Question about Dell E173FP 17" LCD Flat Panel Monitor
Monitor Grounding dear sir i have bought dell e178wfp (Black) 17 in. Flat Panel LCD Monitor 3 years ago and it's work perfect tell now but this days i found a problem with my Motherboard USB ports it's disconnecting all usb mouse or keyboard connected to he motherboard after checking all my parts i found something the problem is this my Dell LCD when i connect it to the motherboard i fell with electrical grounding it means when i connect the monitor to motherboard the monitor cause grounding to motherboard when i disconnect the lcd monitor the grounding disappear i don't know why LCD do that i tried another LCD and it's good this means the current LCD i have right now is the problem ? what i do to solve the grounding problem of my LCD monitor thanks a lot note: the LCD is working perfect there is no any thing happened to colors or to anything in the lcd no it's work good but the problem in the grounding it's make to the motherboard thanks alot
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 40 Answers
Good luck
Posted on May 09, 2013
SOURCE: Dell E173FP 17" Monitor
I just had the same problem as well - mine happened during a windows update, related? Also, for me the monitor doesn't come one even after disconnecting from computer, nothing, just blinking green light.
Posted on Nov 21, 2007
worldvet
  • 859 Answers
SOURCE: Dell LCD monitor suddenly loses power
Five years is a long time for an LCD panel. You definetly got your money's worth.
But, if your trouble shooing has led you to this conclusion I can also only conclude that the power driver inside your panel just gave up the ghost.
However, try giving Dell a call, for what's thats worth and see what they have to say.
You might also want to ask this expert "Robotek" what he may think as he is a board troubleshooter and could give you an answer if one is there.
Type this or copy and paste into your browser's address bar:
http://www.fixya.com/users/robotek
And then click on the Ask Me button under his picture.
Best regards,
Worldvet
Posted on Jun 21, 2008
Benimur
  • 6966 Answers
SOURCE: NO POWER ON INDICATOR LIGHT AND NO Screen Raster on Monitor
Initially, pls check D854 on the Power Supply/Logic board. It is a dual diode. If you would prefer board replacement rather than component level repair, this might be of help. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
This is of course in addition to checking the usual, power cord, fuse, outlet etc.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 05, 2008
  • 3940 Answers
SOURCE: Dell E171FPb 17" TFT LCD Flat Panel Monitor Problem
The LCD and or the LCD inverted has failed. it is an unfortunate fact of life that nowdays it is cheaper to replace that monitor that to aquire parts for repair
Here is one on Ebay:
http://cgi.ebay.com/Dell-E171FPb-LCD-17-Flat-Panel-Color-Monitor_W0QQitemZ290290215133QQcmdZViewItem
You can buy a new 19 for about the same price
http://www.newegg.com/Product/Product.aspx?Item=N82E16824254009
Posted on Jan 22, 2009
pin_0018
  • 77 Answers
SOURCE: HI SIR MY LCD IS Dell 1704FPVs 14" IF WE
You can only use this connector after you have connected the USB cable to the computer and USB upstream connector on the monitor.And u need to Purchase this Cable Seperatly u dont Get with the Box.
Click on this Link if u Need More Clarification
http://support.dell.com/support/edocs/monitors/1704FPVS/EN/about.htm#Bottom View
Posted on Jul 18, 2009
Dell e178wfpc power light on but no display
REMOVE IT'S RAM, CLEAN ITS CONTACTS USING ERASER & AGAIN PLACE THE RAM IN SAME SLOT. IF NOT FIX YOUR PROBLEM ALTER THE RAM SLOT. ALSO CHECK S-VIDEO CABLE.
Apr 11, 2014 | Dell E178WFP Black 17 inch LCD Monitor
Dell lcd monitor e178wfp rev a00
wrap a magnet around the cable or some tin-foil.
May 07, 2013 | Computers & Internet
Gateway FPD 1730 (mfg June 2004) On start-up, monitor flashes bios screen for less than half a second, then flashes the Windows XP logo for less than half a second and then stays black, no image. No...
All support is finished for XP years ago. The system is 13 years old and well past it expected life. Average is 8 to 10 years on a shop bought unit like Gateway, 12 years on a custom build.
I am thinking you probably have a dry joint on the board behind the switch as holding the switch makes the monitor work.
My advice though is a new computer running Windows 10, technology moves on in hardware and software.
Mar 08, 2017 | Gateway FPD 1730 17" Flat Panel LCD...
I have a Dell E173FP 17 inch Flat Panel LCD Monitor. About two weeks ago after having turned it off at night (leaving the PC on) then turning the monitor back on in the morning it would light up to half of...
The monitor can be repaired - by replacing one or both the fluorescent tube and inverter. You can have the work done for you - or you can attempt it yourself. Lamp prices vary based on size - but most hover in the $10 range. Inverters can vary in price too - but run more than lamps for the most part. There are numerous suppliers for these parts such as this and instructions about how to do it such as this.
I hope this helps! Please rate my reply - thanks!
Dec 21, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
My DELL monitor is not working I got a second
More likely to have problem in the inverter circuits, check for short between Emitter and Collector pin of the four transistors as shown in the pictures.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Feb 24, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Screen Size
try ask at&t any firmware upgarde for vga output, or try use auto key on monitor.
Feb 21, 2010 | Dell E178WFP 17 in. Flat Panel LCD Monitor...
No power to Dell E173FPc monitor; power light doesn't come on
It sounds like you are not getting any power. I would try another power cord to see if it makes a difference.
Jun 16, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Jan 21, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell E173FP 17" LCD Flat Panel Monitor Logo
69 people viewed this question
Alun Cox
