Question about Samsung SyncMaster Computers & Internet
Computer monitor yelp
*deep breath*. I bought a new Samsung b300 monitor. Im using a dvi cable. The windows logo with the colored thingies comes up, then nothing. A blinking on/off light. I got it into safe mode and it tells me my Asus graffix card isnt compatible. It said to update the driver but I cant do it in safe mode. ! of the folders said *vista and xp* but no Windows 7.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 40 Answers
I think you need a DVI to VGA cable
Posted on May 09, 2013
SOURCE: Samsung Monitor 510N LCD BLINKING like Tubelight.
Dear ,
let me know this problem you fecing in other C.P.U.?
also if you are not cheked another C.P.U.and give me feedback to me i will help you .
Posted on Jun 14, 2008
SOURCE: Wont work with new computer
Since this was a new out of the box computer, Safe Mode was not allowed. In order to change monitor settings (resolution), I had to use another monitor, in this case a newer CRT. With the CRT, the computer booted up, no problem. Once booted, I turned down the monitor resolution and saved. Now when the Princeton LCD was plugged in and the computer restarted, everything works fine. Now the resolution could be set to limits of the monitor.
Posted on Aug 20, 2008
  • 300 Answers
SOURCE: "No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Posted on Sep 14, 2008
  • 489 Answers
SOURCE: When I boot into Windows Vista Premium nothing on screen
In Safe Mode, your monitor will not be listed as it is using a generic device driver for basic display. Go into your video settings and reset it to the lowest resolution available. Reboot the computer into Vista again and your display should be working. If you check Device Manager now, you should see your monitor listed. If it isn't, you will need to load the Vista drivers for it. You can then modify your display settings to suit your preferences.
Posted on Mar 28, 2009
prerit_777
  • 214 Answers
SOURCE: I'm running windows 7, and whenever I run a game
ITS NOT PROBLEM WITH YOUR CARD BUT WINDOWS7 DOESN'T SUPPORTS MANY GAMES
Posted on Feb 04, 2010
Screen flickering on windows 7 boot
This is more than likely an issue with the monitors themselves. Does this happen on the main monitor is you move the secondary cable over to it? What kind of monitors are you using, how old are they, and do you know the refresh rates on them?
Nov 21, 2013 | Nvidia Computers & Internet
Samsung syncmaster 2033sw monitor, till now i was using a vga cable for the display, but recently i bought a dvi cable and connected it. but its not detecting the display of dvi cable. if i remove the vga...
LCD Monitors having multiple inputs have option and option to select and switch between the displays from analog (VGA) or Digital (DVI) inputs. Go to the LCD menu and select input source (DVI)
Hope this helps!
CreativeTECH
Nov 15, 2010 | Samsung Syncmaster 2033SW Monitor
I bought a used samsung 931b 19 inch monitor and it did not come with the cables to hook up to PC what cables do i need?
you need either a dvi-d or a dsub cord depending on whether your computer has analogue or digital outputs. if you look on the back of your computer, dsub is blue, dvi is white. this monitor has inputs for both. the cords are available at you local bestbuy, radio shack, or office depot.
Aug 14, 2009 | Computers & Internet
Nothing on the screen at startup
If you cant get into the setup menu then I would think the monitor is defective,you did not state if you hooked up the monitor to a computer that has a vga port that works.
Jul 21, 2009 | LG 22" FLATRON LCD Monitor
Replacing monitor.
What type of monitor do you have? Most monitors will come with a DVI-to-VGA adaptor.(Sometimes and some models.) Also, when you say the monitor will not power on, do you see a message like "No signal detected" or anything like that or do you get nothing what so ever?
To verify it's not your system, connect a VGA monitor to your computer to see if it works. If it does, you know it is the monitor. Good luck.
Feb 02, 2009 | HP Compaq Presario SR1265CL-B...
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
Samsung T220 monitor hook up to new macbookpro-how-pc driver only-help
I think you're using the adapter in reverse. The adapter that changes from VGA to DVI but not the other way. You should plug the adapter into the DVI out on the macbook and then plug the VGA end of the cable into the monitor. If the monitor has a DVI input then you should be using a DVI to DVI cable to hook it up.
Once you have the cable plugged in you'll need to enable dual monitors or switch to external monitor on your macbook. Don't worry about the driver's cd, they are not necessary to make the monitor work on your mac (or on a PC for that matter).
There are two great instructions on how to do this, just google for "macbook switch to external monitor"
One here.
Second one here.
Jun 04, 2008 | Samsung Computers & Internet
Computers & Internet Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
