Question about Black & Decker ICR500 Iron
How to open an icr500 Iron
It does not work, I want to open it to review electrical continuity
2 Suggested Answers
chitownbob45
  • 316 Answers
SOURCE: I bought Black & decker iron ICR500 8m ago.
Take it back to were you bought and get another one.
Posted on Oct 04, 2009
2 year old iron lost power while ironing. Plugged it in to other working outlets. Light remains off.
It has defective parts, either the wire is open or the heating element also a defective plug cord.
It can be check by a continuity tester, if you have and knows how to use it.
If not, call or ask who has knowledge in appliance or electrical repair for assistance.
Thanks for asking.
Jun 28, 2011 | Tefal UltraGlide Easycord FV4256 Iron
Tip
Electric Iron not Heating Up or not Working Right
If you go to use your Electric Iron and it does not work you may be wondering what could have gone wrong. Actually there are only a few things that can go wrong with this handy little appliance.
The first thing to check is to make sure that you actually have electric power getting to the steam iron. Many times the problem is simply caused by a tripped circuit breaker, a faulty outlet, a worn or broken plug on the end of the cord, or in some cases, a fuse that is in the plug. Another common problem is for the cord of the clothing iron to break at the point where it enters the handle of the iron. By checking that you have power actually getting to the internal parts of the electric iron, you eliminate one set of common problems.
Next you need to check that the power is getting to the heating element. For the power to get to the heating elements of the iron it needs to go through the power switch and the thermostat. On some irons the power switch will be included in the iron thermostat and on others the on/off switch will be a separate switch. In either case you will need to make sure that there is continuity, or the ability for the power to flow through the switch and thermostat to get to the heating part of the iron. The thermostat is just an on/off switch that works on the temperature of the base of the iron. So whenever the iron is cold the thermostat should be closed, allowing the power to flow through it.
If the power can get to the heating element of the iron, then it should get hot. If it is not, then the heating part has failed. Sometimes, when this happens it will short out and cause the fuse to blow or the circuit breaker to trip. Many times though, the element will just simply burn out or break so that the circuit is open and the electricity cannot flow through to make the element produce heat.
If your iron is getting too hot or not hot enough then the problem will almost always be in the thermostat. Sometimes it may be a simple thermostat calibration problem, but it also can be that the thermostat simply will not work properly anymore.
This should give you a basic troubleshooting guide for home electric irons and steam irons. As you can see, there are not many parts that can fail and troubleshooting the few parts that can fail, is relatively simple with a basic electric meter.
on Jul 14, 2010 | Irons
Is no workig i needcramic heat control
1. you need a multi tester.
2. check the power supply of your outlet, or check the fuse or circuit breaker.
if has power go to 3.
3.open the back of your electric iron, the end of the cord or plug. then try to check the continuity of two wires if any is open. if its open or no continuity replace the cord or plug, either cut the only open wires and reconnect it again.
4. Or check the heating element of your electric iron if no resistance replace the heating element or you buy a new one.
Feb 16, 2011 | Conair Irons
Not heating up
The connection to your iron is perfectly alright and also to the cut offf circuit but unfortunately there is either a failure of the heating coild of the iron or a link failure to the iron heating element. The last option to check will be take a continuity test with a multimeter, you must get a low range below100- 250 ohms reading. If not you will have to open and test the coil for continuity failing which the coild is open. Replacing the coil to the cost of a new irron must be checked out. Hope you work this out. Good day
Jul 26, 2010 | Sunbeam 4214 Iron
Iron will not turn on
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jan 27, 2010 | Euro-Pro G1490 Continuous Iron
My iron is filled with water but won't steam - why?
No heat ! It's probably an electrical problem. If the electrical cord is connected to the iron properly, then it's probably one of the swithes to the iron.
Oct 07, 2009 | Oreck Cordless Speed JP8100CA Iron
Black & Decker D2020 Iron - Burning Smell & Beeping
The iron is probably junk...
heatman101
May 11, 2008 | Black & Decker D2020 Iron
Black 7 Decker Steam Express AS250 Iron
heatman101
Oct 31, 2007 | Black & Decker Steam Xpress AS250 Iron...
Black & Decker ICR500 Iron Logo
79 people viewed this question
Top Black & Decker Irons Experts
tfelton3
nmccully
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
