Question about Lexmark 3-Pack Axis 5400 Print Server .: Computers & Accessories
What's a Carrier jam?
When i switch on the printer it is showing "Clear Carrier Jam" i didn't understand what it is...kindly please help me to fix this problem as soon as possible.
  • Lexmark Master
  • 684 Answers
Carrier Jam means that the Carrier which carries the cartridges is not moving correctly in this case please follow the below Steps:
Lift the Flat Bed Scanner up so that you can find the Cartridges Inside.
Remove the Cartridges from the Printer.
Move the Cartridge Carrier Back and Forth as fast as you can!
Replace the Cartridges back to the Printer!
Good Luck!!!!
Posted on May 16, 2013
Carriage jam error
A paper jam
If you've had a paper jam, normally after you clear it, a small amount of paper sometimes gets left behind and gets shunted onto the sidewall of the printer by the carriage, which stops the carriage reaching its full travel and throwing up an error, rendering the printer unable to print or carry out any other function. Simply remove the paper and switch printer off and on and it will reset.
If you have an error of any other kind, many remedies and fixes for these can be found on my website http://www.the-inkstore.co.uk/frame/pages/epson.htm
Regards
Aeronautical
Oct 25, 2012 | HP OfficeJet 6110 All-In-One InkJet...
Hello, I have a HP 3210 Photosmart All-in-One printer. It will copy and print a test page with no problem. It will not print from the computer command. The photo carrier slides freely in and out as if it...
Hello and Welcome to FixYa!
Sir, The problem you are telling is surely be the problem of Paper Jam actually their may be small bit paper jam in side the printerThere are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.It will clear the printer jam error and your problem will be solved.
I hope you have clear picture in your mind, Don't hesitate to let me know if you have some confusion
Sir, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed
Thank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
Nov 28, 2011 | HP Photosmart 3210 Printer
Printer says to clear paper jam, can't see paper jam i clear it out.
Here is a post I found how someone else fixed their problem. Good Luck
I was getting the same fake paper jam and improper shutdown error messages on this POS printer. I blew it out with compressed air - but that was no help. To watch what was going on, I stuck a pen top in the open cover switch sensor (see top image at http://windowshopusa.com/hp_8500_POS.html ). It didn't appear that the cog wheel was the problem - it made no clicking noise or anything - the print head just traversed from R to L, then errored.
After I removed the sliding cover on the right, and with the print heads out of the way, I noticed that the chrome hold-down clip (bottom image) was crooked, and this prevented the print heads from traveling all the way to the right, causing the fake paper jam. Straightening the clip fixed the problem. (I didn't have to remove the clip, just pushed it straight - it's not in very tight.)
Nov 14, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My brother mfc 440cn had a paper jam & after i removed the paper "unable to print 50" & "unable to print 30" showed on the screen. i went to brother web site & went to the...
You have to open the printer and set it back into the ph carrier.
1) Remove Plastic wire covers from inside printers, and release plastic stay on lower edge, tilt cover to 90 Degrees 2) make a note of where each connector goes 3) release the Ribbon and 3 Multicolor cables, removing grounding screw, then remove scanner module by sliding it off the hinges at 90 degrees. 4) Remove Three Front Panel Screws, carefully leaver front panel upwards releasing front side clips.5) Remove front panel by disconnecting ribbon and wiring on both sides.6) Remove 6 Screws (2 on back, three at front and one middle right7) Carefully remove speaker cable (Red Connector) and lift up plastic casing, leaving printer uncovered.8) Re-Seat Encoder Strip.9) Re-assemble in reverse.
Nov 08, 2011 | Brother MFC-440CN InkJet Printer
I have a paper jam and need to open the back door of an HP 6200 Printer. Do I need a screw driver?
No, you didn't need any screw driver for clearing a paper jam. But yes, if it is more mess than just a simple paper jam, then it depends.
For Paper Jam issues, kindly go through this document.
Concerned, Nooh.
Aug 04, 2011 | Office Equipment & Supplies
How to clear carriage jam?
Hi there! in order for you to clear the carriage jammed of your 7410.. kindly check this link below..
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&tmp_task=solveCategory&lc=en&dlc=en&cc=us&site=null&key=null&product=391194
if the steps didn't help you on how to fix the carriage jammed then there's something wrong with the printer itself.
May 17, 2011 | HP OfficeJet 7410 All-In-One InkJet...
Dellv305 printer, clear carrier jam. My son pulled the paper out from the bottom of printer. How do i clear carrier jam?
Please perform the steps mentioned in the link below:
Paper Jam
The steps would help resolve the carriage problem as well.
Jun 17, 2010 | Dell 926 All-In-One InkJet Printer
Carrier jam on dell 924 printer??
eventually I uninstalled it then re installed it and thank god it solved the problem ididnt know it was that easy
Jan 16, 2009 | Dell 926 All-In-One InkJet Printer
How to Clear carriage jam on HP PSC 1610 Printer? No obvious paper jam visible.
Dear it's the carriage jam error. so it mean that your carriage is jam not paper. so open the printer where you insert the cartridge. check whether it is jam or what . cartridge carrier is jam kindly turn off the printer and try to move the cartridge head by hand very gently and if seems to be stuck than check for anything which abort him to move freely so than might be anything like dust or else. when you get success in moving the head put some machine lubricant on the rod on which head moves and check it ok.
Dec 04, 2008 | HP Office Equipment & Supplies
Lexmark 3-Pack Axis 5400 Print Server .: Computers & Accessories Logo
90 people viewed this question
Top Lexmark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
micky dee
Owen Barnes
Are you a Lexmark Computer and Internet Expert? Answer questions, earn points and help others
