Question about Zanussi TC180W Electric Portable Dryer
Clothes dryer It is actually a Hotpoint TDL 30 Dryer Not heating up, elements seem ok but i think one thermostat is gone, tried continuity. i assume these Stats. switch off when too hot, can you explain how the two stats. work Thanks
    President:
  • 331 Answers
These t'stats are in series with the element monitoring temp's at different locations and are rated for different temperatures. When they are "satisfied", they close the circuit and allow power to the element. When dis-satisfied they "open" the circuit, thereby killing power to the element. If you are reading infinity on one or both of these t'stats when they are room temp, it indicates a failed component and must be replaced. Don't forget to OHM out your element, too. If you read anything other than infinite resistance, it's OK.
Posted on Aug 11, 2007
  • Tracy Farrell
    Tracy Farrell Aug 17, 2007
    Can you explain how my explanation of thermostats was not helpful to you? Did I not answer your question? Hmmm. Posting to a tough crowd...
SOURCE:
Heating element will not heat , the element is ok
GOD IS STILL GOOD !!!!
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Sep 09, 2014 | Hotpoint Belt for CTD00P, CTD40, CTD80,...
Heating but not drying, doesnt seem to be blowing very strong through dryer vent
Hi cipera11...
I think your problem is a clogged or cogging vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry.
But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Please take time to rate me thumbs up.
Sep 11, 2011 | Amana Dryers
The dryer heats up but doesnt dry the clothes... what could be the problem
Hi rissa306
Clogged Vent
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Cycling thermostat
This is a Free answer, Please rate me.
May 23, 2011 | Dryers
The Dryer has hot air but the clothes are not getting dry?
Clogged Vent
Heating Element
Cycling thermostat
Apr 14, 2011 | Maytag MDE6000 Dryer
Dryer takes forever to dry clothes. now it will not dry clothing
Clogged Vent
Heating Element
Cycling thermostat
Apr 11, 2011 | Dryers
It takes 3 cylcles to dry clothes
Heating Element
Cycling thermostat
This is a free answer, Please rate me
Oct 04, 2010 | Miele T1302 Electric Dryer
Hotpoint nvlr333evoww runs but clothes will not dry
there is chance that the heating element has gone bad but the first things to check are all your thermal fuses inside the cabinet of the dryer. They should all have continuity and the one that does not have anything then it needs to be replaced
Jul 06, 2010 | Hotpoint NVL333EY Electric Dryer
My heating element stays on for about 15 sec at a time-is this normal?
Is is normal for the heating element to cycle on and off. The element is usually protected by an operating (or hi-limit) thermostat that helps regulate the internal operating temperature. The element is not supposed to stay on continuously or you could end up with a scorched clothing, or a fire hazard. As your clothes get dryer, the heating element should cycle less. As long as you are not having any problems with dryer performance, you shouldn't have anything to worry about.
However, if your dryer is heating, but you are experiencing longer dry times or poor drying efficiency, the following link can give you some things to check before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will actually take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter than usual in many cases as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat failure.
Mar 12, 2010 | Dryers
Dryer Heating But Not Drying!!!
if its not heating at all the thermal is the most likely culprit and it was the little plastic piece you seen now if you have a meter set it to continuity and pull one of the wires off the thermal limiter and check it if it reads open its bad same with the heating element let me know now if the heater and thermal limiter are good pull the blower motor vent and check it for blockage
Jan 17, 2008 | Roper REX5635E Dryer
Washer dryer not heating up
both the 'wash' & the 'dryer' have their own heating elements, If the 'wash' completes its full cycle including 'spin', then I suspect this heat element is ok.Re the dryer, most likely the heat element circuit is 'open circuit' somewhere, could be  the element, thermal fuse, thermostat, or a wire burned out
Oct 23, 2007 | Hotpoint Aquarius WD640 Front Load...
Zanussi TC180W Electric Portable Dryer Logo
99 people viewed this question
Top Zanussi Dryers Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
