Question about Jl Audio 12W6v2 Car Subwoofer
Making a high powered substitute voicecoil
I have the wires and the former but not the adhesive. Recently my Jlaudio 12 w0 burnt out. I usually repair speakers and make coils for low wattage speakers for home use. I use epoxy to make the coils for these speakers. I tried making a coil for a high powered car speaker using epoxy but the coil failed at an early stage. Does anybody know what kind of high temperature adhesive is available to make high powered voice coils? I want to know the name of the best adhesive available for attaching copper wires to kapton formers that can withstand searing temperatures(above 600f) and thermal shock. Also tell me how can I access this type of adhesive. Please help!
  • 113 Answers
Try this first use steel epoxy ,thinest one you can find.quick drying steel epoxy is normally thick not recom.use thin long drying type.
Posted on Aug 22, 2007
  • oscar herrera Aug 22, 2007
    note:is ACE available to you? also the varnish on these copper wires may only withstand 300f max.
SOURCE:
What's the board substitution relation among different versions?
The TN52NS3 can be created as NS3 on the NMS. The former can substitute for the latter, without any software upgrade. After substitution, the TN52NS3 functions as the TN11NS3.
The TN56NS3 can be created as 55NS3 on the NMS. The former can substitute for the latter, without any software upgrade. After substitution, the TN56NS3 functions as the TN55NS3.
Dec 15, 2015 | Televison & Video
Tip
Don't buy jlaudio products even if you think it is good but they got the worst...
Don't buy jlaudio products even if you think it is good but they got the worst warranty ever. they do not give warranty for customers and they tell you : thats you have to take it to the dealer you bought from!!!!!!!!!!!!!!!!!!!!!! very stupid and guess what if that dealer is out of business YOU ARE OUT OF LUCK. thats exactly what did happen with me and 3 friends. so you are paying high dollar ticket for no warranty, without saying any other brand name , all the other brands they have repair centers and take warranty from customers except JLAUDIO because they are the best hmmmmmmmmmmm. if you are about to buy this brand think again.
thanks
on Oct 07, 2010 | Car Audio & Video
My head light went out. Checked the bulb with 12 volts of power and it worked. Checked the fuse and its not burnt. But there is no power there. Either side.... Now what do I do
It sounds like a headlight relay might have gone bad. They're usually in a fuse box under the hood. Do you get high beams and/or fog lights? If everything but the low beam went out, then you may be able to find a wiring diagram online for your make/model/year of car and start tracing back from the bulb until you get power.
When you get to the circuit where you get power TO it but not OUT of it, then you have found your culprit. I am still guessing headlight relays. If you have two of them, swap them and see if anything changes (like, lows work, but not highs)
Aug 23, 2014 | Cars & Trucks
Just got 84 lasharo rv ac blower dont work cant find fuze
If a GM chassis and problem is dash air, remove the power wire from blower (under hood) & apply 12 volts directly in order to confirm blower even works. Next, pull blower relay harness & check for arcing/burnt wires & contacts (usually the culprit this year GM). If good, trace wire to relay and check for 12 volts at relay (be sure to use a test light) and do this across the ground and power wires to relay and, relay to blower. Bad grounds and burnt contacts on relays are more of a problem than fuses during these years.
Oct 26, 2013 | Cars & Trucks
In my display is says 3-03 when ever i plug in my rca cables and no sound comes out?
From Page 7 of your manual... this is indicating a grounded speaker wire (blown voicecoil).
It has shut down to prevent damage. Disconnect the speaker wires from the amplifier and power on the amplifier again. If the error persists - you will need to have the amplifier repaired.
Check the voicecoils for proper imedance.
MANUAL LINK
Thanks!
Jan 01, 2011 | Kenwood XXV-03A Mono 25th Anniversary...
Wiring diagram for dual voicecoil subwoofer
To wire a DVC subwoofer, treat it (in the diagrams) as two seperate speakers, called coil one and coil two. This makes things easier.
