Question about Cisco Linksys E1000 WirelessN Broadband Router Network Routers
Error 105 (net::ERR_NAME_NOT_RESOLVED): Unable to resolve the server's DNS address
I have a macbook white and PC laptop but both cannot access the internet through WiFi. Both can connect through ethernet cable. For WiFi, both can connect WiFi but when tried to access webpage, "Error 105 (net::ERR_NAME_NOT_RESOLVED): Unable to resolve the server's DNS address" appears. Why this happened and how to solve it?
Benimur
  • 6966 Answers
SOURCE: router cannot get IP with cisco 675 modem
The issue may be due to the existence of two (2) DHCP servers; 1 in the Cisco 675 and the 2nd in the DLink DI-524. You need to disable the Cisco's DHCP server function and assign static IP add & config to the DLink WAN config. This way it will only be the DLink handing out IP adds to the network.
The workaround. Install your original configuration/setting without the DLink DI-524 - PC direct to the Cisco 675 (I am assuming through Ethernet ports). Verify that indeed you are connected to the Internet and can surf the net, check e-mails, etc. Check your Networking Connection Status. Log down your PC's IP Add, Subnet Mask, Default Gateway, DNS. For purposes of discussion, let's call this "N1".
After your Internet connection has been verified with your PC directly connected to the Cisco, remove the direct connection and connect the DLink DI-524 in between the Cisco router and your PC.
Log in to the DLink and modify WAN parameters using the "N1" configurations/settings.
It might be of help to disable any security (WEP WPA, MAC etc) at least while configuring.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Feb 01, 2008
battlesmith
  • 382 Answers
SOURCE: cisco router 1841 connected to serial interface
Theres no need to setup for the nat but please check the wan interface and subnet mask ip it has to something else and not 255.255.255.252..Try 255.255.255.240 it must work...
Posted on Jul 29, 2008
  • 208 Answers
SOURCE: Connected straight through ethernet cables on
Assuming you have the wiring correct, you will have to configure the 2516 to do what you want. Without more detail, we really can't provide any more help.
Posted on Oct 03, 2009
  • 119 Answers
SOURCE: i have a cisco e1000 when i first bought it and
Unplug the modem and router, plug them back in. Wait ten minutes and restart your computer.
Posted on Feb 27, 2011
  • 693 Answers
SOURCE: my pc was connected to my moms desktop via wifi then her internet service was off for a few weeks now I can only connect by ethernet cable even though my wifi card says I am connected
You have to reset your wireless router. You need to delete the old connection on your computer to that router. To do that, point your mouse to the wireless icon in the lower right corner of your screen. Right-click on the icon and choose "Open Network & Sharing Center". In the window that opens on the left column choose "Manage Wireless Networks". Right-click on the network and choose "Remove Network" for all networks that are shown. After you've done all this, click on the wireless icon in the bottom right hand corner and choose the name of your router to re-connect. If you have a secured password, you will need to reenter it to connect. If none of this works for you, follow this link below to reset your router and modem.http://www6.nohold.net/Cisco2/ukp.aspx?vw=1&docid=785463d9ecaf4cac84aed245b08d615f_3733.xml&pid=80&respid=0&snid=14&dispid=0&cpage=search
Posted on Dec 04, 2011
Error 105 net err name not resolved server found
What is the OS. And when exactly you are receiving the error mesaage
Feb 10, 2014 | Computers & Internet
Eror 105 wifi
Error 105 is one of the most commonly faced errors by a lot of users everyday who are using Google chrome
Error 105 is a DNS resolution error. - Which means when you enter the URL of the website and hit enter in Google chrome, it tries to resolve the IP address of the website using a protocol called DNS (Domain Name System). If chrome is unable to reach the DNS server, the name resolution fails and you get the error 105.
Solution:
Once you have verified from your internet service provider that there is no problem on their end, follow the step by step instructions below.
We are simply going to add a manual DNS address in Windows so that chrome is able to resolve DNS queries.
1) Press [Windows Key + R] to open the "RUN Dialog"
Alternatively, you can also click on the start menu, type run in the search bar, and you will have the RUN Program.
Once you have the RUN box, type in ncpa.cpl and click OK - This would work for all Windows operating systems including Windows Xp, Vista and 7.
2) Next, Choose the correct network adapter (from the icons)
If you are connecting to the internet using an Ethernet cable, then most likely you are using a desktop computer. Right-Click "Local Area Connection" and click "Properties"
If you are connecting to the internet using a Wi-Fi Connection, then Right-Click on "Wireless Network Connection" and click properties
3) After you open the properties window, select "Internet Protocol Version 4 (TCP/IPv4)" and click "Properties"
4) Usually you would be having both the options set to "Automatic"
In the section below, select the "Use the following DNS Server Addresses" and enter the following values Preferred DNS Server - 8.8.4.4
Alternate DNS Server - 8.8.8.8
and click "OK", then click "CLOSE"
You must now test your new configuration by browsing a website - you can also try and browse the website you were trying to get to when you got the error 105.
Jul 06, 2012 | Microsoft Windows XP Media Center Edition...
Kodak printer ESP C310 printer not responding error code 105-100003
for more help visit CBR Tech Solutions
Sep 23, 2011 | Office Equipment & Supplies
I am suddenly getting error 105(net err_name not resolved unable to resolve dns address i tried flush dns and did not work and restarted the computer please help i found this page on my firewall that...
You are infected my friend, take the hard drive out of there, install it in an other computer (with a good up to date antivirus) than scan the drive for viruses... hours of plesure...
Aug 10, 2011 | Google Chrome
Hello,after i tried to download a couple or so mcafee virus protection downloads i keep getting the DNS error 105 name not resolved message and can't load anything unless i restart my laptop in restore...
it seems that you have a problem connecting to the DNS server which is the server who knows how to resolve the internet address you enter into the IP.
did you change anything in your internet connection settings?
did you configure a router lately?
please do the follow:
  1. Start --> Control Panel --> Network Connections
  2. right click on your LAN and select properties
  3. scroll down to the IP/TCP and select it
  4. click properties
  5. check the "Obtain and IP automatically
if this doesnt work you should contact your ISP
May 29, 2011 | Google Chrome
Error 105 Err name not resolved
May 03, 2011 | Computers & Internet
Error 105 (net::ERR_NAME_NOT_RESOLVED): The server could not be found. i keep getting this massage when i try to brows the net
When you type any name, e.g, 'www.google.com', your computer "talks" to a DNS (Domain Name Server), which translates the string 'www.google.com' into at leaset one IP-address:
Addresses: 74.125.155.103, 74.125.155.106, 74.125.155.147, 74.125.155.104, 74.125.155.99, 74.125.155.105
Aliases: www.google.com
If your computer does not have a working Internet connection, it cannot "talk" to the DNS-server.
If you spell the name incorrectly, the DNS-server will report "cannot give you an IP-address".
Contact your Internet Service Provider, to trouble-shoot your Internet connection.
Or, check for a computer-virus on your computer, which could be blocking your attempts to "talk" to the DNS server.
Jul 30, 2010 | Google Chrome
Cisco Linksys E1000 WirelessN Broadband Router Network Routers Logo
232 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
