My Tungsten T3, from time to time, turns itself off within 2-10 seconds after I turn it on. The delay is random; the problem is random (it doesn't do it for weeks, and then it apparently goes into a snit about something and withdraws from the real world as described. I never buy it flowers).
Seriously, it really does do this, and I wonder if anyone else has had this problem, and how they've fixed it. It is possible that the internal battery plug is not as tight as it should be, or that there is something adrift inside (all PDAs are subjected to shocks from time to time). Your opinions?
Issue rather seems software related, if Battery issue usually comes up with low battery alert. A full (Hard) reset can be a good solution to be sure if its Software related. If you do so make sure you have backup of all your data as full reset will set everything to factory default and will erase the personal data
I have a Palm Tungsten T3 that I purchased used from Overstock last year. I replaced the battery 6...
(More)
I have a Palm Tungsten T3 that I purchased used from Overstock last year. I replaced the battery 6 months ago. Now the battery runs down in literally 2 minutes. I can see the battery indicator depleting until I plug in the USB cable. Should I try to replace this battery again? Or do I have a real lemon and just give it up?
