Question about Karcher Pressure Washer 1800 PSI 15 GPM Model K348M
Simoniz piece # 9.036-694.0 PA 6.6 30% GF CIP max 130 bar max 40o C
How do I change disks in my Makita PA - GF 30? Thank you
https://www.matbase.com/material-categories/composites/polymer-matrix-composites-pmc/reinforced-polymers/material-properties-of-polamide-6-30-percent-glass-fiber-reinforced-pa-6-gf30.html
PA GF30 is the base material of the housing set of the machine not the model number made a google search for " makita saw " on pictures the chance is that you find your model .
Feb 05, 2017 | Makita Saws
What type of oil doe it use
10W-30 Turf Gard
http://www.greenpartstore.com/John-Deere-GF-3-10W30-Turf-Gard-4-Cycle-Motor-Oil-Quart-TY22029.html
May 12, 2016 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
JE POSSEDE UNE PIECE PORTANT LA REF.PP GF 30 YS61 13 K060 AA 1 305 239 147 ...
Je viens d'acheter une ponceuse d'occasion Bosch PP GF 30 et je desire avoir le manuel d'utilisation.
merci
Aug 23, 2011 | Bosch Power Tools Sanders Corner/Detail
Iam wanting to buy a 2-way cylinder to run off one of my outlets i need to know the pressure that my sk 1020 has ; in order to buy the correct one
Type Komatsu sk1020
Pump Gear
Max. flow - auxiliary hydraulic 21 gal/min 80 ltr./min
Max. pressure - auxiliary hydraulic 3,045 psi 210 bar
Control valve 3 elements fully Servo-controlled
High flow auxiliary hydraulic system "SUPER FLOW" (OPTIONAL):
Max. flow 34 gal/min 130 ltr./min
Max. pressure 3,045 psi 210 bar
cheers
Joe
www.barter-joes.com
Feb 12, 2011 | Computers & Internet
Delco no.90 566 821 ,suplier 4660103 mc,gm 0500x9595741 I need a code for this cd-player, because I losted and it*s from vauxhall vectra
I need a code for this cd-player, because I losted and it*s from vauxhall vectra b delco no.90 493 281 ,suplier 4 660 103 mc, GM 90 493 281 cdr 500 >PA 6 - GF 15< Thanks. mail sgul@qu.edu.az
Mar 06, 2010 | Car Audio & Video
I bought a PA-13 to use with my Latitude D800, and I have used an HP and Targus I own as well, however is this harmful???
  • PA-13 Family
  • Model: PA-1131-02D
  • Part No: 9Y819
  • Input: 100-240 Volts AC at 2.5 Amps 50/60 Hz
  • Output: 19.5 V DC 6.7A 130 Watts
  • **this unit was only Compatibile with: Dell Inspirion 5150, 5160
  • Jul 08, 2009 | Dell Inspiron 1501 Notebook
    Where is the sparkplugs? on a 2000 ford expedtion
    under the "cip" coil in plug. cip sets on top of plug. each plug has its own cip.
    Jun 26, 2009 | 2000 Ford Expedition
    Looking for Owners Manual for Simoniz S2600
    Hi my simoniz electrc power washer will not go off when I release the trigger , leaks trough the water inlet hose , I replaced the O rings but keeps leaking ..THANKS
    Apr 21, 2009 | Garden
    Karcher Pressure Washer  1800 PSI 15 GPM Model K348M Logo
    59 people viewed this question
    Top Karcher Garden Experts
    John Trevino
    andy just round the...
    Level 1 Expert
    Are you a Karcher Garden Expert? Answer questions, earn points and help others
