Tv sound dead
Sound not working
    Top Expert:
  • Televison & ... Master
  • 74,459 Answers
What is the brand name to your TV? Provide more details please. Check its speaker first. If it is found OK, check the audio output section circuit for fault. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Nine Lakh viewers cannot be wrong.
Posted on May 07, 2013
Vizio tv sound to speaker outlet dead
Connect the sound bar to the cable box audio out.
Sep 10, 2015 | Vizio L37 Television
I awoke this morning to find the sound on my Apex Digital LD4088 LCD tv is dead. The picture is fine, but sound is dead, how do I solve this?
Download the user manual to your TV. Clik here to download it. See whether audio options to it are set right. If all are right, check its speaker. If speaker is OK, the audio output circuit section should be troubleshooted.
If you feel any difficulty in downloading the manual, send your email address to me. I'll send a copy of it to you by return mail.
May 16, 2012 | Apex Digital LD4088 LCD TV
Model DP26649 No pic no sound no warning. Shut off last night and dead today. Will be 2 yrs old in August.
Now the tv it is completely dead no LED power light indication is on at all or the tv power LED light indication blinking too?Check the power source?Tries tv unplug,replug it back about an hour later for the tv do a resetting itself back to the factory setting,tv should be working again.If not the tv power supply board it is dead,that the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jun 17, 2011 | Sanyo DP32746 32 in. LCD Television
Heard a pop sound...turned it off then back on and the red light is flashing and it's making a clicking sound
This problems it the causes by the power supply board have dead parts call capacitors.That the board,where the power a/c cord plug into it.U have tools like a soldering iron,desoldering pump or a roll of desoldering braids,a roll of solders?U know basic electronic and can do basic soldering?Yes,check the power supply board for dying and dead capacitors,these capacitors are alway bulges up or puffing up on it tops.Replaced these dying and dead capacitors parts,will get ur tv stop making clicking sounds and the tv power will be stable again,tv will work.Or try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 27, 2010 | Fujitsu Plasmavision P42HHA10 42 in....
I WAS TOLD I NEED A NEW BULB....IT WAS WORKING FINE AND THEN NOTHING...MAKING A SMALL CHIRPING REPETITIVE SOUND...YOUR THOUGHTS, THANKS
This problems,it is also the causes by the tv convergence board,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved this chirping problems.The shop,will cost u like $300-350 for parts and labors.
Nov 24, 2010 | Philips Magnavox 9P6034C 60" Rear...
TV turned off, red and green lights flash for 60. Changed lamp STILL NOT WORKING. Question: Should you still hear the TV if the lamp was out?
Yes,u still can hear sound,if the projection bulb is dead.The Ballast board might also dead dead too.The Balllast board help to ignite the projection bulb.
Jul 14, 2010 | Zenith D52WLCD 52" Rear Projection...
Blinking timer light, No picture or sound.
Ur high voltage is dead,the FBT,the flyback transformer,the big black block of plastic with a red wire with a cap hook to the CRT(tv tube).That is dead.
Sep 27, 2009 | JVC AV-36D302 36" TV
Black screen on tv but still have sound!
i used to work on the warantee's for relysis from memory that was a deffo dead un we used to swap out on that fault im pretty certain its a dead processing board . . . sadly relysis uk went bust . . . .
Jan 17, 2009 | RCA F32450 32" TV
Suddenly no sound & no picture overnight: is my TV dead?
If you have static siugnal, sure TV is not dead.
Check the aerial cable, ensure it is well plugged in and getting signal.
If you are using a receiver box, check cables to TV and receiver (freeview, sat, cable etc.), try setting channels on receiver again, if it does not work but you get static, then either the cables or receiver are defective.
Test the TV on standalone , connecting it to an external antenna.
Tune again the channels, and save the preset.
If still no signal then the antenna socket on the TV may be defective.
Try using the TV with a DVD.
If you can watch DVDs, and TV is not keeping channels preset, and you tried all the above, at this point htere may be a fault in the tuner card inside tv.
Call the phone number listed on tv user manual to get support, and eventually repair it.
Oct 03, 2008 | Panasonic CT-36HL43 36" TV
KOLIN TV - Snap sound and went dead
The number is 1-888-796-8298,you need your model and serial number,tell them what happened and they will tell you where to take it.You should have some warranty.
Oct 03, 2006 | Olevia Kolin DLT2711M 27 in. LCD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
