Question about Flytouch Google Android 4.0, 10 vc, 1GB RAM, 4 GB tablet pc,Skype
How to factory reset a flytouch tablet
I can not remember my password or email address, so I need to reset my flytouch tablet flytouch 10 vc
How do i reboot a fly touch v10 tablet
Tony, you mean reset, Right ?
Check the attached links, to see how to reset.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to do Manual Factory Data Reset on Superpad Tablets Android 4 0
How to reset the SuperPad Flytouch 2 Google Android OS 10 inch
How to Do Manual Factory Data Reset on Flytouch Tablet The Classroom...
Superpad VI How to reset to factory defaults FlyTouch 3 Superpad 2
Mar 08, 2016 | Tablets & eReaders
How can I reset password for my Apple ID to get into ITunes?
Recover or Reset Forgotten Apple ID or Password on iPhone & iPad
This is all done on an iOS device and is often the simplest way to log back into an Apple account:
  1. Open the Settings app and scroll down and tap on "iCloud"
  2. Tap on the email address at the very top of the iCloud settings screen
  3. Tap on the blue text underneath the password entry that says "Forgot Apple ID or Password?" where you'll have two choices:
    • If you know your Apple ID and don't remember the password, type in your email address and click "Next" to start the reset process
    • If you don't know your Apple ID, tap on "Forgot your Apple ID?" and fill out your full name and email address to recover the Apple ID login (yes, you can then do the password reset after you have the Apple ID)
  4. Answer the security questions pertaining to that Apple ID, and follow the onscreen directions to complete the process
At this point you should be good to go, you can reset the password for the account and then login as usual.
Feb 15, 2016 | Apple iPad 32 GB WiFi Tablet PC
I cannot access my google password, so therefore my tablet is useless. How can i reset my password or find out what my password is
You can try using this link Having trouble signing in to recover your google password. Do you remember if you associate a different email address to your google account when you created it because normally that is where they are going to send your google password.
May 25, 2015 | Tablets & eReaders
Hi I forgot my password for my ipad
The biggest problem with Apple product's is the password. If you forgot your password you need to connect it to you PC/Mac and sync it with iTunes. From there it will ask you for your user I'd which is your email address and pasword. If you've forgot it you have the option to choose forgot password or user name. Either enter the user name and password or select forgot user name/password. If you remember it, it will sync with iclould and you can reset the iPad to factory settings with no password. Now the second option will send an email to you with a link to reset your password. The most important thing is that you remember your email address and password you signed up with when you bought the ipad. "If your in pad says Authorization lock....well you must have activated find my iPad or it is stolen and the iPad is bricked and there is no simple way of fixing this short of going to Apple with your proof of purchase.
Mar 01, 2015 | Tablets & eReaders
Facebook login problems
unless you can hack it, or remember it, you won't get your old password back. You can reset it provided you still have access to the email address you have on file with facebook. Simply goto login and look for and click on, "forgot password" (or something like that!) and an email link to reset your password will be sent to you. Open the email and click on that link. Then change your password. Write it down and relogin from each place you use facebook.
Aug 21, 2014 | Amazon Kindle Fire HD
Don't remember correct username n password on my goggle account
The username would be your email address then click on forgot password and reset your password with one that you will remember
Mar 24, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Flytouch superpad 9 sticks on android logo,i need instruction on how to reset
Doing a hard reset will delete all your saved files and application. Press and hold the POWER, MENU AND BACK buttons while turning the power on After doing that action it will automatically hard reset your device, no confirmation, just wait for the proess to be completed and thats it
Sep 17, 2013 | shop-fun 10 Flytouch 9 GPS Tablet PC...
Reset vigo android
This works with devices having physical home button:-
1. Press the power button and the home button together for a while, long enough until the screen appears with Android bot and a progress bar which shows that it's formatting the internal memory.
With NO physical HOME button:-
2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds.
3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings.
or you can Check my blog how to reset your tablet lol,
http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
Feb 18, 2013 | Android Flytouch 3 8gb 10.1 Inch Super Pad...
Flytouch Google Android 4.0, 10 vc, 1GB RAM, 4 GB tablet pc,Skype Logo
57 people viewed this question
Top Flytouch Tablets & eReaders Experts
Are you a Flytouch Tablet and eReader Expert? Answer questions, earn points and help others
