FUZZY LOGIC TURBO 2.6 CU FT does not dry the clothes
SOURCE: LG FUZZY LOGIC
Are you sure it is the bowl and not inside the pump with the impellar hitting it on spin cycle? I just had the same problem and had to remove a dime from inside the pump.
Posted on Oct 10, 2008
blueextc3221
  • 15935 Answers
SOURCE: Kenmore 3.8 cu. ft. HE3t displays trouble code F-2
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 17, 2010
rickyrt441
  • 4399 Answers
SOURCE: Kenmore 3.5 cu. ft. Super
Thanks for choosing FixYa and welcome. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging. The motor drive also controls the wash. You may need a new belt for the motor or it may be bad. Make sure you check to see if the motor has power. You may have an issue with the control board or a wire.
Posted on May 05, 2011
  • 6277 Answers
SOURCE: my washing machine(fuzzy logic WFS65A01DCT)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
(If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 14, 2011
Testimonial: "thanks"
areemshaji
SOURCE: how to start a LG fuzzy logic turbo drum washing
the water is going out during the wash? how to solve it ?
Posted on Feb 19, 2012
LG Fuzzy Logic 8.5 kg washing machine WF-T855A Turbo Drum I sensor will not fully spin, stops with 2 minutes to go till end and clothes are in a ball, not spun properly,never had a problem until now??
Unplug the machine over night and then plug it back in the morning. this should reset the internal cycle back to manufacturers specs.
This problem occurs because someone may have opened the door during operations and the onboard computer recognized and remembered this, so it is now part of the standard operating proceedure.
Nov 10, 2016 | LG Washing Machines
Kenmore 500 dryer used to dry a full load of cloths in 1 regular cycle of about 40 to 50 minutes. Now the same cloths are taking nearly 2 hours to dry.
I think I would check and see if the dryer vent tube is clogged or nearly clogged. It sounds to me like it is. Try this first, if its not, I will continue to try and solve this with you.
Sep 06, 2015 | Kenmore 500 7.0 cu. ft. Electric Dryer -...
Why doesn't my dryer dry clothes?
You can find the Installation Instructions and your owner's manual here: http://www.kmart.com/whirlpool-duet-174-7.4-cu-ft-he-gas-dryer/p-02692332000P The links are about halfway down the page and are in red. There are instructions for cleaning the lint screen, which if clogged, will effect the drying time. Hope this helps.
Jun 25, 2014 | Whirlpool Duet WGD96HEAW 7.4 cu. ft. Front...
Buzzing sound
USUALLY WHEN MOISTER SENSOR DETECTS CLOTHES ARE DRIED THE BUZZER GOES OFF TO LET U KNOW SO MAY HABE BAD MOISTER SENSOR, UNLESS THE CLOTHES ARE DRYED WHEN IT GOES OFF
Apr 12, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Lg fuzzy logic wf t652
Front loader? Coins do get into the baffles. They may be riveted on. I would leave it alone, personally.
Dec 01, 2013 | Washing Machines
I have a LG 15.0kg top loading fuzzy logic washing machine. Machine does not empty water out. What could the problem be?
i have a lg fuzzy logic 15.0kg and on fuzzy mode , it continue to supply water and do not wash clothes
please can anyone help me what can i do .
Oct 26, 2012 | LG Washing Machines
Whirlpool 6.5 cu ft 5 cycle is not timing and drying clothes qui
First I would check to make sure your vent is not clogged or kinked. As far as the timer, the only fix would be to replace it. Unless of course you have the feature that detects the dryness and that would put you back at the venting problem. Good luck.
Apr 17, 2009 | Whirlpool 6.5 Cu. Ft. Super Capacity Gas...
Washing Machines Logo
108 people viewed this question
Top Washing Machines Experts
