Question about Garden
Yt6800 yamaha lawn mower
Where is the best place to find parts? I need a pan gasket and seal for shaft between motor and belt pulley s on bottom of motor.
Agent Don
  • 310 Answers
SOURCE: 1957 Sunbeam Twin-Blade electric lawn mower shaft bushing
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=654762
Generic problem for all Vacuums
1957 Sunbeam Twin-Blade electric lawn mower shaft...
Posted by mower man on Jun 08, 2008
I have a late 50's series Sunbeam twin-blade electric lawn mower that I use regularly. The shaft bushing(s) on the left blade has worn out, and there's too much play for me to run it w/o ruining the machine.
It appears that the belt-run cog inside the housing is the part that is supposed to come off of the shaft to get to the bushings, but instead of a cotter pin or other fastener holding the cog in place, it looks like a rolled metal pin that may have been pressed in place.
How do I replace the shaft bushings so I can keep using this great vintage appliance!? I found a website that supplies parts for this model year, but no schematics or user manuals. Thanks!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. This website is for vacuums and you would need to contact a local lawn mower shop in the yellow pages, they are amazing about the way they can fix old lawnmowers.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 09, 2008
SOURCE: BOLEN RIDING LAWN MOWER 13AN683G163 TRANSMATIC
Either the belt routing is incorrect or there is a tensioner which needs adjusting. Recheck your belt installation. Oh, it could be the wrong belt, too.
Posted on May 01, 2009
jmgldsmth
  • 1869 Answers
SOURCE: belt installation for a cub cadet lawn mower
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10051
Posted on May 20, 2009
  • 10865 Answers
SOURCE: murray belt manual for a 20hp 46" rider lawn mower
here is a link to all of the murray manuals, for free. pick out your model and enjoy your manual.
Posted on Jun 02, 2009
  • 376 Answers
SOURCE: MTD Lawn Tractor problem
The front belt should be a 954-0280A, rear 954-0370. When you go to higher gears, the front belt should be getting tighter as the vari-speed pulley is moving further back. Remove the shift plate, put the transmission in neutral. Start the engine, put speed selector in highest gear and slowly let out on the clutch. You should be able to see what the problem is. It will do everything the same as if were in gear, except move. Make sure you have the correct belts.
Posted on Jun 28, 2009
Oil leak on deck of Lawn Mower
Because you mentioned the smoke and hard to start it could be that the engine is flooding or overfilled. Check for fuel in the crankcase. Be sure cranckcase is not overfilled. An engine with too much oil will force excess oil out somewhere. If the mower has been turned on its side lately it could have put oil in places that it should not be and its trying to burn off this oil. Be sure your air filter is not saturated with oil or fuel.
If all that checks out we will look for oil leaks.
As far as oil leaks go the three most likely places for your engine to leak are from the head gasket, dipstick tube seal, or the sump gasket.
Check for proper torque on the head bolts ( 125 inch pounds). Headbolts can come loose over time. After that check that the seal at the bottom of the dipstick tube is in good shape and a tight fit. This seal usually leaks when the engine is running because at rest the oil level is just below this seal. Lastly, if everything else checks out then the sump gasket is leaking. To replace the sump gasket drain oil from motor and remove air filter. remove blade and self propel belt. remove engine stop cable. remove the three motor mount bolts from under deck and remove motor. place on work bench upside down. some fuel may run out carb or tank cap. remove sump bolts from bottom of motor and remove sump. Do not remove governor gear or cam gear from cranckcase. At this time it will be obvious where the gasket has failed. Remove old gasket. It may need to be scraped off. Take care to keep material from going into crankcase and clean out any that does fall in. install new gasket and torque sump to proper specs and reassemble.
Jul 20, 2014 | Briggs & Stratton Garden
HOW TO REPAIR PULLEY ON TROY BILT LAWN MOWER?
Replace the damaged pulley is the best answer. Don't know which pulley you are talking about as it has 2, 1 on the motor shaft and 1 on the transmission. Most have a set screw which hold them in place on the shaft, usually will be an allen type screw.
Jul 19, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Front seal replacement
Hi No Name, The most likely place of the leakage on your car is the front crankshaft oil seal. The oil pan (sump) is fitted with silicon from a tube as the gasket. It rarely leaks unless someone has broken the seal, which is difficult and usually needs a special tool for removal. To replace it you'll need to disconnect the battery, remove the PK (Serpentine) belt and the power steering pump belt and the front engine mounting (Front of the engine but fitted onto the side of the body) Next remove the crank shaft pulley, (a difficult part of the job, made easier if the starter motor is removed and a dog tooth tool is bolted into the most suitable starter motor attachment bolt holes, the dog tooth is used to lock the flywheel while removing the crankshaft bolt holding the pulley (which is torqued to 76 nm when re-fitting. Use a puller to remove the pulley from the crankshaft and then remove the ten mm bolts holding the two parts of the timing belt cover. Set the engine to T.D.C (Top Dead Center) and look for the match marks for re-timing the engine when refitting the timing belt. Once alignment has been achieved release the bolt holding the tensioner bearing and push it all the way open, releasing all tension from the timing belt and remove the timing belt. The oil seal can now be removed from its housing. Fit a replacement oil seal smearing a light coating of grease on the seal lip. Press evenly into place, making sure of an even flush fit. Replace the timing belt with a new belt, Re-align the belt so that the match marks align precisely to those on the gears by fitting and adjusting on the straight side of the belt. Once correctly fitted, gently release the tensioner bearing until it comes into full contact with the belt and hand tighten the fixing bolt and then loosen half one turn. Remove the dog tooth tool. Screw in the crankshaft pulley bolt and apply enough force to take up slack and tighten the tensioner. Remove the crankshaft bolt and then reassemble opposite to disassembly. Remember to refit the dog tooth for re-tightening the crankshaft bolt.
