Question about Sony KLV-32M1 32 in. HD-Ready LCD Television
Factory reset press
Can't get the words or capcha appearing on my tv
How do I restore the factory settings on a Toshiba TV Model 32w1633DB
IMPORTANT: Different TVs may have different ways of performing the reset procedure. Refer to the Owners Manual CHAPTER 5: SETTING UP YOUR TV > RESET FACTORY DEFAULTS OR CHAPTER 6: BASIC FEATURES > RESETTING TO FACTORY DEFAULTS for your specific TV.
  • Turn off the TV and unplug the TV power cord. Leave unplugged for at least one minute. Plug it in again to complete this reset process.
  • When the TV has powered on, access the settings through the MENU button, perform the following reset procedure.
Whether your TV has Wi-Fi capabilities will dictate the steps to perform the second reset procedure. This procedure will reset all settings and channels to their factory default values.
Non Wi-Fi TVs Use one of the following procedures below to reset the TV.
Procedure 1
  • Press the MENU button on the remote (or MENU on the TV) to open the Setup menu.
  • Using the arrow keys on the remote (or volume / channel on the TV), highlight INSTALLATION at the top of the menu and press ENTER. A new set of INSTALLATION menu icons will appear.
  • Highlight the SYSTEM STATUS menu at the top.
  • Highlight SYSTEM INFORMATION below and press ENTER.
  • At the top of the SYSTEM INFORMATION window, use the arrow keys on the remote (or volume / channel on the TV) to scroll Left/Right through the menu bar to select FACTORY DEFAULTS. Press ENTER.
  • Highlight YES and press ENTER. To cancel the reset process, select NO and press ENTER.
NOTE: If a PIN code has been set, enter your PIN code. Select DONE and press ENTER.
  • A warning message will appear, select YES and press ENTER. The TV will turn off automatically after a few seconds.
  • After the TV turns off, unplug the TV power cord and then plug it in again to complete the reset process.
Procedure 2
  • Press the SETUP button.
  • Select Installation > Reset TV.
  • Enter your PIN code (if a PIN code has been set). A confirmatiom screen appears.
  • Select Yes, and then press the OK button. The TV will turn off automatically.
Wi-Fi TVs (Smart, Cloud)
Procedure 1
  • Using the arrow keys on the remote (or volume / channel on the TV), select SETTINGS > SETUP > RESET TV and press ENTER.
  • A confirmation screen appears. Select YES, and press ENTER. To cancel the reset process, select NO and press ENTER. The TV will turn off automatically to complete the reset process.
Procedure 2
Aug 30, 2017 | Toshiba Computers & Internet
How to hard reset Samsung 55UES7000
default is 0000
To perform a Factory Reset, follow these steps:
  1. With the TV powered on press the MENU button.
    1. Use the Up arrow-up_15x13.jpg or Down arrow-down_15-x-13.jpg arrow buttons to select the Support section of the Main Menu, and then press ENTER.
      1. Use the Up arrow-up_15x13.jpg or Down arrow-down_15-x-13.jpg arrow buttons to select the Self Diagnosis option, and then press ENTER.
        1. Use the Up arrow-up_15x13.jpg or Down arrow-down_15-x-13.jpg arrow buttons to select the Reset option, and then press ENTER.
          1. Your TV will require you to enter your security PIN. If you have not set up a PIN the default is 0000.
            1. A factory reset warning will appear, you can cancel the reset at this time by selecting No.
              1. The TV will power off and when it is powered back on the Setup screen will appear.
Nov 02, 2014 | Televison & Video
How to perform factory reset procedure pro1150hd
Factory Reset Procedure
1 With TV off/in standby....press home menu.
2 Within 3 sec turn TV on , Integrated Menu will appear.
3 Hold Display button until Final Setup appears in the top menu.
4 Arrow leftor right until yes appears in lower menu.
5 Hold enter until menu disappears.
6 Wait 1 min.
7 Power TV off and unplug from the wall for 5 or more min.
You can also try this:
Home Menu, select Picture, select "Reset", then ENTER, then select "Yes" and press ENTER.
May 09, 2014 | Televison & Video
What to do if television becomes "bloqueado"?
Reset your TV to factory default. use your user manual some tv's you have to hold down the up button and power button at the same time or go into the manual by pressing manual button
Apr 11, 2012 | LG 32LG30 32 in. LCD HDTV
My nokia e5 does not open continuously and the word NOKIA did not appear. how can i solve this?
Hi
Is it new?If not check its authenticity by pressing *#0000#. This will display
the phone's name and model number.
Now try hard resetting the phone to its original factory settings.But be WARNED,this will delete all your data and third party installations or downloads.
First try *#7780#. Solved?
Press *#7370#
Feb 27, 2012 | Nokia E5 Cell Phone
AOC A15X221 have picture no sound
Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Nov 20, 2011 | AOC A15X221 15 in. LCD Television
Bought this TV used and was told it needed a ballast board. I spoke with the tech that worked on it and was told a supply board as well as possibly needing a new bulb. I've replaced all three with no...
Sir when replacing the bulb you should reset the lamp hour meter. 1. while on the standby mode press "mute" then the numbers 1,8 and 2 in succession, and press the power button.
2. wait until "loading factory" appears on your screen and the service menu is displayed with the lamp life hours. You will see a list of service options.
3. Scroll down to "option" and press "enter". next you will see "reset lamp" where you will press again the "enter" button. good day and best regards.
  • 2 Wait until "Loading Factory" appears on your screen and the service menu is displayed with the Lamp Life Hours. You will see a list of service options.
  • 3 Scroll down to "Option" and press "Enter." Next you will see "Reset Lamp" where you will press again with the "Enter" button.
  • Read more: How to Reset the Lamp Hours on the TV ' eHow.com http://www.ehow.com/how_5535314_reset-lamp-hours-tv.html#ixzz1VIGJC5k7
    Aug 17, 2011 | Samsung HL56A650 56 in. TV
    How to put your lg 420 back to factory setting
    in the menu under settings/phone settings there should be an option to restore your pone to factory defaults.
    Jun 15, 2011 | Cell Phones
    I have a "craig" tv and the word factory is on the upper left corner, when this word appears i can no longer use any buttons on my tv, how do i fix this?
    Dec 24, 2008 | Craig CTV-41904 19" TV
    Audiosonic TV - Word "Factory" appears on top left corner
    Try pressing the RETURN button (above the DISP button - number 6 on the button list in the manual). The button has two arrows chasing each other. It worked for me on our Audiosonic KMC TH68 TV.
    Apr 02, 2008 | Televison & Video
    Sony KLV-32M1 32 in. HD-Ready LCD Television Logo
    26 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
