Question about Canon CanoScan 8400F Flatbed Scanner
Canoscan Won't Scan
I moved the scanner from one place on my desk to another, and unplugged the usb cable in the process. The next time I went to use it it wouldn't scan. I didn't do anything rough with it and I've restarted my mac several times since i re-plugged in the usb cable. When I try to preview it says that either i left in the protective sheet or the lamp is too cold ... i live in san francisco and i didn't put the protective sheet in... any ideas?
  • 2 more comments
  • vmsc Dec 01, 2007
    I have the same problem with the same message. One day it worked fine the next I got that message about the film sheet or the lamp is too cold. What can we do to fix this problem. I miss my scanner!!
  • mikeoramy Apr 11, 2008
    Having the same issue after scanning film successfully, but when setting it to scan a photo again, I get the same message, and it will not scan. Tried turning off/on, making sure the lid is on correctly, etc.
  • Anonymous Aug 18, 2008
    How about some answers concerning this problem with the 8400 scanner!!
  • squirefang Dec 02, 2008
    I also have this problem and get that same error message. Reinstalling the drivers did not work for me either.
I have the same problem with my 8400f. I moved it across the room and am getting the same error message. I have reinstalled the driver several times. No go. I hooked the scanner up to a Mac that had never had the driver installed before and am getting the same message. I used the scanner successfully a month or so ago. Now nothing.
Posted on Sep 18, 2007
  • 35 Answers
You have to reinstall drivers of your scanner. Thank you.
Posted on Aug 14, 2007
SOURCE:
I cannot scan with my scanner: " it says RELEASE THE LOCK SWITCH,DETACH THE USB CABLE
Hi ,
Disconnect your unit from your pc ( usb and power)
Insert your install cd and run the program
Restart your pc
When Windows has settled , connect scanner back to pc .
It should run normaly .
Best regards.
Aug 15, 2014 | Canon CanoScan LiDe110
I just installed my new Canon LiDE 110 scanner. I slid the lock button to the unlock position. When I try to scan, I get the following error: "Release the lock switch, detach USB cable and...
mbrindle is great!!!! Many thanks - I was just about to take it back as I thought the scanner was defective. Would never have thought i had to do that. Thanks!!!
Aug 15, 2011 | Canon CanoScan LiDE100 Flatbed Scanner
CanoScan LiDE 30 Flatbed Scanner: When I click the scan button it says, "Cannot find...
Make sure the USB cable is properly connected at both ends. Close the Canoscan software and then reopen it and try again.
May 18, 2010 | Canon CanoScan LiDE 30 Flatbed Scanner
Errow msg. "release lock switch and detatch the i/f cable" still will not scan.
There is a switch on the underside on the scanner. This is the lock switch. Flipping it should solve your problem.
May 26, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Code: 31, 0, 0
met same problem. after a lot of trials, finally got rid of the Code 31,0,0 thingy.
went to:
http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide25#DriversAndSoftware
<from Software>
1. downloaded the - Driver uninstall utility
-unplugged the usb cable and run the - Driver uninstall utility
<from Drivers>
2. downloaded the - Twain Drivers
-installed the Drivers with usb cable still unplugged
3. plug and scan
Feb 09, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Canoscan lide 20 Error; Release the lock switch, detach the USB cable and reconnect. Scanner driver will be closed.
hi.. there is a lock under the scanner you need to unlock it... lock it to prevent damage while transporting...
Dec 16, 2008 | Apple Canon CanoScan N670U Flatbed Scanner
Canoscan 9950F won't scan, says scanner locked, but it isn't
I was surprised by the same problem this morning. First time I've had a problem with in years. Checked the lock... it was already unlocked. I solved the problem by unhooking the USB cable from the hub, restarting my Mac (seems to be the key), replugging the cable and restarting the scanner. Worked like a charm. Hope it works for you!
Nov 19, 2008 | Canon CanoScan 9950F Flatbed Scanner
Trouble shooting
The "car sound" could be an indication that the scanner is locked. Check the lock switch on the bottom of the scanner. Move the switch back and forth a few times and then leave it in the locked position. Another possibility is that you are scanning heavy items such as books. If too much weight is placed on the scanner glass, then pressure could be enough to prevent the scanning element from moving as it should.
The code 201 sometimes can indicate a power issue...meaning the scanner is not getting enough power. Try connecting the usb cable to a different port on the computer (preferrably directly to the computer and not through a USB hub).
May 20, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Canoscan 4200f Problem with Vista 32 bit
I got mine working after experiencing the same problem.
I had mine hooked up to a USB hub, after I hooked it directly to the USB ports in the back of my computer, everything just worked fine.
Weird that it worked on the USB hub on XP and not vista though.
Dec 31, 2007 | Canon CanoScan 4200F Flatbed Scanner
My pc will not recognize my scanner
uninstall again. download updated drivers from website then install the software again. make sure the usb cable is unplugged. install software frist then plug in usb cable make sure it is powered on.
Oct 29, 2007 | Canon CanoScan 3000ex Flatbed Scanner
Canon CanoScan 8400F Flatbed Scanner Logo
423 people viewed this question
Clive
Clive
old marine
old marine
Ekse
