Question about Dell Inspiron 530 Desktop Computer
CD drive won't close
CD drive is open. I need to know how to close it.
  • Dell Master
  • 998 Answers
If the CD tray won't close then it's probably a mechanical issue with the drive and needs to be replaced.
Posted on May 01, 2014
3 Suggested Answers
SOURCE: Cd draw opens on power up and won't play a cd keeps opening after closing
This unit needs replaced it has seen better days sorry. The only thing you can try is shut off all power to the PC then unplug the PC and that cd drive from the rear of it. let the PC boot all the way up so you see your desk top. Shut it all the way down un plug PC hook back up the wires on the back of the CD player let it boot back up see if this stops it.Remember to rate my solution this is how i earn my achievements also testimonial Thanks much in advance.
Posted on Apr 22, 2012
Geekman
  • 32281 Answers
SOURCE: dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Posted on Feb 22, 2013
Why won't my packard bell's cd disc or floppy disc drive won't open
CD / DVD and most optical drives - Manual eject by sticking a straightened paperclip in the tiny hole and gently push open.
Apr 02, 2013 | Packard Bell Computers & Internet
DVD Drive opens automatically when I start up the pc and won't recognize disc
I had the same problem and it was the sata cable, I would check this and change it for one you know is good. hope it solves your problem.
Jan 09, 2013 | HP DVD 740VI 16X16 Dual Layer LightScribe...
CD ROM won't recognize CD's/DVD's
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps. if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Dec 13, 2012 | Compaq PRESARIO C500 COMPATIBLE LAPTOP LCD...
Cd player door won't open
cd/rw drive has shifted due to unit being bumped, Tray is binding or blocked. Remove the back panel. Remove 4 screws on the bottom holding cd drive. Now you can push the drive slightly back. On the left side of the drive there is a white nylon cam. Push in with a screwdriver and the tray will open so you can manually remove your cd. You should be able to cycle the tray open and closed now. Replace the four screws but cycle several times after tightening each screw. Replace the back.
Aug 30, 2012 | Crosley CR248 Turntable
Apr 22, 2012 | Dell Dimension 3000® Pentium® 4...
Cd drive won'tclose
i've already answered on your question "cd drive won't open"
solution is the same
Mar 12, 2012 | Gateway Computers & Internet
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
CD disk drive won't work or open
you need to replace the disk drive , the optical lens is not working and that way is not spin
Feb 20, 2012 | Computers & Internet
Acer 4420 laptop.vista windows,d drive won't read data dvd or cd.says insert a blank disc, when i try to open the d drive
Take a can of air and blow some onto the laser of the drive so that way you know for sure its not dust or dirt on the laser that is causing it not to read.
After you do that if the drive still won't read any discs then you know the drive is bad and it'll have to be replaced.
May 15, 2011 | Computers & Internet
Dell Inspiron 530 Desktop Computer   Logo
66 people viewed this question
Alun Cox
