Question about Nikon COOLPIX L3 Digital Camera
Lines on some pictures
I sporadically take pictures and a number of thiem will have horizontal lines running across the entire picture to to bottom and the picture will be very over exposed. Then a picture will be fine. then a number of bad then a single good. etc. Help
    Genius:
  • 2,985 Answers
This is a failing processor. Check out repair costs from Nikon A new camera may be the better bet.
Posted on Aug 30, 2007
So I have a 50 Lg ( LG 50LN5700). There is still a picture however about every 3 seconds it goes from regular to blurry and repeats. There seem to be about 3 black lines across the top horizontally about 3...
To clarify, are the 3 black lines horizontal (left to right across entire width of screen)? or are the 3 black lines vertical (top to bottom across entire height of screen)?
Horizontal lines are almost always the result of a failed panel, and no board replacement will fix the issue.
Vertical lines such as you have described (only 3) are probably also a bad panel. If the black lines were evenly spaced in a repeating pattern, it could be a mainboard or TCONN board.
Has this panel been cracked? or perhaps cleaned recently with too much water or cleaning solvent that has gotten the screen wet?
You may have to sell the TV for parts.
Oct 23, 2017 | LG Televison & Video
White lines across tv screen
Without seeing the lines I can't be sure what your set has wrong, but here are a some possibilities:
If the lines are lines are confined to the top inch or two of the screen and the picture looks otherwise normal, the trouble is bad capacitors in the vertical output circuit. Fixable by replacing the bad parts.
If diagonal lines are across the entire face of the picture tube and the picture looks washed out, the trouble is often a bad capacitor on the 200-volt line to the picture tube. This may be on the main circuit board near the horizontal output transformer, or on the small circuit board plugged onto the end of the picture tube. Again, replacing the bad capacitor can fix this.
If your TV is actually an RCA, someone may have bumped a rear-panel adjustment. On the back of the TV near the bottom right are two small knobs. RCA left these adjustments exposed inside of putting them inside the set like other manufacturers. These sometimes get bumped if someone was behind the set cleaning, or if a pet got back there and hit them with a tail. The top knob adjusts focus, and the bottom knob adjusts something called G2 or screen voltage. If this gets turned up too high it can cause the faded picture and diagonal white lines. Turn the adjustment down until a black screen looks black instead of gray.
A bad picture tube or horizontal output transformer can also cause lines through the picture. If this is the case with your set, it's time for a new TV. The transformer is relatively inexpensive but labor costs aren't, and the repair bill may exceed $200. If the tube is bad, there's no point even considering repair. The tube cost alone exceeds the cost of new TV.
Hopefully your lines are easy and cheap to fix. Good luck, and thanks for using Fixya!
Jul 22, 2011 | RCA F35673MB 35" TV
Horizontal lines
Does the picture look 3-D at any time?
Larry
Jul 06, 2009 | Toshiba Televison & Video
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
Horizontal LINES
If you are getting fine horizontal lines thet means the picture is over exposing. most probably the apparture or the shutter blade mechanism is not working fine. needs repairs.
Jan 19, 2008 | Sony Cyber-Shot DSC-V3 Digital Camera
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
Picture Shortens, Converges, eventually the set shuts off - $50 for Correct Solution
Open the TV amd turn it on in a position you can see the picture, possibly through a mirror. Now gently tap all of the metal heat sinks on the circuit board until you find the one that is sensitive it will have a small chip mounted vertically on it, with probably like 7-10 pins. The number on the chip will most likely be an "LA****" number. Now turn the circuit board (UNPLUG FIRST) over and resolder the pins. This is your problem 99% of the time. Be very careful there is High Voltage inside this TV.
Apr 26, 2007 | Zenith IQB36B42W TV
Thin horizontal line across picture
I really dont understand the problem Could we see a picture of this please?
Jun 14, 2006 | Toshiba 35A44 35" TV
Nikon COOLPIX L3 Digital Camera Logo
402 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
