Question about Maytag Dryer Drive Motor - W10410999
Dryer wont start after installing w10410999
Dryer model lde8624acl.red to 5,blue to 1,yellow to 6,blue to 2,grey to thermal tab,blue jumper discarded.checked voltage between grey and yellow got 120v.checked fuses for continuity(good),checked door switch(good).old motor worked before replacing(but had bad bearings)
    New Friend:
I had the same problem. Root cause was connecting the red wire to ground instead of pin 5.
Ground is between pins 1 and 5. Since it has no label, it is easy to miss the fact that pin 5 is not right next to 1, and connect red to ground instead.
Posted on Dec 31, 2015
SOURCE: Dryer does not start - Thermal Fuse is ok.
My Maytag Electric Dryer stopped working mid cycle and wont turn on at all now. Any ideas?
Posted on Jan 06, 2009
  • 18 Answers
SOURCE: Dryer will not start, timer sounds like it is running
Possibly a door switch, or starting switch near timer assembly. it could also be a bad breaker, dryers have a double breaker, even if you are getting electricity to part of your dryer 1 bad breaker might not let the rest of the dryer work. With electrical experiance,and elect. tools, have some one test breakers and plug voltage.
Posted on Apr 08, 2007
SOURCE: Maytag dryer: pye2300ayw
I had the same problem last month. My heater element broke in two places. This created an electrical open that prevented the heater from functioning. I replaced the heater element and my problem was solved.
In order to check your heater element: With the machine unplugged, disconnect one wire to the heater element and then use an ohm meter or multimeter across the heater element lugs to read resistance. Infinite ohms = open circuit.
Posted on Nov 04, 2008
SOURCE: Maytag Performa PYE2200AYW Dryer Heats intermittently
i had the same problem with my dryer and i installed the wrong thermal fuse for gas dryer which calls for a pink thermal fuse in which i installed and it works fine also check the lint in the front of your dryer. also my dryer which is the same make as yours seems will run on the fluff cycle until i replaced the right thermal fuse. my dryer run exceptionally hot and eventally shut down and it only run on the fluff cycle for any length of time.
Posted on Sep 22, 2009
  • 949 Answers
SOURCE: Dryer won't start, checked thermal fuses and start switch.
It sounds like you have been through most of the areas too look.
One thing to make sure of is that you have a full 240 volts. An electric dryer can measure 120 volts. from L1 to common and 120 volts from L2 to common but you also need to make sure you have 240 volts from L1 to L2 on the meter, one leg of the breaker or one of the two fuses could be blown.
If this is alright you only have a couple components left. The timer contacts and the drive motor. Either of these could be causing the issue.
To check the motor with the power disconnected check for continuity between switch terminal 5 and the Green(black) wire on the motor. If you have no continuity the motor is bad. Check for continuity between the terminal 6 and the yellow wire on the motor, if you have no continuity there the motor is bad. Check for continuity between terminal 1 and 2 on the motor if you you do not have continuity the motor is bad.
The timer should have continuity between the Yellow and Grey wire terminals for the motor to start.
I hope this helps
Posted on Apr 23, 2010
Testimonial: "Great advice, thank you for your help."
Colourcode. resistersr512andr514. forPacificsubwooferhcs101circuitboard
Resistor color code is as follows:
Black-0/.0
Brown-1/0
Red-2/00
Orange-3/000
Yellow-4/0000
Green-5/00000
Blue-6/000000
Violet-7/0000000
Grey-8/00000000
White-9/000000000
The first and second color corresponds to the numbers .0-9
The 3rd color corresponds to the zero(s).
So, 512 would be: Green/Brown/Red (5100 ohms)
and 514 would be: Green/Brown/Yellow (510000 Ohms).
Feb 09, 2017 | Computers & Internet
I need to know what the various colored wires connect to since I needed to remove the old amp and install an after market stereo.
Check the speakers connection and that should give you at least 8 of the colors. The ones left then are going to be ground and power and display power. You can figure those out with a meter.
Aug 24, 2015 | 1994 Volvo 940
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
Hi Ginko. I have a Kenmore dryer model 11086810100 that has some wires removed from inside. The only HOT I can find is the red wire. I have 2 wires that have femals push-on crimped terminals, but I have no...
