click the Folder Icon to Browse for Folder.
    • File Name - The default file name is the date and time the scan is performed. To change the File Name, select the File Name field.
    • File Format - The file type selected will be the default file type for each consecutive scan. Select from the following formats. (TIFF, PDF, BMP, and JPG)
    namo_fileview.jsp?type=nfs&pid=decisiontree&did=151998&cid=q0imt82cnhs9@namo.co.kr&sep=%7c
  1. After entering the previous information, click OK. (Scan Manager appears)
  2. namo_fileview.jsp?type=nfs&pid=decisiontree&did=151998&cid=1oy6sc87xa6m@namo.co.kr&sep=%7c
  1. Click Scan to scan the document to the PC.
  2. namo_fileview.jsp?type=nfs&pid=decisiontree&did=151998&cid=45q4kejs8a31@namo.co.kr&sep=%7c
For additional information about Scan Managers' features and settings, click the question mark icon (?) at the top of the application window.
Dec 23, 2010 | Samsung SCX 4521F All-In-One Laser Printer
How do I scan to the computer?
The exact steps to scan will depend on what software you're using. Windows itself has a "Scanner and Camera Wizard" that you can use. Most scanners come with software that gets installed along with the necessary drivers when you run the installation CD. (You do have a properly installed scanner connected, right?)
In general, the steps in scanning are:
  1. Place the item to be scanned on the scanner.
  2. Start the scan software.
  3. Do a preview scan.
  4. Select any scanning options and the scan area as applicable.
  5. Scan the item.
  6. Tell the software to save the image if it's not automatically saved for you.
The fine details will vary, but that's basically all there is to scanning.
Nov 28, 2010 | Computers & Internet
I'm trying to scan a picture to my computer,but can't get it to work
The only way I got my Lexmark to scan, was to install the CD that came with it. It installs a program called "Lexmark Imaging Studio". That's where the scan will be transferred to from the printer.
To scan: Press the Scan Mode button, and then the check mark in the middle of the buttons. Then to activate the scan, press Start Color or Start Black to start the scan. With the Imaging Program installed, it will automatically come up and display the scan, where you can scan more or save or print the scan. I have the X4530 Lexmark all-in-one, but the program should be the same, or similar. Good luck, hope this helps.
Apr 18, 2010 | Lexmark X4650 InkJet Printer
Attempt to scan, screen states
This error occurs because the HP scanner can not communicate with your computer and thus won't scan. In most cases this is simply because you don't have all of the necessary drivers installed.
  1. Insert the software CD into your CD ROM drive. The software installer should automatically start
  2. Install the software and restart your computer when prompted
  3. Try to Scan using the Scan To or Start Scan buttons on your printer
Jan 13, 2010 | Computers & Internet
How do i scan multiple pages
Please perform the steps given below to scan multiple pages to a single PDF file.
NOTE: Before performing the steps please make sure that Adobe Reader is installed on your computer. If not installed then goto www.adobe.com and install Adobe Reader.
  1. Open HP Solution Center.
  2. Click on Settings.
  3. Click on Scan Settings.
  4. Click on Scan Preferences and Select the option 'Prompt for additional scans when preview is turned off'.
  5. Click on OK to apply changes.
  6. Now Click on Home and click on scan Document
  7. Select Document to File under scan shortcuts.
  8. Uncheck the option Preview Scan at right bottom of the scan window.
  9. Now Click on scan to scan document.
  10. When prompted for additional scan place the another document on scanner glass or ADF and Click on Scan.
  11. After scanning is complete Click on Finish to save the scanned document
  12. To Locate the scanned document (PDF) goto My Documents folder and Open My scans folder.
Oct 12, 2009 | HP Officejet 6500 Wireless All-in-One...
Scan drivers
  1. go to My Computer
  2. if you have already installed it, their should be a scan icon located their.
  3. put your hard copy on the scanner then double click on the icon to scan.
  4. a window will pop showing progress of scan.
Oct 05, 2009 | Canon Pixma MP500 All-In-One InkJet...
Dell AIO 942 does not scan
I think scanning softwaere was not installed in your computer. so install scanning software. then the scanning will work properly. Pl give feedback
Aug 23, 2009 | Dell 942 All-In-One InkJet Printer
What is the difference between direct scanning and scanning through software (after installing driver)
Scanning through software enables you to crop and adjust settings before scanning.
Apr 28, 2009 | Office Equipment & Supplies
Samsung SCX 4521F All-In-One Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
