Question about RCA 20F530T 20" TV
Screen on rca tv compressed into 2 inch line in middle
The screen on this tv has basically compressed into a two inch line across the middle of the screen with empty space below and above. Have tried to unplug and that is about it.
  • 398 Answers
The 20F530T uses the relatively newer ITC008 chassis. If the picture collapses down and only a small bright line is visible, it means that your vertical output IC has stopped working correctly. This could be due to a defective IC, cracked solder joints on the IC or the power supply that feeds it. The IC should be replaced or resoldered and/or the vertical power supply restored by an experienced tech familiar with the new line of RCA TV's.
Posted on Aug 11, 2007
SOURCE:
My RCA 37 inch flat screen TV has horizontal lines going through the screen
This type of issue can only be fix by a professional tech specially if its a flat screen TV. the line across indicate that there is a problem with the projection of the unit.
Nov 22, 2017 | RCA Televison & Video
Panasonic plasma tv th42px8ob 2 inche vertical line showing
do the proper isolation proceedure and try unhooking the Su from the SC board to see if you then get a normal picture all the way across the bottom half of the screen? I am assuming the Vertcal extends extends all the way from top to the bottom of the screen?
Aug 06, 2012 | Panasonic Televison & Video
White line only, has sound, may be 14 yrs old.
Hello
If there is a white line across the screen, the vertical output section of your TV is faulty. If the line is vertical at the middle of the screen, horizontal deflection yoke doesn't get sweep signal. You haven't mentioned about the full mode number of your RCA TV. Therefore I can only give you this much hint. OK.
Mar 06, 2011 | RCA Televison & Video
Rca 32 inch tv
this is a frame fault
the fact that you can still see the line when the tv is off is because you have been watching with the line and it has burnt into the crt.
time to buy a new tv
Sep 04, 2009 | Sanyo DS24205 24" TV
Black Screen with white line across the
the vertical IC most likely has failed
Jul 19, 2009 | Televison & Video
Red line across top half of screen
Uh-Oh.. Sounds like the BGA RAM in the video circuit. (These units are Intel based and Core 2 duo if posted correct).. We can repair if you need help and its under warranty and sorry its not a home remedy situation..
ikenfixit.com
Jan 17, 2008 | Apple MacBook Pro Laptop Computer with...
Tv screen goes blank with a line across middle
Hi Andy.
This is a straight forward repair & wont be expensive.
The problem is either dry joints on frame chip or component going thermal and failing at a certain temperature.
Cost for repair will be between £35.00 to £55.00 ask for a quote first.
http://dysonmanuals.inc.io/
Chris.
Dec 02, 2007 | RCA F32648 32" TV
RCA F27442 27" TV - topper half screen stripped and bottom-half is still good
check for bad c14505 220mf.
or u14501 vertical output ic.
Nov 04, 2007 | RCA F27442 27" TV
POP and noothiing
yes it can still be fixed! the pop sound you've heard maybe came from a blown capacitor in the vertical deflection circuits. this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 10, 2007 | RCA E13309 13-Inch Diagonal XL-100 Color...
RCA 20F530T 20" TV Logo
130 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
