I bought fisher & Paykel 8kg washsmart & need to find serial number for warranty registration
IFIXALL
  • 868 Answers
SOURCE: Fisher & Paykel smart drive
Turn machine OFF on the front panel. Hold down the Water Temp Down button and press the POWER button. Release buttons. You are in Diagnostic mode.With your service sheet ,Diagnostic chart will explain where the error lights pattern and the path to your solution are.My advice is this....there is a known problem with the wire harness connectors,and the contact that is made at the point of connection.One at a time remove each connector starting at your main control board ,some where there is a loose connection.
Posted on Jun 08, 2008
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
hattonhall
  • 349 Answers
SOURCE: fisher & paykel fill up with water then
Yep it sounds like another electronics panel has failed.
We never had this much trouble in the old days with the old electric timer machines.
Posted on Oct 19, 2009
  • 30 Answers
SOURCE: have trouble with fluf and soap residue on the
Through use a layer of gunk will build up on the inside of the outer bowl, especially if you regularly use fabric softener. This can generally be cleared by a couple large hot washes and kept at bay by putting a large hot wash through say... once a month.
Hope this helps
Posted on Dec 01, 2009
  • 343 Answers
SOURCE: what is error code 136 on a fisher & paykel IW...
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
Posted on May 24, 2010
Tip
Determining the Age of Your Fisher & Paykel Appliance
This advice applies to Fisher and Paykel appliances. Determining the manufactured date of most appliances is accomplished by looking at the SERIAL NUMBER. On Fisher and Paykel appliances this is determined by the by the 1st two letters of the serial number.
The 1st letter represents the YEAR of manufacture.
The 2nd letter represents the MONTH of manufacture.
Example: DHL121796
LETTER YEAR
C - 1
U - 2
M - 3
B - 4
E - 5
R - 6
L - 7
A - 8
N - 9
D - 0
LETTER MONTH
F - 1
I - 2
S - 3
H - 4
E - 5
R - 6
P - 7
A - 8
Y - 9
K - 10
U - 11
L - 12
In this example the appliance was manufactured in April of 2000.
on Sep 10, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Is it possible to reduce the washing time on Fisher & Paykel 10kg washsmart machine? The quickest wash is 35 mins.
NO
the wash time is set in the program board and that time is what the manufacturers consider necessary for a clean wash
Sep 19, 2016 | Fisher and Paykel Washing Machines
Fisher & Paykel washsmart washing machine model wa1068g1 serial mlg589826 keeps coming up with error 'loc' 'suds' can you pls help
This usually means the machine has locked up due to a suds issue? Meaning your using to much detergent or not using h.e detergent? which by the way u are suppose to use very little of in ur machine. Especially if u have an H.E machine and ur using regular detergent? u can try running some empty loads with water and vinegar
Jun 08, 2015 | Fisher Washing Machines
Fisher and paykel 8kg washsmart
check the water pump and hoses make sure it is not stopped up
Sep 08, 2014 | Washing Machines
How can I find out the part number for a bearing on my fisher & paykel dryer?
Your model number might be DG62T27GW2.
You can get a user manual from this site.
http://www.ajmadison.com/ajmadison/itemdocs/3969_USA_EN_Smartload_Dryer_UC.pdf
To find the part numbers from Fisher and Paykel parts catalogue you need the serial number or product number of the dryer. This should be on a sticker on the inside of the lid. Once you find it go to this site and download a parts manual.
Appliances User and Installation Manuals Fisher Paykel
Sep 03, 2014 | Fisher and Paykel Dryers
Error code 49 on fisher and paykel 8kg aqua smart washing machine, model number: wl80t65cw1. What does this mean?
Hi just read your posting.Error code 49 means the computer has measured a voltage from the valve diagnostic circuit that indicates the cold valve is faulty.Would you like help in confirming that the cold valve is faulty?You need an electrical test meter.Please reply and I can guide you thru the testing procedure.Looking forward to your reply.
May 15, 2011 | Fisher and Paykel Washing Machines
There is none I just want to know how I sign up for warranty instructions--I did not receive a card or anything i certainly don't think I should have to pay for the warranty. Lois Fair e-mail is...
Hi Lois,
You shouldn't pay for in warranty repairs. I am assuming you have a Fisher & Paykal washer based on the model number. If that is correct, click here to be brought to the official Fisher & Paykel product registration page.
Fill out the form and you're done! Make sure you keep you sales slip in a safe place if the ever need to see it for verification.
I hope this helps & good luck! Please rate my reply. Thank you.
Mar 24, 2011 | Washing Machines
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
