Question about Kyocera Mita FS 3800 Laser Printer
Kyocera Mita FS-3800
MY PRINTER IS PRINTING IN AN GREY COLOR ALL OVER THE PAGE AS IF IT WAS DIRTY OR SMEARED WITH TONER.
  • Anonymous Mar 21, 2014
    I did clean the printer several times but there still is a black lane lengthwise over the whole document when I print
    I did clean the printer several times but still have the problem that there is a black lane lengthwise over each page that I print
My employer is having same problem with several printers across the network. I just found this page at Kyocera's site http://www.kyoceramita.com.au/cs_paper_spec.asp which says a lot about the type of paper to be used to avoid problems but the one which leaped off the page to me was this:
"Glossy paper or coated paper may suffer from grey background print." We all point fingers at the toner, drums, printers but it seems like the paper is a more likely culprit. I haven't tested this solution but though I would post it anyway. Even if it doesn't solve my problem, maybe it will solve yours.
Posted on Mar 03, 2008
  • 36 Answers
Go to the print driver, properties, device settings, PDL. Hit the drop down box and select PCL5. Try this first.
You could have bad toner in it. Is it OEM?
It is possible to take off the side panels on the Process unit, release the tension springs on both sides and crack open the unit. You have to remove the corona,take off the bias board and slide out the drum shaft. Vacuum out the unit and clean off the mag roller. Toner stuck on the mag roller can also do this. Once toner has adhered to the mag roller, all you can do is clean it off with a solvent....or replace it. This is "not" easy to do. I only suggest trying this, if you have done cartridges before.
Posted on Oct 26, 2007
  • Sam Oct 26, 2007
    Replace the Developer Unit.
    Problem Solver:
  • 25 Answers
Hello helpless try to clean the printer from smeared tonner and the transfer. the grey print could be as a result of printing using application sofware. make sure the tonner economy mode is not active form the application software,if it was turn it off and save, then reprint.
Posted on Aug 11, 2007
By Kyocera Mita FS-1020D printer has had it cartridge changed and his just printing a grey smear on the paper and no readable information
is the cartridge a genuine Kyocera cartridge? I had similar problems on some models with the cheaper generic products. had to strip and clean the whole process unit to rectify the problem.
Jan 14, 2011 | Kyocera Mita FS-1020D Laser Printer
Magenta is bleeding down the center of the page Kyocera FS-C5016N
you most likely will need to replace the magenta developer...
you prob dont' need a tech to do this..
these machines get very dirty..
take out all the toners.
underneath the toners is the developers.
there is a connector on the right hand side ..take out the connector
than pinch both grey tabs together and pull up and out the magenta developer... clean the magenta develop (vaccum out) or replace it
Feb 08, 2010 | Kyocera Mita FS-C5016N Printer
Kyocera FS-C5015N colour laser printer. -printing grey backgound
it seems very important to shake the toner before using your printer.
it is not too late
remove all toners and shake them well
you will find after a short time that the grey background goes away
Jul 09, 2009 | Kyocera Office Equipment & Supplies
FS-C5020N just put new toner in, color not print
your best bet with this one.. is to call kyocera support... they might give you a simple answer.. where as a tech will charge you an arm and a leg...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Apr 23, 2009 | Kyocera Mita FS-C5020N Led Printer
Kyocera FS 3800 printer - error code F3 any ideas!!!!
Technical Support You may contact Kyocera Technical Support Monday - Friday 9 am - 6 pm EST at:
1-800-255-6482
Jan 26, 2009 | Kyocera Mita FS 3800 Laser Printer
Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Jan 14, 2009 | Kyocera FS-3900DN Laser Printer
Wast Toner Box is filling up quickly.
You say there are colors in the box but the 3800 is not a color printer. If it is one of the desktop color printers there is a setting change that may help. It is a service mode setting called "T7". If you print documents that don't use much toner this setting will reduce what is dumped in the bottle during operation. If you call the Kyocera End User Help Desk they can remote in and make the change if they think it will help. 800-255-6482
Jan 09, 2009 | Kyocera Mita FS 3800 Laser Printer
Solid bar in graph is not fully covered
Hi zmienny
Unfortunetly Kyocera and HP drums not ineter change able. You will have to get the Kyocera fs3800n drum to replace.
Regards
Go-Tech
Dec 16, 2008 | Kyocera Mita FS-3800N Printer
Grey shades coming all over the page as well in top back side of paper.
The Developer unit needs to be replaced. It gives background over entire page. If the printer is under 3 years old and is original unit (developer unit) you can get a new one free from Kyocera. Very good warr. from them. Phone number is 1 800438 6482 prompt 2 ; # for the part DV-62. Have your serial # and a status page with you. I work on Kyocera FS printers. Good luck. Russ
Dec 31, 2007 | Kyocera Mita FS 3800 Laser Printer
Kyocera Mita FS 3800 Laser Printer Logo
650 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
AAAA262430
Marvin
Marvin
kyotech
Level 1 Expert
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
