Whirlpool cabrio model # wed6600vwo turn on everything lights up but when I press start it beeps and goes to sensor
MicrowaveSvc
  • 9085 Answers
SOURCE: I replaced the bulbs in the underside of the
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights fan can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jun 02, 2009
SOURCE: whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
Posted on Oct 14, 2009
SOURCE: my whirlpool cabrio dryer will not turn on and the
I'm trying to replace the motor from my Whirlpool Cabrio (WED6400SW1) dryer. The motor is impossible to remove from the blower. I can't break the motor away without stripping the plastic blower nut that connects to the two. What do you recommend I do at this point. I'm thinking that I should try to seperate the two by cutting the plastic connection and order a new blower fan.
Posted on Nov 28, 2009
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Cabrio Model WTW6400SW2
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^^^^
Posted on Sep 28, 2010
canwoodjc
  • 3301 Answers
SOURCE: Our Whirlpool Cabrio Elecetric dryer will not
it could be that or it could be the start button, you can check the button by adding a jumper in the wires that go to it,, this should be done as a check and not left that way,, for safety
Posted on Jul 03, 2011
Frigidaire dryer, model leq1452kso, does not start
some of these dryers have a fuse on them , I think that what it is or bad switch so ck for power to it ,
Mar 28, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Our Whirlpool Cabrio Elecetric dryer will not start. Model is WED6200SW1. We had just finsihed drying a load and put a 2nd load in, but it won't start. All the light come on. Could it be a sensor...
Jul 03, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My washer wont spin and the add garment light stays on. Then it starts to beep with F51 or FSl (not sure if it is a 5 or an S) shows up. Doesn't do anything more but beep.
Sorry to read about your problem, I hope this helps you out.
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, read below
Basically, the F51 error is a rotor position sensor error.
What has to be fixed?
Two parts really need to be replaced. 1) the rotor sensor itself ($43) and 2) the control board ($197). Apparently, Whirlpool has yet to officially recall these parts, but there is a new board that has a reduced or no sensitivity to the rotor sensor and thus the problem should be corrected.
Can I fix it myself?
That depends on your level of handy-skills. If you're one who can work on late model foreign cars with ease, then this probably won't be a challenge. But for most amateur handy-"people" this will require a professional.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 03, 2011 | Whirlpool Cabrio WTW6800W Washer
Whirlpool cabrio washing machine
FL error code generally means 'flood condition' which is telling you the machine is overfilling with water with water.
Try pressing STOP/CANCEL to clear the display.
If the condition persists the water fill valve or sensor may be faulty and may need replacement.
May 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Brand new Duet Dryer - WED9400SZ model - just installed and connected - everything looks good. BUT, it won't start. All I hear is a beep sound? any setting to be turned on?
Make sure that the door is firmly closed and the light inside the drum goes out. I have model YWED9400SW (brand new) that had the same problem. The spring lock on the top was not fully engaging. Press firmly on the top and bottom of the door until the light goes out then press start. Good luck.
Jan 03, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Whirlpool Cabrio Dryer Wont go past sensing light when I press start. The door is tightly closed and the filter is clean. It just won't even try to start it just just beeps once.
my dryer sensing light was on and dryer would not start, we replaced the sensor fuse and now it works the fuse is in back of dryer close to the bottom on the left hand side very easy to replace cost $11.00 by the way don't call whirlpool they have no clue, wanted to send repair man out to fix it.
Nov 04, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
