Question about Stanley 5 Watt Led Waterproof Rechargeable Spotlight Camping Hiking Flashlight
Stanley fatmax flashlight manual
How do I switch from strobe to constant light?
  • 122 Answers
SOURCE: How to basically operate my
Press the red button - (distance) you will see a red dot on the wall you are measuring - then you will hear a beep - release the button and read the display - the measurement should be displayed and accurate within a quarter inch.
Posted on Nov 23, 2008
SOURCE: Just purchased a Stanley FatMax 10-778 retractable
1. Make sure the side lock is unlocked.
2. Push the thumb tab all the way to the front of the blade handle.
3. Insert the blade in the opening, you may notice two notches on the top side of the blade.
4. Press the small blade release button as you slide the blade into the knife. You may have to jiggle up and down to get the two notches on the blade fully into the handle.
If properly inserted, the exposed area of the blade should look very close to an equilateral triangle.
make sure both notches of the blade are inside the handle. They notch into the thumb lever.
good luck
Posted on Apr 11, 2010
Testimonial: "Thanks so much!"
CarlGlas
  • 283 Answers
SOURCE: i have been given a stanley 95 111 flashlight.
You can remove either the cap or the end and replace the batteries that way. They twist counter clockwise.
Posted on Jul 21, 2010
nielsonplumb
  • 91 Answers
SOURCE: I have a stanley FatMax. How do I insert the blade
On the side there is a big gold wheel, twist counter clockwise and the case should split in half, the blade is held by a magnet, prise the old blade off and replace with new one, then put case back together and tighten gold wheel clockwise
Posted on Mar 07, 2011
  • 436 Answers
SOURCE: I need an instruction manual
here is the link:
http://www.laserstreet.com/documents/TLM100_manual.pdf
Hope this helps
Thanks
Please rate FIXYA
Posted on May 20, 2011
How can I calibrate a FatMax digital level?
Mark, Automatic calibration, check the little pockets on case instructions inside, the instructions show how.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Stanley FatMax Digital level mp4
Stanley fatmax digital level instructions Measuring Tools Measuring Tools
STANLEY HAND TOOLS Measuring Leveling Layout Levels Stanley FatMax Digital...
http://www.microprecision.com/equipment/STANLEY-CALIBRATION.html
Mar 04, 2016 | Measuring Tools & Sensors
Stanley flashlight keeps blinking like a strobe light how can I fix it
I assume it is an LED flashlight (you did not say). Cheap Chinese-manufactured LEDs will flicker in this way when they go bad. The condition is not repairable... you will need to replace the flashlight. (Save the batteries.)
May 11, 2015 | Stanley Camping, Backpacking & Hiking
Where can I download the instruction manual for a stanley fatmax 450 amp jumpstarter?
Request the manual directly from Stanley. It may not be available as a download.
Jan 12, 2015 | Stanley Measuring Tools & Sensors
How can I get a parts repair manual/list for a stanley fatmax 3.8 cfm compressor
try searching for stanley fatmax compressor . I think bostitch owns it
Nov 03, 2014 | Measuring Tools & Sensors
I have a E2d Defender and when I turn the light on the light flashes like a strobe light. Any ideas on how to fix? Thanks
THIS FLASHLIGHT SHOULD HAVE THREE DIFFERENT LIGHTS WHEN YOU ACTIVE THE SWITCH TO TURN IT ON.FIRST IS THE BRIGHT,SECOND IS THE LOWER BRIGHT AND THE THIRD IS THE STROBE.YOU SHOULD BE ABLE TO ACTIVATE ALL THREE FUNCTIONS OF THE LIGHT BY PUSHING THE SWITCH.HOPE THIS WORKS.IF THIS DOESNT WORK THEN THERE IS SOMETHING WRONG WITH THE SWITCH.
Nov 27, 2013 | Surefire E2D Defender Flashlight
Depress the switch until light goes on but does not click on and then release just a little and depress again, light should switch to solid if it does than depress button all the way until it clicks on. If there is a high and low setting on the torch than make sure you are in high.
May 07, 2013 | Stanley 5 Watt Led Waterproof Rechargeable...
Stanley fatmax s300 manual
Go to http://www.youtube.com/watch?v=QInszVD9WpE&feature=youtu.be - doesn't tell you everything, but better than the manual Stanley ship with the product, which is just a collection of hard to decipher graphics.
Feb 03, 2013 | Stanley Measuring Tools & Sensors
I have a stanley Ultra Bright LED Spotlight - I plugged it into the charger until the light turned "green". Unplugged it and went to use it and now the light flashes on & off constantly like...
Mine did the same thing so in desperation before disposing of it I did the following and it worked. I turned it on and while strobing, I locked it in place wanting to run the battery completely dead before recharging. It ran that way for about 45 seconds, it beeped and started working correctly. It may only be temporary, but worth a try.
Sep 12, 2011 | Garden
How to basically operate my stanley fatmax, TLM100. The directions that came with it were for another Stanley product. Thanks,Ralph
Nov 16, 2008 | Stanley 100 ft. Tape Measure, FatMax
Stanley 5 Watt Led Waterproof Rechargeable Spotlight Camping Hiking Flashlight Logo
628 people viewed this question
Top Stanley Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Stanley Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
