Can you connect a proscan tablet to a tv via usb cable to watch youtube?
I want to hook it to a tv so youtube videos are larger
tvtek
  • 1284 Answers
SOURCE: "No Signal" when DVD player is hooked up via component video
If you are using the same cables,same input and the cable box works ok. I would look into the settings of the DVD player. Such as is it a progressive playback and is progressive turned on. It is not turned on by default because not all TV's could handle progressive in.
Posted on Feb 08, 2007
SOURCE: Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Posted on Nov 20, 2008
SOURCE: Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
Posted on May 22, 2009
  • 2336 Answers
SOURCE: my 42 inch sylvania plasma tv does not have a coax
Since your TV only has audio and video input jacks, you can connect those to audio and video output jacks on the VCR. Now connect the coax cable to the RF/ant input on the VCR and you'll have to change channels by using the VCR channel selector.
Let me know if you require further assistance.
Posted on Aug 08, 2009
SOURCE: DVD Hook up to Proscan TV
if using RCA connector cables, connect the left and right audio cables to D and D1, then connect the Video cable to the video connector right above the S Video port.
Posted on Aug 12, 2009
How to connect youtube to your TV via computer
You can't unless it is a smart tv. You need the YouTube app on the television and on the computer, and both need to be connected to the home wifi. This is normally done via smart phone and smart television.
May 27, 2018 | YouTube Computers & Internet
Can I connect my Tablet to my tv with a USB cable to watch videos or play games?
Only if the tablet supports hdmi out. Usually via the usb port or a dedicated mini hdmi port. Check the owners manual or Google the specs for your tablet. If it doesn't you can mirror your tablet however to do so you either need a wifi enabled tv that supports mirroring or a dongle like roku, chrome cast etc. with mirroring capabilities.
Nov 14, 2016 | Tablets & eReaders
How to get a carrier for my Proscan 7-Inch Tablet with Google Android 4.1 Jelly Bean
Get a carrier to be able to use the Internet when you are away from wifi?
Just go to your local mall and ask for data only packages via a USB dongle. Like the Bell Turbo Stick in the link.
This powerful 7-Inch Tablet with multi touch Capacitive touch screen will connect you to the world. As a bonus this latest tablet includes a free case and keyboard - allowing you to input text via the touch screen or via keyboard, yours free! Enjoy movies, pictures, music, games, and thousands of APPS with this 7-Inch Capacitive touch screen tablet. The tablet features the latest in Google powered Android operating system. Android 4.1 - Jelly Bean operating system makes it easier then ever to connect to the internet and all your favorite on-line activities including, email, social networking, Facebook, Twitter, YouTube, etc. etc. Proscan's latest Android tablet includes a front facing camera allowing you to snap images, watch videos and video conference. The unit has a blazing fast 1.2 GHz processor turning any task into a dream. With 4 GB of built in flash memory plus an expandable slot to 32 GB you will be able to store and play all your digital media. Built in Wi-Fi (802.11 B/G/N) will connect this internet tablet to any Wi-Fi network and connect you to the world. You can even connect to an Ethernet LAN port (via USB dongle). There is a built in speaker so you can listen to audio with friends, plus a 3.5 MM headphone jack for the audio/video meant for your ears only. The built in rechargeable battery will give you hours of use before recharge is necessary. All your favorite sites, Facebook, Twitter, Gmail, YouTube, Pandora etc. are just 1 click away! View the web and your media in your choice of portrait or landscape mode with automatic orientation detection. Transfer all your files from your computer via high speed USB 2.0 port. With the included GetJar App store you can download thousands of applications for social media, work and play. If you are looking for a high powered, functional internet tablet, look no further, this is sure to please you. Mobile Internet plans from Bell Mobility
Jan 18, 2016 | Tablets & eReaders
I hooked my tablet up to my tv via usb cord and cant figure out why i cant watch my netflix on the tv
On the TV you need to select the port for the USB. You should have a source select button on your remote for this. If not it is in our video menu. Second, you have to make sure there is not a setting on our tablet that needs to be turned on for sharing.
Jan 29, 2014 | Tablets & eReaders
How to connect tablet to tv
Buy a compatible HD cable. Depending on your device this may vary. If you have a Samsung tablet, it will connect to your TV if your TV is also a Samsung Smart TV.
Nov 27, 2013 | Tablets & eReaders
Can I cnnect my pc to view on my proscan 32 LCD
Well I do, I mean I often connect up my PC & TV via my TV OUT, on my Video card, I hook it into my 2.4GHz Video AV "Sender" I simply use the PC's, Composite Output & the Stereo Out, audio, feed it into the Transmitter, & connect the Receiver to the TV's Composite IN & AV IN. Works great.
Feb 08, 2010 | Proscan 26LB30QD 26 in. LCD HDTV
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
Jun 20, 2009 | Proscan 32LA30Q Television
PLEASE HELP ME CONNECT MY DVD PLAYER TO MY NEW PROSCAN 32LB30Q.
Use either another HDMI cable (available at your local electronics store) or a component video and left/right audio cable to connect the two pieces together. The connections on the back panel of both pieces should be color coded and clearly marked.
Apr 10, 2009 | Televison & Video
Televison & Video Logo
481 people viewed this question
Top Televison & Video Experts
