Question about Garden
I have a white outdoors lawn tractor lt 546 h with pto off when raising mower deck all the way up mower deck comes on should be off not turning rightr
2 Suggested Answers
  • 73 Answers
SOURCE: my 1979 111 john deere lawn tractor deck blades shut off
If it has a clutch, that would be the problem. An electric clutch will kick on and off when it is hot if it is bad.
Posted on Oct 02, 2009
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
Sep 19, 2008
Apr 6, 2008
Sep 25, 2015 | Cub Cadet Garden
I have an LT 1018. The PTO suddenly won't engage. I checked immediately after and found a broken spring sitting on the deck. I am pretty sure I have the right replacement spring, but I can't find where it...
There are 2 springs involved with PTO and deck belt system. They both connect to bolts standoffs. I linking you the parts diagram at Partstree where you can look at the parts layout. Hope this helps.
Lawn Mower Parts Small Engine Parts Much More PartsTree com Briggs MTD...
Nov 02, 2014 | Garden
Where is the safety switch to engage the blade
Your lawn tractor will have a lever that raises and lowers the mower deck which houses the two cutting blades. By lowering your mower deck to the desired cutting height, the blades should automatically engage. By raising the deck back to it's highest position, the blades will automatically disengage. Should be simple enough. You can consult your mower manual. If you don't have one, you can easily find it online using the make, model and year of the lawn tractor.
Jul 08, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My Lt 1050 Pto just stopped running and now it won't start
test the safety switch on the brake pedal and the pto switch
Aug 20, 2012 | Cub Cadet Garden
John Deere 314 garden tractor PTO mower deck kills engine
bypass the safety switch on the seat to test that one
Aug 13, 2012 | Garden
PTO WONT COME ON
cub cad rzt 50 o turn, pto will not come up deck,.....replaced both pto button ,safety switch that were bad, does the keys switch send power to the pto button , if so how can u check for for bad key switch thanks
Jul 21, 2011 | Cub Cadet Street Sign- tractor lawn riding...
White LT-12 lawn tractor 139-656-190 Mower deck on right side is out of alinement. Rear tire rubs on deck when lowerd. How do I ajust the deck?
I have exact same problem with my 1989 built LT-12 White tractor ! I Discovered that the Right side connecting Link #14802A,that connects the lift handle shaft #17154A with the Stabalizer bar #16465A, was broken where it connects with the Deck Lift handle shaft.
May 07, 2010 | Oregon Scientific Electric PTO Clutch for...
Need your assistance please
http://www.superxpower.com/pages/parts/viewbybrand/default.aspx
try this link, they don't deal specifically with craftsman parts, though they do have aftermarket suitable substitutes for craftsmen. This website has excellent illustrated parts breakdowns for numerous other riding lawnmowers though and I'll bet that something like MTD or White Outdoor is exactly the same as your mower. I have a White outdoor 42 inch riding mower and have changed numerous parts using these illustrations. Good luck
Apr 14, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Cub cadet lt 1018 blade will not engage when i pull knob up
It sounds like the PTO is not engaging. This is the pulley on the bottom of the crankshaft and the belt for the deck goes around. It may be time to buy a new electric PTO to solve this problem.
Go to www.precisionope.com. and put your information in. you should find a part number you need there.
Sep 28, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
