Question about RCA F27242GY 27" TV
No power i tried to change the fuse and it keeps blowing im thikingg its the power supply but not sure on how to get one or how to change it or even what it looks like. please send me some info on what to look for and what it looks like and how to change it. thank you. or if you mat have any other ideas on what it may be please tell me. thank you
  • ktenney Aug 12, 2007
    thankyou
  • 398 Answers
The RCA F27242GY uses the CTC185 series chassis. If it blows the main fuse the instant the power plug is inserted in the wall, then you most likely have a shorted power supply IC. This is a large almost-rectangular black IC mounted on the metal heat sink with STK730-020 (or -010) printed on it. Some sets have a metal clip over the top pressing it into the heat sink and some have 2 screws holding it in place. If you change it yourself then you must unsolder and remove the old IC, clean the surface of the heatsink, get a new STK730-020, apply heat sink compound the the back of the new IC, bolt it in place and solder its pins. Replace the fuse again and if you did everything right, the set should play fine.
Posted on Aug 11, 2007
19 in lcd sharp keeps blowing fuse
check the primary section of the powersupply mostly diodes and transistors inside and alo there filters.
Feb 06, 2013 | Sharp 32R-S50 32" TV
Crest audio ca4 blowing fuse
There is two possibillities to fuse blown off due to hi current flowing through fuse more than 3amp.because power supply componant like rectifying diode, filter capacitor or regulator ic ,regulator transistor shall be short circuited.
if you are tech......just remove amp. supply.from main power supply...try with another fuse........if fuse ok, fault is amp side, or if fuse blow off ...power side problem just....maximum fault comming on varistor ,diode, filter capacitor, .........
if you are not tech......... give to local authorised tech.......
Feb 04, 2018 | Crest Audio CA4 Amplifier Amplifier
My 4x4 fuse is poping on my 1994 cheve silverado 2500
a fuse only blows when it is overloaded eg.if you have a 10 amp fuse & the unit it supplying power to is drawing 15 amps it will blow, that is why the fuses are there,firstly make sure you have the right amperage fuse,if it keeps blowing,whatever it is supplying power to is faulty, don't try and overcome the problem by using a bigger fuse as you may start a fire......hope this helps.....cheers
Jul 06, 2010 | 1994 Chevrolet Silverado 2500
Hi i changed colour cartridge tried trial run printer died; changed fuse in plug; still no power any suggestions please
in the printer there is a power supply board.there is a same type of 3amp fuse on the power supply board.if there is any kind of overheating in the power then the fuse in the plug and fuse on the power supply board blows out.in some cases only fuse on power supply board blows out.this fuse is placed on the board for safety reasons.because in the older model printers when this short circuit problem was happening at that time whole board used to blow out.so in the new model of printer a fuse is placed on the board ,so if any overheating or any power outage or any short circuit occurs.the fuse blows out instead of whole power supply board. You just need to replace the fuse on the power supply board by disassembling the printer.the power supply board is the green color square shaped board.its the board to which your power wire of printer is connected. the fuse is available at any local electric hardware shop.its not any special kind of fuse. This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
Mar 18, 2010 | Lexmark X5150 All-In-One InkJet Printer
What do you do when your amp keeps blowing fuses
First off which fuse is it? The inline fuse from the battery or the amplifiers power supply fuse? Blowing the main fuse from the battery is caused by either the load (your amp) drawing too much current or you have a short to ground somewhere. Maybe there is a tear in the 12Vdc line and it is shorting to the chassis of your car. If the amps power supply fuse is blowing as soon as it turns on your amp has a shorted power supply. This will require internal component changes by a technician. If it is blowing after operation at high volumes I would say change the impedance that the amp is driving. If you are at 2 ohm try to rewire your speakers for four ohm. (go from parallel to series wiring then bridge mono or operate the amp in stereo mode)
Feb 07, 2010 | Infinity Reference 1300a Car Audio...
My tv keeps blowing a fuse when I turn on set.
DO NOT keep feeding it fuses more damage can accur-check rectifiers in power supply-then check regulator-chech H.O.transistor.if you need more help im gonna need a model number to go furthor
Sep 04, 2009 | Televison & Video
Fuse blows everytime i turn it on
the blue coloured varacter in your power supply circuit needs to be changed
Mar 30, 2009 | Teac AG-V3050 Receiver
Blow fuse
If the TV keeps blowing fuses, there most be a short somewhere. Most likely the power supply board itself somewhere. But take it to a repair shop to find out for sure. The sad part maybe that you'll have to pay over $100 for someone to look at it.
Feb 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Fuse keep blowing off
If the fuse keeps blowing, that is an indication that something has failed and is drawing too much current. Most likely it could be a problem with the power supply, such as a shorted rectifier diode or voltage regulator. Another possibility could be a shorted audio output module. Unfortunately, you'll have to take it to a repair center to be serviced.
Please let me know if I can help you further.
- Jim
Feb 01, 2008 | Sony STR-DE345 Receiver
Lanzar amp
If it keeps blowing fuses then #1 its internally damaged or "blown" .. Or #2 i would make sure you have the battery power hooked up to the + terminal and the ground wire running from the car body to the - terminal.. so if its hooked up correctly and keeps blowing fuses then it requires repair.. I wish i had better news but thats all it can be...
Aug 20, 2007 | Scosche Industries Scosche High...
RCA F27242GY 27" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
