Adjust fan speed on brivis hx 23 en - Heating & Cooling
2 Suggested Answers
  • 81 Answers
SOURCE: Brivis gas heater - Wombat
Take fan apart - easy. Clean with WD40 and then oil with 3and1
Works on all fans.
Posted on Jul 19, 2011
Brivis me20e fan speed adjustable?
all u do is turn the wall controller to the off position. then press the clock button then hold buttons 2 and 4 down at the same time. let it load for 10 sec then turn the knob all the way untill it sais 1500 that is max fan speed then push the off on button to exit it. dont adjust any other values in here tho just the first one
Apr 20, 2014 | Heating & Cooling
Brivis heater HX 231-XA error code 58
I just called a technician out for a Code 58 error and it started working fine after he reset the controller. He checked for a blockage in the condensation pipe but it was clear so a bit of a mystery.
Apr 25, 2012 | Heating & Cooling
Hi I have error code 30 H1 on my Brivis heater, The problem is the fan sometime speed up itself
my power went out last night and today the heat was not working just the cooler , l turned off the main to the heater and the main power and reset the unit but is still the same
Mar 23, 2012 | Heating & Cooling
Brivis gas heater - Wombat 20 - fan doesnt seem to be operating at full speed
Works on all fans.
Jul 15, 2011 | Heating & Cooling
Hi i have a brivis eh 30 unit that comes up with error 65 and 30 the display inside the unit says fan limp, if i reset it from the unit it works for about 1 hr then the same thing can anyone help please
Hi. Here are the error codes for your Brivis Heater. Error Codes 30 - relating to speed sensor, 40 - overheating, 65 - motor lock-out. Usually resetting the unit will resolved the issue. In your case, you already reset the unit and problem came back. This will require immediate attention by Brivis technician.
Jul 12, 2010 | Heating & Cooling
Electric Radiator Fan Does Not Come On
Chevy dealer says will not come on until temperature reaches 219 f
May 16, 2010 | 2007 Chevrolet Silverado 1500 2WD
Where is the switch that cuts on the cooling fans on a 2000 grand am with a 3.4 engine
The computer turns on the fan. Based on sensors from the motor.
DTC P0480 - COOLING FAN CIRCUIT
Circuit Description
The cooling fan is controlled by PCM through the fan relay based on inputs from ECT sensor, IAT sensor, A/C selector switch, A/C refrigerant pressure switch and vehicle speed sensor. PCM controls cooling fan by grounding cooling fan control circuit which turns on cooling fan relay.
The fan relay will be commanded on when ECT reaches 223°F (106°C) or greater, A/C is requested or vehicle speed is less than 38 MPH. Cooling fan relay will also be commanded on regardless of vehicle speed when a DTC is set requesting cooling fan to be on, ECT is 304°F (151°C) or greater, or A/C refrigerant pressure is high. Cooling fan may also be commanded on when engine is not running, on certain conditions.
Conditions for setting DTC:
Battery voltage greater than 9.5 volts.
Cooling fan fault line detects a malfunction for 6 seconds.
1. Check cooling system. Ensure coolant level and belt tension are correct. Adjust/repair as necessary. After repairs, go to step 23). If no adjustment or repairs were required, go to next step.
2. Turn ignition on, with engine off. Using scan tool, check if cooling fan is operating with ECT at less than 209°F (98°C). If cooling fan is off, go to next step. If cooling fan is on, go to step 4).
3. Command cooling fan relay on. If cooling fan operates, go to step 23). If cooling fan does not operate, go to step 5).
4. Turn ignition off. Disconnect PCM harness connector. If cooling fan turns off, go to step 23). If cooling fan does not turn off, go to step 6).
5. Disconnect cooling fan relay harness connector. Using a test light connected to ground, probe battery feed circuits in relay harness connector. If test light illuminates on both terminals, go to step 7). If test light does not illuminate on both terminals, go to step icon_cool.gif.
6. Disconnect cooling fan relay harness connector. With test light connected to ground, probe battery feed circuit in relay harness connector. If test light illuminates, go to step 9). If test light does not illuminate, go to step 10).
7. Connect a jumper wire between cooling fan relay battery feed and cooling fan battery feed circuit. If cooling fan operates, go to step 11). If cooling fan does not operate, go to step 12).
8. Repair open in battery feed circuit. After repairs, go to step 23).
9. Repair short to voltage in cooling fan battery feed circuit. After repairs, go to step 23).
10. Connect test light battery voltage and probe cooling fan control circuit. If test light illuminates, go to step 13). If test light does not illuminate, go to step 21).
11. Connect test light to battery voltage and probe cooling fan control circuit. Using scan tool, command cooling fan on. If test light illuminates, go to step 14). If test light does not illuminate, go to step 15).
12. With jumper wire still connected, disconnect cooling fan harness connector. Using test light connected to ground, probe cooling fan battery feed circuit. If test light illuminates, go to step 16). If test light does not illuminate, go to step 17).
13. Repair short to ground in cooling fan control circuit. After repairs, go to step 23).
14. Check terminals to cooling fan relay. Repair as necessary. After repairs, go to step 23). If terminals are okay, go to step 21).
15. Check cooling fan control circuit for open or poor connection. Repair as necessary. After repairs, go to step 23). If circuit or connection is okay, go to step 22).
16. Connect test light to battery voltage and probe cooling fan ground circuit. If test light illuminates, go to step 1icon_cool.gif. If test light does not illuminate, go to step 19).
17. Repair open or poor connection in cooling fan ignition feed circuit. After repairs, go to step 23).
18. Check for poor connections at cooling fan harness connector. Repair as necessary. After repairs, go to step 23). If connections are okay, go to step 20).
19. Repair open or poor connection in cooling fan ground circuit. After repairs, go to step 23).
20. Replace cooling fan motor. After replacing cooling and motor, go step 23).
21. Replace cooling fan relay. After replacing relay, go to step 23).
22. Replace PCM. Program replacement PCM using required equipment. After replacing PCM, go to next step.
23. Turn ignition on, with engine off. Command cooling fan on. If cooling fan operates, system is okay. If cooling fan does not operate, repeat step 1).
May 16, 2010 | 2000 Pontiac Grand Am GT
Brivis Buffalo 85 ducted heating unit, fan is always on
On the unit outside there is a button that says "push man. pull auto" if it is set to push man then the fan will go constantly.
Sep 22, 2009 | Heating & Cooling
Brivis Buffalo 85 central heating unit - fan stays on problem
I have exactly the same problem. When I have the cover off there is a red light on, from what I can tell is the "Over Heat Fan" this seems to keep the fan on, and because it is in error prevents the system igniting. Haven't got a solution yet it only happened last night. Stu.
Jun 11, 2009 | Heating & Cooling
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
