Question about Apple Bluedio I4 Bluetooth 2.1 A2DP Handsfree Stereo Headset - Black
The headset disconnects automatically
The headset connects well and then in a few minutes while i am using it, it automatically dissconects
How do I reset my computer on 2011 dodge ram
dissconect battery for a few min if that dont do it contact your local ten min oil change they will know how to do it
Mar 20, 2015 | 2011 Dodge Ram 1500
My roadking is stuck in paring mode how to stop
Try removing the headset battery and leave it out for a few minutes. Also try disconnecting the power to the system and reconnect after a few minutes.
Oct 05, 2014 | RoadKing Rk400 Noise Cancelling Bluetooth...
Welded a radiator support on with mig welder and didnt dissconect battery
Try disconnecting the battery for a few minutes and recheck , if problem persists, something fried, possible cluster or RPM sensor
Feb 22, 2014 | Nissan Cars & Trucks
Headset won't stay connected.
The headset may not be pairing up correctly due to the difference in bluetooth applications. If you have a new telephone with the headset already paired up to the very first phone, it will automatically go to phone number one or the phone that it was last used with. If the answer is not in the users guide, you can try Plantronics tech line 800-544-4660.
Plantronics Explorer User's Guide
Good luck from Headsets Direct!
May 12, 2010 | Plantronics Explorer 330 Headset
CAN'T GET MY BLACKBERRY 8330 TO PAIR WITH MY
Did you do the steps listed here?
This is the Plantronics information.
Your new headset includes Plantronics QuickPair technology to simplify
the Bluetooth setup process. The rst time you turn your headset on, your
headset automatically enters pairing mode for 10 minutes. Once paired
successfully, your headset stays on for instant use.
If not sucessfully paired after 10 minutes, your headset automatically
powers o. When you turn the headset on again, it automatically goes
into pairing mode until successfully paired with a Bluetooth phone.
To pair your headset for the rst time:
Turn ON the Bluetooth feature on your phone.
TIP: For most phones, select Settings/Tools > Connections > Bluetooth > On.
See your phone’s user guide for more information.
Press and hold the call control button to turn on your headset. (The indicator
ashes red/blue to show that the headset is on and in pairing mode.)
TIP: If you don’t see the red/blue ash, press and hold the call control button to
turn your headset o, and then press and hold the call control button again until
you see the red/blue ash.
Use the commands on your phone to locate your headset.
Search > 520Plantronics. See your phone’s user guide for more information.
When prompted for the passkey, enter 0000.
When pairing is successful, the indicator on your headset ashes blue. Your
headset is now connected and ready to use.
Apr 15, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
Motorola Headset Out of range...
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select HS815 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Dec 23, 2008 | Motorola Mobility HS815 Wireless Headset
Permanent Connect and disconnect with K750i
I had the same issue with my LG Vx8700 phone. Turned out to be the phone and not the parrot. Am on my third replacement Vx8700 and it is working fine for now.
Feb 04, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Headset disconnecting frequently
I think that the problem is with the on/off switch inside the headset boom. Mine has been doing the same thing lately. I'd like to find out how to fix it myself, cause I'm sure having it repaired would cost about as much as just buying a new or better headset.
Jun 10, 2007 | Motorola Mobility H700 Wireless Headset
Apple Bluedio I4 Bluetooth 2.1 A2DP Handsfree Stereo Headset - Black Logo
Top Apple Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you an Apple Radio Communication Expert? Answer questions, earn points and help others
