Question about Garden
Grass Trimmer How to properly re-string my Kawasaki grass trimmer ?
    New Friend:
How to play blackberry media files on samsung hm1100 bluetooth
Posted on May 07, 2013
  • 9 Answers
SOURCE: Black and Decker Grass Hog Model #GH1000
the drive cable probley kinked or bent and does not drive the head the cable goes from the motor to the head take the clamp bolt out and lift the head off the cutter check the cable
Posted on Jul 30, 2008
#1 Taper
  • 1041 Answers
SOURCE: Installing new line on my string grass trimmer
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Posted on Jul 03, 2009
#1 Taper
  • 1041 Answers
SOURCE: NEED INSTRUCTION SHEET FOR LINE INSTALLATION
If it is a duel line trimmer then:
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
Jim
Posted on Dec 02, 2009
SOURCE: string will not advance on black and decker grass
Is it best to buy a spool for Grass Hog, than trying to re-string myself? String seems to get stuck.
Posted on May 23, 2010
How do I find a detailed diagram of a Murray string grass trimmer CARBURETOR/
Hi Patrick,
If you hit the link below and scroll toward the bottom of page you will find videos that should be very helpful.
http://www.ereplacementparts.com/mtd-m2500-41adz01c758-gas-trimmer-parts-c-20039_20040_299701.html
Good Luck!
Mar 22, 2016 | Garden
Why did my weedeater lost power when trimming on grass but still spun?
There is a cable that runs from the motor to the trimmer head check that. Remove trimmer b.y removing small screw at the base of trimmer head
Aug 05, 2014 | Troy-Bilt 25cc 2-Cycle Curved-Shaft Gas...
How to put together a black n decker grass trimmer,has assembled the trimmer it's not cutting the grass should there be a blade in the trimmer
No, it is not heavy duty enough to drive a blade. It should have cuttting line in it and it only can use up to .065" string (factory recommended).
Oct 12, 2010 | Black & Decker 14" Grass Hog Xp...
;How do you lengthen the string? (Have the grass
To lengthen the string:
- Turn the Grass Hog upside down
- Push in on the two release buttons on either side of the spool (they're orange)
- Pull the spool head off and spin it to release more string while you pull the string with your hand (make sure it is still fed out through the hole in the base)
- Pop the spool head back into place
Test the Grass Hog to make sure the string is not too long. If it is you'll hear it cracking against the plastic guard on the base.
May 02, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
It looks like its working fine, but it doesn't cut the grass. Looks like the string is spinning with the turn instead of against it, if that makes any sense.
If the string is spinning it should cut no mater which way it is turning. maybe you aren't getting the trimmer close enough to the grass.
Apr 17, 2010 | Black & Decker String Trimmer Cordless 12"...
String will not advance on black and decker grass hog electric trimmer
Did you re-string it? If you did it is possible that you crossed the string over itself and it is stuck. Check that and good luck...Lee
Oct 20, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
String is cut always
first of all be carefull of what you hit with the trimmer string if you hit sidewalks and rocks or dirt it will cut it short also you might make sure the tensil strength is strong enough to withstand the abuse the trimmers being subjected to :-)
Jun 22, 2009 | Black & Decker String Trimmer Cordless 12"...
Grass trimmer
yes charger are vailable for this unit
Jun 02, 2008 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