Jun 28, 2014 | 1993 Toyota Corolla
Briggs
the pulley just bolts on
9/16 i think
may have to use pipe wrench to hold shaft of pulley
spray top of pulley with PB blaster should slide off might have to tap it some
May 01, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to remove a pulley on Yamaha yt6800 that drives the blower
most pulleys are on a tapered, keyed or splined shaft and require a puller to be begged borowed or stolen unless you are real lucky...tapping with a wooden drive or heating after spraying with a lubricant can sometimes work
May 25, 2012 | Garden
How do I change the drive belt on a 7021r mower? The drive will move the mower on pavement but not on the grass
First, you need to make sure you have the right tools for the job. You'll need a wrench, work gloves, mower blade clamp, drain pan and fresh fuel. Check your owner's manual for the correct belt to your specific lawn mower. Belts that are not specifically designed for your mower will not fit properly and may wear down prematurely. Next, remove the spark plug wire. This is a safety precaution to prevent the mower from accidentally starting.
Now you can remove the screws that secure the drive cover to the mower deck. Once you've taken off the drive cover, loosen the screw that holds the belt tension spring to the transmission. As the screw is loosened, tension on the belt is released allowing you to remove the belt off of the front transmission pulley.
At this point you'll need to turn your mower on its side to take off the mower blade. Be sure to use a work glove to protect your hand when removing the mower blade. You can use a lawn mower blade clamp over the blade to secure it. Unscrew the bolt to remove the blade and then the engine baffle. Once the pulley unit is exposed, you can remove the entire drive belt. Insert the new drive belt and place one end on the rear pulley and re-attach the engine baffle. Then, place the mower blade back (making sure it's facing the correct way with bottom of the blade facing the ground) and tighten the bolt. Remove the clamp and return the mower to its upright position so you can place the other end of the belt to the front pulley. Remember to tighten the screw to the tension spring.
Put the front drive cover back on, tighten the screw that secures the cover to the deck and reconnect the spark plug wire. Add new fuel to your mower and you're done!
May 14, 2011 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
How to replace belt on self propelled lawn mower
There is probably a cover on the front part of the mower that goes to the front wheels. remove the cover and you should have access to the belt. Carefully remove the belt (don't pinch your fingers) push it back towards the motor. You might have to remove the blade. Place new belt in the pulley on the engine shaft then to the pulley up front. Carefully start the belt on the front pulley and slowly turn it onto the pulley.
May 23, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Leaking oil left side of motor
Since it's not clear whether you mean driver side or passenger side, I will address both.
On the driver side, the most common leak is from the distributor. This can be caused by the distributor shaft exterior o-ring, or it can be caused by the distributor shaft interior bearing seal. To determine which it is, remove the distributor. First detach the spark plug wires, then undo the bolt that holds the distributor to the head, then pull the distributor out of the head. You will see the o-ring on the exterior of the distributor shaft. This is a $0.50 part, so just replace it with a new one as long as you have the distributor out. The bearing seal is on the inside of the distributor. To inspect it, undo the three bolts holding the cap to the distributor body. Pop the rotor off the shaft, the unclip the inside plastic cover. If you see any oil inside the distributor or the distributor cap, this means the seal is leaking and must be replaced. You can get a seal and bearing replacement kit from kbox.ca. Or, you can just buy a new distributor. Note: To get the distributor back in place you must align the shaft correctly with the notch in the camshaft. There is a right way and a wrong way. If the shaft seems to be aligned but does not go in, pull it out and rotate it 180 degrees, then put it back in.
The other possibility on the driver side of the engine is the main seal between the engine and transmission. If this is the case, you would have to either drop the transmission or pull the engine to replace it.
What if the oil is leaking on the passenger side? If it's coming from behind the timing belt cover, there is a camshaft seal and a crankshaft seal, both of which can leak oil. To get to them, you will have to remove all accessory belts and the alternator, remove the exterior crankshaft pulley, remove the engine mount (support the engine) and the timing belt covers, remove the timing belt, then the crankshaft pulley and/or camshaft pulley, whichever is necessary to replace the leaking seal(s).
Where else could oil be leaking from? If it's coming out from near the top of the engine, that's the valve cover gasket. Remove the valve cover and replace the gasket. While you're at it, replace the spark plug tube seals.
If it's coming out from near the bottom of the engine, it could be the oil pan gasket. Remove the oil pan and replace the gasket.
One more possibility for oil leakage: The head gasket. But in this case you would have noticed other symptoms besides just an oil leak.
Good luck! Let us know how it turns out.
Mar 21, 2010 | 1993 Toyota Corolla
I need to take the pulley off from under the motor so I can change out the belt.It keeps turning how do I lock it down.
Use a pair of Vice Grips, or similar, and grab the shaft behind the Pulley if possible and "Lock" it against something to stop it rotating.
Mar 11, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
