Question about Miele 36 in. KM342 Gas Cooktop
Uneven flame adjust
How do i change the flame strength
It takes several minutes for the igniter to light the GE cooktop burners.
Mike, do the flames look to be normal size once they do light or are they very small? You may have a bad regulator. The regulator is used to lower the incoming pressure to a safe level to prevent excessive flame size. It sounds as though the regulator is not working properly. However, if the flames are small or uneven levels, check the orifices directly below the caps or on the burner valves for any obstruction such as spillage or cleaner residues. You can replace the regulator with any brand that has a 1/2" in/out pipe thread. Most are available at a large hardware store.
Feb 01, 2016 | GE Cooktops
How to adjust flame on Westinghouse freestyle gas oven
The flame is regulated by the thermostat you don't say if it's too high or too low. Suggest you buy an oven thermometer available for a few dollars at most homeware shops, compare the temperatures then you will see if the thermostat is working or not.
Apr 22, 2014 | Cooktops
I have a new gas hob which is making the bottom of my pans black like soot?
You must have an improper air/gas ratio. To adjust the shutters you simply open or close them a hair till you get a beautiful blue flame. Improper flame is yellow, good flame is blue. 9916a1c.jpgThis gas conversion training manual shows where to adjust
Apr 22, 2010 | Cooktops
Flame burns too high t0 simmer
if you look closely, down the center of the knob ther should be an adjustment screw to lowert he flame
Jan 26, 2009 | Amana AKS3040 Gas Cooktop
Side burner on Jennaire grill
Hello
The soot stains come from the air mixture, that will show too much yellow flame tips, just adjust the air intake, too have an idea how much to adjust it, and also it wouldn't hurt to clean the flames holes by sticking a pin. Alos make sure you have the right fittings converters. It's the grill LP Gas or Natural?
Hope this help
Eddie Rentas
Tupper Lake NY
Aug 01, 2008 | DCS Double 30'' Grill Cart Side Burners in...
GE Stove
check all holes on burner make sure all air/gas holes are unclogged do not use any ajax or any cleanser that will leave a powdery residue.
Nov 30, 2007 | Cooktops
Burners only work half way
Remove the burner knobs, inside of each shaft is a straight slot screw adjustment, use a flshlight to see it. Sears has screwdrivers this small.While holding the shaft with a pair of pliers turn the screw in the shaft, it will be hard to turn, this is normal.
Continue doing this until you obtain the desired flame setting.
Oct 11, 2007 | GE 30 in. JGP337 Gas Cooktop
AEG 5 burner gas hob
there is a bypass screw on each gas valve. adjust so flame is reasonable when each burner is turned to low
Jun 15, 2007 | AEG 34942G-M Gas Cooktop
Miele 36 in. KM342 Gas Cooktop Logo
22 people viewed this question
Top Miele Cooktops Experts
Dan Webster
Dan Webster
Are you a Miele Cooktop Expert? Answer questions, earn points and help others