Hi Robert.
Thanks for the pics. I operate in UK and color codes here are different.
From what I can see the wiring in your picture does not match the US standard either.
The thermal fuse for example should have two blue terminals, not red and blue. The thermal fuse wires goes on one side to start, and on the other to the drive motor through the broken belt switch (if present).
The wiring at the blower must be revised and done again.
Here a service manual covering Kenmore 70 series dryers.
http://www.applianceblog.com/mainforums/attachments/sears-kenmore/3298d1196129125-kenmore-dryer-model-110-86870100-wont-heat-ldrwp-checkpoints.jpg
There is a wiring diagram at page 25.
Here a picture showing correct wiring: http://www.applianceblog.com/mainforums/attachments/sears-kenmore/3298d1196129125-kenmore-dryer-model-110-86870100-wont-heat-ldrwp-checkpoints.jpg
See also the pictures in this blog:
http://www.satfix.net/showthread.php?931-How-Dryers-work.-Whirlpool-Inglis-Kitchen-Aid-Kenmore-Admiral-Roper
About the red and yellow cable, the only red yellow wire in the diagram operates the switch for the guard function. The wire becomes hot and powers the motor when the guard switch is closed.
Parts (including wiring harness and terminals) are available here:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11086810100/0582/0151200?pathTaken=&prst=0&shdMod=11086810100
Jan 02, 2012 | Kenmore Dryers
Friend gifted working dryer. the black cord did not match my outlet. Changed to grey dryer cord. Five wires coming from inside dryer yellow red two blue and one white. I have the red and yellow to...
The blue wires defiantly go on the outside...their are so many dryers i can not remember all details of each one off hand reply with the model number and i will check the wiring diagram and see exactly which wire goes where but even without referring to a diagram i know the blue wires go on the outside
GENE
Sep 14, 2011 | Dryers
Wire colours
Check if this applies to your Rover
White/Blue - Perm 12v,
Yellow/Red - Switched Igntion,
Red/Black - Night time illumination,
Black - Earth
 Blue/Green & Grey/Black at ISO Connection is LH Front Door Speaker
 Red/Green & Brown/Black at ISO Connection is RH Front Door Speaker
Blue/Yellow & Grey/White is LH Rear Speaker
Brown/White & Red/Yellow is RH Rear Speaker
Power connector:
1. n/a
2. n/a
3. n/a
4. 12V permenant
5. n/a
6. n/a
7. 12V (ignition on)
8. Ground
Speaker Connector:
1, 2: rear right speaker
3, 4: front right speaker
5, 6: front left speaker
7, 8: rear left speaker
Sep 01, 2009 | Philips Car Audio & Video
I need a wiring diagram for this stereo
FOR 16-PIN HARNESS
Pin Number Wire Color Function 1 White Left Front (+) 2 Green Left Rear (+) 3 Violet Right Rear (+) 4 Grey Right Front (+) 5 Blue/White Amplifier Remote 6 Blue Antenna Remote 7 Red Accessory 12 Volts 8 Black Ground 9 White/Black Left Front (-) 10 Green/Black Left Rear (-) 11 Violet/Black Right Rear (-) 12 Grey/Black Right Front (-) 13 Sky Blue Telephone Mute 14 Orange/White Illumination 15 Not Used Not Used 16 Yellow Constant 12 Volts
FOR 9-PIN HARNESS
Pin Number Wire Color Function 1 Not Used Not Used 2 Black Ground 3 Grey Right Positive 4 Grey/Black Right Negative 5 Blue/White Amplifier Remote 6 Red 12 Volt Switched 7 Yellow 12 Volt Constant 8 White Left Positive 9 White/Black Left Negative
MAY THIS HELP YOU
Jul 04, 2009 | Sony CDX-GT210 CD Player
Plymouth voyager
Hi Marlon,
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
Nov 24, 2007 | Car Audio & Video
Radar screen shows "no scanner". Would like resistance data for cable pin-out from display to scanner head.
Hello Clifford,
This is an old message. Are you still having trouble with this or has it been resolved?
Aug 22, 2007 | Raymarine C80 GPS Receiver
Maytag Dryer Drive Motor - W10410999 Logo
201 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