To wire them up, wiring them in series would be safer, but if the amp is 2 ohm stable, put them in parallel. Look up dual voice coil wiring in google imagesfor more information and pictures.
Jan 22, 2010 | Soundstream PCS-12 Car Subwoofer
Bright lites indicator out, recently installed head lite modulater
The "high beam indicator" lamp gets it's power from the high beam wiring to your headlamp. Usually, it's wired in parallel with the high beam filament. The high beam filament is usually powered by the white wire going to the headlight. Evidently, this circuit has been bypassed by the modulator.
Oct 08, 2009 | 2002 Harley Davidson XL Sportster 883
Fried amp
Hello zadiel89,
Out-of-warranty JL Audio products are normally repaired through JL's authorized dealer network.
To locate your nearest JL dealer, enter your zip code in the box on this page, select "radius" from the drop down, and click "find".
http://mobile.jlaudio.com/dealerfind.php
You can email JL directly at: technical@jlaudio.com
Hope this helps.
Aug 21, 2009 | Jl Audio Car Audio & Video
Sub cutting out
500W x 1 @ 2ohm
How did you "switch the sub from 2ohms to 4 ohms"?
If you have the swr-1222d as listed, your only options are wiring 1 or 4 ohm, as it is a dual 2 ohm voicecoil.
If it was wired @ 1 ohm - you may have already done the damage to your amplifier - as it is not rated @ 1ohm mono.
There are 3 reasons the amplifier will go into protect mode while playing...
Thermal - overheating due to too low impedence.
Ground Loop/Short Circuit - Blown voicecoil, bad amplifier ground, tinsel slap, etc.
Overload - Impedence not within specs.
Disconnect every wire (including RCAs) from the amplifier. Reconnect only power and ground - make a short wire to loop from power terminal to remote terminal.
If the amplifier stays on without turning off - remove the jumper, add the remote wire, and try again.
If it turns off - the problem is internal and needs repair.
Still on? plug in 1 rca, and re-try.... then the other.
Still going??
Now use an Ohm Meter - or Digital multimeter set to ohms 20, and check both voicecoils. They should read 2ohms +/- .5ohm.
If they are OK, wire up the 4ohm load (series the voicecoils) and turn the gain on the amplifier to 1/2.
Retry -
If the amplifier continues to fail at higher volumes - the thermal protection relay has become weakened because of your improper wiring, and will need to be repaired to solve your issue.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 10, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Trying to figure out what kind of amp i got amercian pro vs-3507?
The VS3507 Is a class D monoblock.
Your optimum wiring for this amplifier is a 2 Ohm load - so it produces its full potential power of 350W RMS.
To Achieve a 2 ohm load, the most common load is one of the following...
(1) Dual 4 Ohm Voicecoil Subwoofer Wired in Parallel.
(2) 4 Ohm Voicecoil Subwoofers wired in Parallel.
(1) Quad 2 Ohm Voicecoil Subwoofer wired in Parallel/Series.
(1) Single 2 Ohm voicecoil subwoofer.
American Pro VS3507 2000W Car Audio Monoblock Amplifier
American Pro VS3507 Monoblock Amplifier Details
  • Built-In Crossover
  • Variable High/Low Pass Filters
  • Phase Shift Control
  • Subsonic Filter
  • Bass Boost Control
  • Dancing Lights at the Rhythm of Music
  • Protection Circuits
  • Gold Plated Terminals
  • Power & Protection Circuit LED
  • 1 x 250 Watts RMS @ 4 Ohms
  • 1 x 350 Watts RMS @ 2 Ohms Thanks for using FixYa - A FixYa rating is appreciated!!
Jan 29, 2009 | American Pro Car Audio & Video
Jl Audio 12W6v2 Car Subwoofer Logo
123 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
matthew walsh
Level 1 Expert
Dalynn Turner
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
