Question about Toshiba E-studio 160 Mulifunction Copier, E-studio 160
Total print counter
We need to copy / print of Total Print Counter. What procedure.?
3 Suggested Answers
  • 36 Answers
SOURCE: How do you get the total counter to print? When I
There is a counter button on the panel that brings up 4 squares. One of them is print out total counter. One button on the panel and one touch on the screen. Hope that helps.
Posted on Mar 01, 2011
  • 653 Answers
SOURCE: how make reading zero or some less total counter miter reading
Altered meter reading is prohibited...
Posted on Jul 10, 2012
Kyocera FS6525MFP - How do I get it to display the number of copies already printed when I have a large job, such as 100 or 300 copies.
Press "System Menu / Counter" button. Press "Report". Press "Report Print". Press "Status Page". Press "Yes". The Status Page will print. Look for Counters in the right column just over 1/2 way down, then follow it down 4 lines to Total. The total page output is just to the right of the Total. Note don't use the Total at the bottom of the page, that is for scanned pages.
Sep 12, 2013 | Kyocera Office Equipment & Supplies
Hopw to get meter count
Total prints B/w with FAX and total b/w copies equals total B/w color is prints and copies color scans? utility/counter button and do you want a print out?
Feb 21, 2013 | Konica Minolta Drum Cartridge for Bizhub...
How do you get the total counter to print? When I log in under Administrator, I can print out department codes, but the total counter will not print. It will only show on the screen.
Feb 22, 2011 | Toshiba E-STUDIO 850 Copier
How do I print the total amount on my ticker tape of what I've added? I pressed the equals sign but that didn't work.
OFF • P P•IC
ON POWER SWITCH; PRINT / ITEM COUNT MODE SELECTOR:
"OFF": Power OFF
"•": Power ON. Set to the non print mode.
"P": Power ON. Set to the print mode.
"P•IC": Power ON. Set to the print and item count mode.
1) For addition or subtraction, each time is pressed, 1 is added to the item
counter, and each time is pressed, 1 is subtracted.
• The count is printed when the calculated result is obtained.
• Pressing of , clears the counter.
2) When the grand total/rate setting mode selector is in the ON position (GT), the
counter will count the number of times that the calculation results have been
stored in the grand total memory. To print and clear the count, press the key.
3) The memory item counter will count the number of times that the key has
been pressed in the addition.
Note: • Each time the key is used in the subtraction, 1 will be subtracted from
the count.
• The count is printed when the memory is recalled.
• Pressing of the key clears the counter.
Note: The counter has a maximum capacity of 3 digits (up to ±999). If the count exceeds
the maximum, the counter will recount from zero.
Dec 17, 2010 | Sharp EL-1801P Calculator
I REPAIR THE MACHINES IN AFRICA SO I NI THE ERROR RESET CODES
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
Main code Start key Sub code Start key
Usual "reset" codes:
14 - Trouble cancel (except for U2)
16 - U2 trouble cancel
20 - 01 Maintenance counter clear
24 -01 Jam total counter clear
02 Trouble memory clear
04 SPF counter clear
06 Paper feed counter clear
07 Drum counter clear
08 Copy counter clear
09 Printer counter clear
13 Scanner counter clear
14 SPF jam total counter clear
42 01 Developing counter clear
There are codes and subcodes.
example if yiu want to clear the maintenance counter , you have to enter simulation mode and then enter 20 / Copy key /01 /copy key.
I hope it helps you.
regards,
Adi
Nov 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
HOW TO GET PAGE COUNTER IN KM-1510
Just hold down the stop/clear button for 3 seconds..
It will flash F24 then 3 increments then 3 more.. eg; F24>063>123
It means you have done 063123 copies/prints..
Sep 18, 2009 | Kyocera KM-1510 Copier
What is "Maintenance required. Code: AA"
Maintenance timing display The message of maintenance execution timing is displayed when each counter reaches the set value. The relationship between the messages and the counters is shown blow. Maintenance counter AA WhenThe maintenance counters (both of total and color) reaches 90% of the set value of SIM21-1 (When the setting of SIM26-38 is ?print stop?). When The maintenance counters (both of total and color) reaches the set value of SIM21-1 (When the setting of SIM26-38 is ?print allowing?). Enable ? After completion of the maintenance, execute SIM 24-4 (Maintenance counters (total, color) clear).
Aug 29, 2009 | Sharp MX-2700N Color Copier
COUNTER CHECK "CANON IMAGERUNNER 2200" BLACK AND WHITE
On the left side of the on/off switch is there a small button mark with 123 press that button and the meter reading will display.
101 TOTAL ***** -that will be the total of copies,printing,and fax receiving on A4
103 TOTAL LARGE ******-this is the total of the A3 copies,printing and fax receiving made
201 COPY(TOTAL) -this is the total A4 copies
203 COPY(TOTAL LARGE)-this is the total for A3 copies.
Apr 02, 2009 | Canon imageRUNNER 2200
4 sets of copy counter numbers on canon imagerunner 2200
101:Total black copies and printed pages
103:Total A3 black copies and printed pages
201:Total A4 black copies
203:Total A3 black copies
Oct 31, 2008 | Canon imageRUNNER 2200
Toshiba E-studio 160 Mulifunction Copier, E-studio 160 Logo
21 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
