Question about Plantronics 510 Voyager Headset - PLN-510 Headset
Noise reproduction problems
Hi there, let's see if somebody can give me a hand :-) Just installed the Plantronics 510 BT headset, and audio input works perfect, but using any program to save/reproduce audio is so noisy I can't hear my voice. Tried with the audio saver tool bundled with XP and with skype with same result. I have muted soundcard microphones just in case but no luck at all. Then checked audio properties, and Plantronics device is correctly specified in both audio and voice. Run a HW test, and exactly the same noisy sound happens when I reproduce the sound saved. Finally I've updated the driver from Plantronics site to latest version, just to give it a try in spite nothing was showed on release notes, needless to say it failed again. I'm beginning to think the headset is defective ! Any ideas ? Thanks in advance !
  • legolas Mar 13, 2008
    Yep, I had to replace it:-(. In fact I did sometime ago and the new one works fine since first moment ! Thx!
  • 5 Answers
I called into Plantronics  Support Phone Number: 1-800-544-4660  with similar issue;  Noise at other end.  Tech (Oscar) told me if I had evidence of purchase date, the one year warranty valid and to send in unit with copy of original receipt.  A replacement will be sent back within 3-5 days of receiving.  He told me to just mail it in an envelope.  No box is necessary.  Hope you call in and get same response.
Posted on Mar 12, 2008
SOURCE:
Minchai USB-510 headphone drive
I have a Minchai USB-510 headphone but can't work it device. What can i do?
Oct 22, 2012 | Plantronics Audio 510 USB Headset
How do i connect my plantronics 510 voyager headset to my blackberry
Once you make your BlackBerry discoverable, then put the Plantronics Voyager 510 into pairing mode by holding the call control and volume up buttons at the same time until the headset flashes red and blue. Here is the link below for the 510 pairing instructions.
Plantronics Voyager 510 Pairing Instructions
Good luck from Headsets Direct!
Oct 19, 2011 | Plantronics 510 Voyager Headset - PLN-510...
Can't hear my pc to head set..can u help
Hearing a Plantronics Voyager 510 headset through a computer:
To use a Plantronics Voyager 510 headset through your computer, you either need a USB Bluetooth adapter or you must have Bluetooth built in to your computer. Once the Voyager 510 headset is "connected" to your pc (by one of the mentioned ways), you may need to go into the control panel on the computer or the specific software program being used to set the Plantronics Voyager 510 headset as the "default device". Keep in mind that the headset has to be powered on and to also have to activate the headset to connect to the Bluetooth adapter or computer.
Good luck from Headsets Direct - 800-914-7996.
Aug 20, 2011 | Plantronics 510 Voyager Headset - PLN-510...
When you press earpiece to pickup call the phone lift not working and a red light blinks on front left on desk top charging station .It worked fine yesturday - I come in today and it doesn't work. there...
This could be several problems, I am going to give you the one that I believe is the answer. It sounds like it may need to be subscribed again. First here is your user guide:
Plantronics Voyager 510 User's Guide
If that doesn't work, it may be that your headset is bad. If it is you can replace that with this headset:
Plantronics Voyager 510 Replacement Headset
Mar 01, 2011 | Plantronics Voyager 500A Deskphone Adapter...
How do I put it into discovery mode, so that my laptop will find it?
Most blue tooth manufactures use holding the power on for 6 to 10 seconds when turning on your bt device to put it in discovery mode i hope this helps
Feb 20, 2011 | Plantronics 510 Voyager Headset - PLN-510...
Blue light blinks all the time its on
Plantronics 510 Voyager Headset - PLN-510 Headset - Light blinking blue.
Good! You'll be happy to know, this is normal.
The Status Indicator flashes blue when the headset is on. When the battery becomes low, the indicator will flash red.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Feb 06, 2010 | Plantronics 510 Voyager Headset - PLN-510...
Turning the plantronics 510 headset off
Holding down the small black button at the top of the earpiece will power down the headset. Plantronics offers great support too so you can contact them at plantronics.com or check out the Plantronics 510 manual for info.
May 08, 2009 | Plantronics 510 Voyager Headset - PLN-510...
During moving I must have lost my cd for my blue tooth plantronics 510 ic, now I'm not able to install it on my computer so that I can phone hands free
have you tried to download the driver for your blue tooth plantronics 510 ic?
if not is uggest you go to the manufacturers website checkout the driver-software for your "bt" and download it.... if still can't install it form your pc...try to copy the driver to a disc and install your "BT" using the cd.
Jun 21, 2008 | Computers & Internet
Pairing headset with phone
You can download manuals from this link: http://plantronics.custhelp.com/cgi-bin/plantronics.cfg/php/enduser/std_adp.php?p_faqid=8079&p_created=1125099403&p_sid=BnXTqpIi&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MzMmcF9wcm9kcz02MiwxNjYmcF9jYXRzPSZwX3B2PTIuMTY2JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTE*&p_li=&p_topview=1 There is an online pairing guide below: http://www.plantronics.com/media/media_resources/easytopair/index.html?WT.mc_t=EasyToPair&WT.mc_n=EasyToPair&WT.srch=1
Aug 05, 2007 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics 510 Voyager Headset - PLN-510 Headset Logo
115 people viewed this question
Top Plantronics Radio Communications Experts
Anthony Ward
Anthony Ward
gggg
edward80
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
