Question about Exercise & Fitness
The box constantly reads either 17.8 or 18.5 as far as the speed of the gun, and you can't turn it down. The regulator switch is ok and everything if brand new.
2 Suggested Answers
  • 885 Answers
SOURCE: dcd985 reverse switch won't work
The switch (PN: N089938) for your drill costs between $75 & $80, so:
If by "brand new, just out of the box" you mean you just bought it, bring it back to where you got it and exchange it or get your money back.
If by "brand new, just out of the box" you mean you bought it, it sat somewhere for some time and you're just now using it, check to see if it's still under warranty so you can get it fixed through that.
If it's out of warranty, you'll have to buy a switch to fix it. They're available on sites like www.ereplacementparts.com.
Posted on Feb 25, 2013
Porsche cdr22 volume increases and button will not dcrease
Most of these things use an IC to control things like volume etc. Chances are that will have failed.
Feb 25, 2013 | Pyramid Cdr22kit Am-fm Receiver Cd Player...
What's your problem?04 dyna low rider, riding down the street and everything went dead. the speedo read like 30 mph and tach accordingly, prob speed i was going when stalled. I pulled fuses out to
Hi Kim, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below. Good luck and have nice day.Harley Diagnostic Codes 04 to Present
Feb 08, 2013 | 2004 Harley Davidson FXDL - FXDLI Dyna Low...
Car won't start after switching baterries
re move alt. have it re tested i had a signaler problem. tested fine at idle under load alt surged blow batt. also volt regulator may be constantly draining battery voltage regulator is inside alternator
Nov 23, 2012 | Oldsmobile Cutlass Ciera Cars & Trucks
The fuel pump was changed,now it idles high.
The idle speed is controlled by an Engine Control Module (ECM).
It needs to be put on a computor to be checked.
The idle air valve provides the control for constant idle speed. In order to set the correct air valve opening to achieve constant idle speed, the fuel injection control unit uses information from the air mass meter, A/C switch, throttle valve switch and the ignition control unit (RPM signal) to regulate the output current to idle air valve. This means, there is alot of things that can make the idle speed go up or down...Hope this was some help to you??
Jul 21, 2011 | 1990 Volvo 740
Our Technics SL-1200MK2 has issues with the direct drive. It does not spin at a constant speed. When stopped, it does not stop immediately. What can be done to solve this?
To adjust stopping speed you'll have to remove the plate by pulling it up. Then there is a plastic cover that has some screws, remove the screws and remove the plastic cover, you'll find a variable resistor that reads something like brake. Adjust it to the left or to the right with a screwdriver and see at which position works best.
To solve the constant speed problem you'll have to replace the pitch regulator.
Go to any panasonic/technics service and buy the pitch. If you have a bit of soldering skills you'll be able to replace it by yourself. You can access the pitch regulator unscrewing all the screws under the device and then removing the cover.
Hope you can solve the problem!
May 18, 2011 | Technics SL-1200MK2 Turntable
I tried to adjust the regulator and the back just screwed off of the body - any ideas on how to prevent that?
Possibly you were trying to adjust the regulator without having air flowing through it. You must squeeze the trigger on the gun and have air constantly flowing through it otherwise the regulator knob is very hard to turn against the pressure inside it. To set an accurate pressure, squeeze gun trigger (while connected to air hose) to get air flowing... then twist regulator knob out (or in the "-" direction) until air flow reads 0 on the regulator gauge. Then start twisting regulator knob the other way until you reach the desired pressure on the regulator gauge. Also make sure the regulator is attached with air flowing the correct way through it. There should be an arrow somewhere on the regulator body which should be pointing toward your spray gun.
Oct 05, 2009 | HVLP 2.5mm Hvlp Spray Gun-auto Paint...
How do i read a radar detector
When a radar or laser is detected, the unit will make noise. As you get closer to the source of the radar or laser, the noise will get louder and the signal levels (if you have a detector that shows signal level) will get stronger.
Since police officers like to wait until you are close to them, they may keep their radar guns turned off until you are very close to them. Once they turn it on, you are likely to be busted unless you can REALLY slow down quickly. Most radar guns take a series of average measurements on the speeding car. If the samples are too far apart, it keeps looking for a series of successive speeds that are close. This happens in a few tenths of a second.
SO even if you hear a SLIGHT noise from your detector, it may have been from a brief instant on radar gun in front of you, so BEWARE until you are sure that there is no threat.
The valentine detectors use multiple antennas to tell you where the signal is coming from. This is handy.
Oct 03, 2009 | Vehicle Parts & Accessories
Amilo xa series
The fan speed is controlled by the processor and BIOS. It is on full speed when it starts, but the processor turns it down again as soon as it starts to run.
Could be loose memory modules or the processor heatsink has come loose. Try taking off the back compartments and check everything is fitted OK.
Jul 27, 2008 | Fujitsu Siemens AMILO Pro V7010 Notebook
Thomson DV3 digital terrestrial recorder
this recorder is constantly getting bad reviews, I think it is unfair because mine does the job, however this problem occured heres what you do.
turn off at the mains and wait 20secs turn back on and hold the standby button untill a light appears.
in sequence up down left right menu ok press the buttons on the front of the box wait 60 seconds and the normal red light will appear turn on box and there you go.
Good Luck further issues visit www.topuptv.com WARNING- doing this procedure will swipe your library but i think it is the only solution
Mar 31, 2008 | Televison & Video
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
